When printer is switched on both ink and paper warning lights flash.both ink and paper have been checked or changed.
    Sergeant:
  • 352 Answers
You quite possibly have corrupted print drivers.
Try updating your printer drivers:
Create a new folder on your desktop and name it newhpdrivers(substitute your manufacturer in new name). Un-intall printer and printer software completely. Go to manufacturers website and navigate to their drivers/downloads or support menu. Select your model, choose the relevant software and download to the new folder you created on your desktop. Power down your computer. Reconnect the printer to the computer and turn printer on. Power on pc. Windows will detect new hardware and ask if you have the manufacturers install cd or a location to check for install files. Direct the wizard to your new software, follow the rest of the setup instructions and your done
anaanymous
Posted on Oct 13, 2008
Epson Stylus PHOTO R220 red lights keep flashing
I hope this will help you :)
* Green Power light flashes- The printer is receiving a print job, replacing an ink cartridge, charging ink, or cleaning the print head.
* RED paper light is On- If the CD/DVD try guide is open, close the CD/DVD tray guide, load paper, then press the paper button. Your paper ran out or multiple sheets loaded at the same time . Load paper and press the paper butoon to resume printing.
* RED paper light flashes- Paper is jammed in the printer. Press the paper button to eject the jammed paper. If the light is still flashing , open the cover and remove all paper, including any jammed or torn pieces. Then reload paper and press the paper button to continue printing.
* RED Ink Light Flashes - One or more cartridges are low on ink. Check the message that appears on your screen to determine which cartridge is low, or follow the instructions in " Checking the Ink Supply". Make sure you have a replacement cartridge.
* RED Ink Light is ON- One or more cartridges are out of ink or not installed. If you have just installed a new cartridge, it may be incomaptible with the printer or incorrectly installed. Reinstall it or replace it with the correct cartridge
* RED Ink and RED paper lights flash alternately- The CD/DVD tray guide was left open when you turned on the printer or when printing on paper. Just simply close it/
* Green Power Light is Off; RED paperand RED Ink Lights flashing- Paper may be blocking movement of the print head. Turn off the printer, then open the cover and remove any jammed paper or other foreign objects. Turn the printer back on again. Or it may have an internal error. Turn off the printer, wait a few seconds, then turn it on again.
Jul 06, 2011 | Epson Stylus Photo R220 InkJet Printer
Ink has run out ??? it no longer prints... TSP100 How do we change the ink roller/cartridge or whatever it requires?
TSP100 Thermal Printer work with a thermosensible paper, there is no ink to change, if the print quality is poor you have to
  • check the paper roller, it can be wrong installed.
  • Check the upper cover if not closed properly close it.
  • check the print head or the pressor roller.
Jun 13, 2011 | Star Micronics TSP100 Thermal Printer
My lexmark z1320 will not switch on right. the light just keeps flashing and my computer not picking up device. it was working 24hrs before and no one has used it since. can you please tell me what the...
The flashing of the lights could mean paper jam, alignment problem, ink level low warning. Try to disconnect the printer from your computer. Remove the sheets of paper from the feeder. Open the printer cover and remove the cartridges. Close the cover. Unplug and replug the printer into the power source to reset it. When the printer turns on, open the printer cover and reinsert the cartridges. Close the printer cover. Reconnect the printer into your computer. Make sure ink levels are substantial for printing. Try to print again.
May 15, 2011 | Lexmark Z1320 InkJet Printer
All the warning lights are flashing on my printer how do I get it working again? I pressed the ink check button for the 3 secs and now it will not move on to be used as the lights just keep flashing.
this usually means there is a paper jam of some sort. I would triple check to make sure no pieces of ripped paper are stuck in the rollers or are visible.after doing this, shut the pc down and the printer as well wait a few minutes start the printer and then the pc. if the lights are still on, verify that one of the ink cartridges had not become loose. this also happens when you forcefully move the printer head back. good luck
May 03, 2010 | Epson Stylus 880 InkJet Color Printer
Warning lights blink upon startup, printer freezes
If the lights flash alternately then it is probably your waste ink pads that need cleaning
If the lights flash continuously check your printer for any outstanding documents in the print queue and cancel them then try again
Mar 30, 2010 | Epson Stylus Color 740 InkJet Printer
Epson Stylus C66 PRINTER KEEPS ON FLASHING RED LIGHTS ON THE INK BUTTON AND PAPER BUTTON
Check the status monitor on the PC, this will tell you the error. If service error it need the wast ink pad counter resetting
Mar 13, 2010 | Epson Stylus R265 InkJet Photo Printer
I am having trouble changing the cartridge on the printer. The
im so sorry for the inconvineince that your having on this printer but let me help you.
if :
Red paper.jpg paper and red inkout1.jpg ink light flash alternately and green power.jpg power light is off possible problem: Paper may be blocking movement of the print head. Turn off the printer, then open the cover and remove any jammed paper or other foreign objects. Turn the printer back on again. If the lights are still on, that means the printer is having a hardware issue if: Green power.jpg power light is off; red paper.jpg paper and inkout1.jpg ink lights flash (quickly) possible problem: The printer may have an internal error. Turn off the printer, wait a few seconds, and turn it on again. If the lights are still flashing , that means the printer is having a hardware issue
Feb 10, 2010 | Epson Stylus C88 InkJet Photo Printer
RX 420 PRINTER WONT PRINT AS PAPER JAMMED WARNING KEEPS FLASHING
hi i hope i can help you? remove the cover from the machine and load paper as normal. and watch if the mechanics is sticking or anything that you can see give a clean with wd40clean all rollers check that you are puting in the correct amount off paper.check for loose connections.check for dirt on the switches.
May 04, 2009 | Xerox Phaser 8400 Laser Printer
Ink and paper lights flashing red and I cannot print
No body wants to take it to repairs, we all hate spending money if it can be avoideded. Do't fret. First, i would bet you have a paper jam that you have missed. This would stop the carriage and head cleaning. Open up the cover as if replacing ink. Get a torch and really thoroughly check for tiny paper jams or ujo's(unidentified jamming objects)check where paper goes too. Now close cover turn off, unplug, all cables, replug, turn on, try printing now. Post back if no good. Cheers lilacgerry
Aug 27, 2007 | Epson Stylus C84 InkJet Printer
67 people viewed this question
