Question about Mitsubishi WD-62525 62" Rear Projection HDTV
60 inch dlp tv picture is bright mitsubishi - Mitsubishi WD-62525 62" Rear Projection HDTV
    Sergeant:
  • 195 Answers
Try to restore factory settings so that we can easily diagnose if the problem is on the settings or have a faulty parts inside
Best regards,
Chester
Posted on Jan 31, 2012
SOURCE:
premtech
  • 934 Answers
SOURCE: mitsubishi wd-62825 dlp
The WD62825 has a Digital Module located on the left side of the chassis looking at it from the rear of the set. It's housed in a metal box that can slide out of its holder after removing the trim screws.
The module has its own power supply board and there are a group of 16v/1000uf caps on that board which commonly fail causing the constant flashing standby light. Further back on the module is a small board about the size of a matchbook called the E2P module. Its SMT (Surface Mount Technology) caps also commonly fail which can cause the same symptoms. Techs can tell whether the E2P has failed by simply removing it, hooking the DM back up and trying to power the set. If it powers on the picture won't be much good - but at least you can tell what's keeping it down...
Back to the caps on the pwr board. If they've failed they usually will buldge visibly on top. And ESR is almost not necessary. In any event that's the nuts and bolts on this model.
Is it a job for a layman? Yes and no - you might strongly consider a tech if you don't feel comfortable removing all the connections that the DM has with the signal board. There are about six - multi-pin - wired connections to unplug and then sliding the DM out of the unit and carefully removing the screws and latching to take the DM top cover off...
Hope this helps.
Bill
Posted on Nov 10, 2007
  • 139 Answers
SOURCE: verticle black lines on mitsubishi dlp tv screen
Press the Menu Key on your remote. If your menu shows clearly on the screen, then there is a problem with your source.
Posted on Mar 06, 2009
  • 58 Answers
SOURCE: Mitsubishi WD-52525 52-inch DLP HDTV ywllow warning lamp light
that means your lamp it is getting to the end of its life.
sometimes even if the lamp still good the TV will send you that message because that timer is closed to 5000 hours
What you can do is open the lamp door, closed again and the tv will ask you if you replaced it the lamp, and just say yes and that sign will go away
or just simple replace the lamp. 915P020010
Posted on Apr 18, 2009
  • 1039 Answers
SOURCE: Mitsubishi 57" DLP. Replaced bulb, now picture is hazy.
Cleaning th mirror and lense will remove the haze. This oldel is much older that 2 years though.
Posted on Apr 25, 2009
milkburp
  • 416 Answers
SOURCE: Screen is dim. Have brightness turned up to max
Yes... from the moment the lamp is put into service, it begins to deminish in brightness. You should order a replacement lamp to have on hand.
Posted on Mar 15, 2010
Mitsubishi 60 dlp 120hz tv picture is not as bright as before
have you checked your connections and sure your getting a HD signal for the clarity . as to Darkness it may be a lamp failing and that also may be your clarity problem if its getting to the end of its life span on the bulb
Oct 19, 2014 | Mitsubishi Televison & Video
My picture went very low where you can barly see it
By low, do you mean dark that you can hardly see a pic. If so then the bulb is going out, if its the same kind of tv as mine. Go on Mitsubishi site, and order new bulb, they are pretty easy to replace, instructions on youtube.com too!
Jun 16, 2014 | Mitsubishi WD-60738 60-Inch 3D DLP HDTV
No power no picture no lights on front panels
SOUNDS LIKE THE POWER BOARD...LOCATE A HONEST TV TECH FOR A ESTIMATE.
Feb 02, 2014 | Mitsubishi WD-60638 60-Inch 3D-Ready DLP...
How to streamline movies from Netflix to Mitsubishi
If your 60 inch TV is a "smart TV", you need to go to setup and enter your router's identification number. If it is not a "smart TV" you need to add a streaming media box (such as Roku or similar product) or "smart DVD" player with Wi-Fi feature to your system.
Jan 02, 2014 | Mitsubishi WD-60738 60-Inch 3D DLP HDTV
60 inch mitsubishi comes on no picture only sound and then it will turn off by its self
Most mornons seem to think that your TV is a traditional crt projection when in fact it is a DLP projection set and does not have convergence chips or CRTs. Instead, your set has a DMD chip and a projector lamp that passes light through the light engine where a color wheel is and the DMD chip itself. Often times DLP TVs cycle on and off again when the lamp is starting to go out. Mitsubishi is well known for this. However, it can also be a symptom of the color wheel going bad as well or simply updating the software by downloading it from http://support.mitsubishi-tv.com/
Good luck and rate me when you can.
Nov 30, 2011 | Mitsubishi WD-60737 60 in. HDTV
My 60" dlp mitsubishi tv
Sound /No picture- Have you replaced the Lamp?
If Not, First make sure fans are running when Tv is Turned on .Then if fans are OK ,Most common reason is the Lamp.
What is the Model # that is printed on back of TV?
Feb 20, 2011 | Mitsubishi Televison & Video
I have a mitsubishi 60 inch tv model wd-60c9 and i purchased it this year ..aug 06 2010 and the picture has became very dark..i am using hdmi conection and purchased new and better cables..issue still dark
The tv projection lamp have problems,it shorting out some how.That why,u have a dim picture.Tries websites like Partstore.com,Ebay.com to buy a new projection lamp for the replacement.New tv,call mitsubishi for a warrenty repair.
Oct 18, 2010 | Mitsubishi WD-60C9 60" DLP HDTV
Picture getting darker over the years
It could be your Light Engine. However, I would first check a few things:
1. Make sure your Low Power/Lamp settings are adjusted so that they meet your brightness needs.
2. Make sure you used a Mitsubishi original lamp, as generics get chewed through fast and hard.
3. Try another lamp; sometimes you can get a bad one in the bunch.
All those things don't work, consider a Light Engine ($400 + for parts; $300+ for labor)
Mar 11, 2009 | Mitsubishi WD-73827 73" HDTV DLP TV
Wd-62825 mitsubishi dlp tv
Had the same problem. Service replaced the lamp engine. It did help.
Dec 18, 2008 | Mitsubishi WD-62825 62" Rear Projection...
Mitsubishi WD-62525 62" Rear Projection HDTV Logo
67 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
