Question about Hitachi 43UWX10B 43" Rear Projection Television
Hitachi model 43FDX 1B
TV was playing OK, last night something happened, double image, top and bottom rounded with no picure image, and the channels indicator crooked and off by 15 degrees, adjusted the colors, both horizontal and vertical line up perfect in the middle of the screen, but on the edges they are way off.
What else can I do ?
Thanks Yvonne
    Master:
  • 538 Answers
Well..sounds to me like you need to get it to a repair person, unless you are inclined to tackle this on your own..is that your intention?
Posted on Oct 13, 2008
If the remote sensor inside the tv stops working...is there something i can get....a box or something to change channels with another device..some tv cable can go thru before to tv so if tv is on a certain...
Check your remote control for its proper working first. Then think of the remote sensor inside your TV. To get more details about how to check remote control, click this link.
If remote control is Ok, replace the infrared sensor, which can be located just behind the infrared sensor window of your Tv. You have to open your TV, and desolder it out and solder a new one in position. The infrared sensor will look like these. There are sevieral types, and just confirm which type is used in your TV. Picures of some types are attached.
6_14_2012_6_34_32_am.jpg6_14_2012_6_35_11_am.jpg6_14_2012_6_35_33_am.jpg6_14_2012_6_35_53_am.jpg6_14_2012_6_36_17_am.jpg
Jun 13, 2012 | Samsung TV Set Top Box Remote Control
Hello, My Hitachi 42" plasma is about 5 years
A description of the fault may help with an answer.
Sep 18, 2017 | Hitachi 42PD7200 42 in. HD-Ready Plasma...
The tv is showing a double image and I cannot get the color right! Model number 50v500
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} You need to upgrade to the high definition cable box---but first try this. Hook the cable from the wall directly to the tv and autoprogram it. If Comcast is anything like charter they transmit the local Hd channels in a format that digital tuner will pick them up. Just channel up/down and check out the channels with -1 and -2's behind them. Depending on where you are----your local channels will usually show up wherever they normally do but with a -1 behind it.
EX: local Fox channel on 47---autoprogram and check 47-1
If this is enough HD for you then get a two way spitter and hook your box back up and keep using the RCA (composite) cables for the best it can produce.
hope this will help..
May 21, 2010 | Hitachi 50V500 50 in. HD-Ready LCD...
Hitachi L32HO1UA HD TV blurred images very dark unwatchable scree
Hi Ellie!
Maybe in the manual you can find any information how to resolve this problem.
On this page of the manual there are shown most common receprion problems: http://manualsbrain.com/ru/manuals/979781/?page=72
Apr 26, 2017 | Hitachi 61SWX10B 61" Rear Projection...
Tv has double images colors are off top and bottom of screen has abow
that means your convergence is out. you will need to have a certified tech to fix it. it's not something any normal joe can do.
Jul 31, 2009 | Hitachi 43FDX01B TV
RED BLINKING LIGHT ON HITACHI TV CANNOT TURN ON
Check the resisters, that could be the burnt small, also you may need to replace the ICs
Jan 08, 2009 | Hitachi 53UDX10B 53" Rear Projection...
Screen appears curved on top and bottom
One or more colors can't be adjusted when when using the convergence menu. Screen is bowed in but stationary.
Solution:
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kit for your exact model. The kit inlcludes a photo instruction guide, original Sanyo STK chips, convergence resistors, etc. Everything you need to fix it yourself. Its an easy fix.
Jul 22, 2008 | Philips 55PW9363 55" Rear Projection...
Double image - not covergence
http://www.digitalhome.ca/forum/showpost.php?p=564268&postcount=220
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Nov 21, 2007 | Toshiba 42H83 42" Rear Projection...
Hitachi 43UWX10B 43" Rear Projection Television Logo
46 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
