Question about Epson Stylus Color 1160 InkJet Printer
Epson 1160 all lights are flashing. I know it wants me to contact the dealer - any way I can bypass this?
I found a very small piece of paper in the feed rollers which generated this problem.
After a jam, someone tore a sheet and left a small bit behind.
I had to take the top cover off to get access and see in. You might be able to turn the printer over and shake it gently.
Posted on Dec 02, 2008
  • 659 Answers
Before it went to flashing all lights, was there anything that was either done to the unit cleaning, ink install ect.
also I would run through all the cleaning procedures of the unit as well click the below link
and then goto the Maintenance section of the manual.
was there any grinding noises and other sounds on the last printing?
Posted on Oct 13, 2008
All light flashing on epson stylus sx105
Epson Stylus Printers all lights flashing 1160 760 860 etc ..
just found this for you not saying it will work for your printer but give it a try.
Nov 22, 2016 | Epson Office Equipment & Supplies
All lights are flashing and we cannot reset, have you any suggestions
I had a smilar problem on a HP Printer, not sure what printer your's is but you can give this a quick try, Turn the printer off, then turn it back on again while pressing both the ink and paper buttons at the same time. As soon as the paper light flashes let go of both buttons, then quickly press and hold down the ink button for 10 seconds. Hope it helps, if not could you let me know the make of your printer and I'll ask a few of my fellow Cleaners ;)
Good Luck
May 04, 2010 | Epson Stylus Color 1160 InkJet Printer
Epson stylus 880 All red lights flashing how do I know which ink to change and how? Have tried pressing button for 3 secs nothing happens
Epson aren't much help on this one. "Unknown printer error - turn off printer and contact dealer"
At a guess I would say the ink counters need resetting so it's worth trying the SSC service utility which supports the 880
It's a free app you can get it from here.
Aug 06, 2009 | Epson Office Equipment & Supplies
All lights are flashing on my epson 1160, I had just replaced the black ink and have had this problem since. anyone know what to do?
The SECOND solution posted by SLICK54 worked for me (after a few tries). I was about to give in, when it just happened. THE MACHINE RESPONDED.
Follow the procedures as HE states.
Best of luck.
Jan 15, 2009 | Epson Stylus Color 1160 InkJet Printer
Flashing ink cartridge lights, soild paper light
Normal 0 Could have a corrupt driver.
Disconnect the printer or at least be sure it is turned off. I'd do both and when the CD software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Dec 31, 2008 | Epson Stylus Color 1160 InkJet Printer
Printing partial color no black
Did you remove the plastic protector on the ink cartridge before you installed it?
Nov 06, 2008 | Epson Stylus Color 1160 InkJet Printer
Is there a fix to bypass the fault?
Try updating your printer drivers:
Create a new folder on your desktop and name it newhpdrivers(substitute your manufacturer in new name). Un-intall printer and printer software completely. Go to manufacturers website and navigate to their drivers/downloads or support menu. Select your model, choose the relevant software and download to the new folder you created on your desktop. Power down your computer. Reconnect the printer to the computer and turn printer on. Power on pc. Windows will detect new hardware and ask if you have the manufacturers install cd or a location to check for install files. Direct the wizard to your new software, follow the rest of the setup instructions and your done
Oct 13, 2008 | Epson Stylus Color 1160 InkJet Printer
Hello Stompson,
You can go here and download this utility. It will allow you to select your printer model so you can reset the maintenace request.
If in the event this does not work try this 2nd procedure, it normally works with the older Epson models and may work for your model too.
1. turn off the machine for at least 5 minutes and disconnect the interface cable to the computer
2. push and hold down the "ink" button and the "paper" button and turn the printer on.
3. When the "paper" light flashes quickly release both the buttons and then immediately press and hold down the "ink" button only for at least 10 seconds.
Aug 18, 2008 | Epson Stylus Color 1160 InkJet Printer
Printer Feed Problems
paper too thin 80gsm is too thin..try100. hope it solves your problem...did mine cheers derek
Mar 27, 2007 | Epson Stylus Color 1160 InkJet Printer
Epson Stylus Color 1160 InkJet Printer Logo
172 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
