Question about Toshiba TZ50V51 50" Rear Projection Television
Re-install TV screen
You told me to pull hard on the housing and it should come off. Should I pull at one of the corners (it seems tighter there) or the middle (more flexible)? I don't want to crack the housing if I can help it. Sorry for so many questions.
  • wrhall Nov 16, 2008
    Worked great! I have TV again.
    Sergeant:
    Champion:
  • 227 Answers
NO PROBLEM, WE'RE HERE TO HELP YOU. AND YES SEE WICH ONE OF THE CORNER COMES OFF EASILY AND JUST START FROM THERE, NOW I DO NOT UNDERSTAND HOW THE SCREEN CAME OFF AND THERE IS NOT AN OPEN CORNER UHMMM... MAYBE FROM THE MIDDLE.
Posted on Oct 13, 2008
  • ESTEBAN MERINO
    ESTEBAN MERINO Oct 16, 2008
    LOOK I AM SORRY,BUT YOU NEED TO TAKE THE BOTTON FRONT PANEL FIRST STARTING WITH THE SPEAKERS GRILL THEN YOU ARE GOING TO FIND SOME SCREWS AND THAT WILL BE YOUR SOLUTION YOU'LL SEE HOW EASY COMES OFF
    CAYPIANAN@YAHOO.COM
  • ESTEBAN MERINO
    ESTEBAN MERINO Nov 16, 2008
    thanks for your reply
I have a KDF50WE655. I have no picture and the lamp light has come on. I have removed the screws but the front cover seems to be stuck around the power button. How do I remove the front panel to acces the...
grab the bottom edge - start at a bottom corner and pull down and away .. It will feel like its gonna break but it won't . There are snaps , one in the middle and one near each corner. Pop one and work your way across.The whole bottom part below the screen frame will come off with the power button . Just pull hard as close as you can to where it's attached.
Oct 17, 2009 | Sony Grand WEGA KDF-50WE655 50" Rear...
There is a shadow in the upper left corner of the screen
someone is going to have to look inside by either removing the rear upper part of the set or removing the entire front screen---neither is easy to do. But considering your trouble I would not be surprised if the mirror is cracked---the entire front screens would have to be removed to replace the mirror--special mirror and special handling--I have seen several break when someone is not careful putting in.
Aug 22, 2009 | Televison & Video
Who does in home TV repair have an RCA D61W20 or can it be done m
The most obvious item which is causing your problem are the 220K ohm 1/4 watt resistors on the convergence power supply board. There are four of them RP10, RP11, RP12 amd RP13
Jun 18, 2009 | RCA D61W20 61" Rear Projection Television
Bluish tint that starts in lower left corner and goes across scre
i have blueish on right lower corner of screen.... what causes this
Mar 05, 2009 | Sony Grand WEGA KDF-60WF655 60" Rear...
LAMP REPLACEMENT SONY KDF42WE655
I think on this model, you will need to remove the lower front facia. There are 2 thumbwheels located on the back side of the TV near the lower left and right corners, unscrew them and then firmly grasp the panel and pull from one end. It will seem that the panel is going to break but you have to pull hard to pop it off. Once the panel is off, you'll see the lamp door with its own thumbwheel. Unscrew it and remove the door. The lamp is held in place by 2 allen or hex screws. You'll need an allen wrench of the proper size to remove them. Make sure the lamp is not hot, and then pull it out. Reverse the procedure to install the new one.
michtech
Feb 18, 2009 | Sony Grand WEGA KDF-50WE655 50" Rear...
REAR PROJECTION TV SCREEN GETTING HARD TO SEE
Your TV requires service and cleaning of screen, mirror and 3 lenses (of CRTs) as looks dusty.
Below is an exploded view how to take off front beznet assembly of this TV to clean inside with moist cotton cloth.
Unplug TV before taking off front of TV.
Jan 26, 2009 | Sony KP-43HT20 43" Rear Projection...
My mitsubishi big screen tv has a green flashing light on the front and it seem to spark when you try to plug it in, I call the tv place where it was purchased and they told me to unplug it for 1 hour and...
is the green led on the front of the tv blinking only, if this is the case the tv is in shutdown state
you will need a tech in your house to find out if there is any short
Sep 15, 2008 | Televison & Video
I've got a replacement lamp for a Samsung HLR 5067. The old lamp is a BP610125A. I was told that the new replacemet lamp is a BP96-00826A. The problem is the new Lamp's housing seems too big for my Hd...
I have the same bulb and was told by Replacement Lamps the same thing. No you can not switch the housings. I tried. The bulb is too large and does not fit in the old housing. It is the wrong lamp all together.
Aug 22, 2008 | Televison & Video
Mitsubishi wt-42311 picture is to long.
Its all in you remote.you need to turn off cable box and then tv. then turn on box from remote and then tv. I have the same problem when someone in the house turns it on incorrectly. make sure you can see the network sign in corner of tv complete then you have it. you may need to do it a couple of times. tv off first then cable box. or tv on then cable . its been awhile since i had the problem
Mar 24, 2008 | Mitsubishi WT-42311 42" Rear Projection...
Sony LCD tv
i guess its the old magnet problem maybe in fluke u or someone in your house had taken a magnet around your tv try fixing it with a magnet by moving the magnet again around the screen and using the same old technique by moving the magnet slowly on the defected area and then quickly taking it off
Nov 05, 2007 | Sony Grand WEGA KF50WE610 50" Rear...
Toshiba TZ50V51 50" Rear Projection Television Logo
Top Toshiba Televison & Video Experts
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
