Question about HP Computers & Internet
Have new lap top.can't get in to boot up. power failure during installation process. have message saying... windows failed to start. boot configuration data file missing required info. I have no window installation disc. what should I do?
    Master:
  • 538 Answers
Hmmm...that is unfortunate...only way to do this is with a recovery disc...
Posted on Oct 13, 2008
How do I unlock my laptop someone
Bad RAM usually causes the computer to crash during the process. An orderly failure to complete the installation usually means a bad hard drive.
Jan 09, 2015 | HP Compaq Presario V2000 Notebook
How can i install win7 os in samsung rv409 lap
Install again from the Windows7 disc. Don't forget your Samsung system board drivers!
Nov 28, 2014 | Samsung Computers & Internet
Windows logo error mesage
Press windows button and in the search type msconfig go to startup tab and uncheck those you dont want to start.
if this fails to fix the problem
Restart your computer
During the boot process you will see on the screen to press a certain key to enter setup usually the Delete or F2 key
this will vary depending on your computer and operating system
Press and hold that key during the boot up process to enter BIOS using the arrow keys load failsafe defaults or load optimized defaults press escape then press f10 to save to cmos to restart
hope this helps
Aug 14, 2012 | Western Digital (WD3200JS) 320 GB Hard...
Can a power interrupt during hard drive installation cause a "Boot manager missing" message?
You do not say what OS you were installing, and Windows limits what you can do with the hard drive during installation.
As you have found out, any power interruption during an installation will likely corrupt the process and make the system unbootable.
If you can restart the install at the very beginning that may work for you. However, I believe the simplest fix will be to use a live system bootable disk and erase the corrupted partition table on the drive then restart the install as if it were a brand new hard drive.
For that type of recovery I use gparted, which can be downloaded for free from http://gparted.org/livecd.php
Gparted live can be used on CD, hard disk, USB, or even pxe boot. I would delete all the existing partitions that were created during the failed install, then restart the install from the very beginning as if it were a new disk.
Mar 10, 2017 | Seagate BARRACUDA Computers & Internet
Everytime i open my pc there's a message that my windows is not genuine. i tried to fix it but it doesnt work, it says that the product key is invalid.. what should i do?
Do not start any of the below untill you have read the entire post you'll need some numbers that only show once.
Have you installed it on another computer?? Have you reinstalled on a new system? If so and you only use one sysetm ie the new system,the activation can be done by starting the activation process and when it gets to the point of a failure you should have an option to call,do that.When calling have your code handy and when asked how many computers the operating system is installed on you must say (one) if you say two you'll fail,at this point a number should show up in a new window.Now when your on the phone some tec will ask for the code you got during the fail and your 16 digit code,the entire process takes about 5 min's using the call in option its very fast and the call is free,All the above will work even if you have not reinstalled and your using your oraginal computer.Hope this helps rate if I've helped
Oct 16, 2010 | Computers & Internet
Unable to install XP OS to MSI lap top
Insert your installer to the lap top then try to change the boot up priority by entering the bios. Try to press del key while your lap top boot. If these deosn't wok try F1 or F2 thesame process. If you have enter the BIOS, look for the boot priority which includes the First Boot, 2nd Boot and 3rd boot. Change the 1st boot to CDROM and the 2nd boot to hardisk. Then save the changes by pressing F10. your PC will reboot and it will direct you to the OS installation.
Mar 29, 2010 | Computers & Internet
I was told it needs reformatted the message on
If you have a windows installation disc, you can boot with it and choose repair. Let windows repair the startup files. In Vista, just boot with the disc, choose repair, vista will search the windows installations and give you the result, you highlight the installation and hit repair.
If you have XP, choose repair and when is says to exit to go to recovery console ot install, click install > click F8 to agree > windows will search for windows installations, again highlight the windows installation and choose to repair at that point, windows will attempt to fix the startup files.
Sep 26, 2009 | Acer Computers & Internet
Computer keeps re-booting while installing any operating system
Were the two power supplies you tried inclusive of the original failed drive or not. In other words did you try a total a 3 power supplies including the one that failed?
If not, please do so. That is, immediately analyze the original known part failure, the power supply or its connection to the board(s) you have tried.
Congratulations for such an exhaustive process of elimination.
Apr 21, 2009 | Tyan Trinity S2090 Motherboard
My lap top says that my hard drive is going to fail
You should back up your files regularly and be prepared to purchase a new hard drive and install Windows on the new hard drive etc. when the hard drive eventually fails.
Apr 16, 2009 | Gateway Computers & Internet
Acer lap top won't boot
without operating cd you will not be able to solve the problem
Jul 02, 2008 | Acer Aspire 3680 Laptop
Computers & Internet Logo
42 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
