I have a zenith c34w37 tv. I have a external amplifier with 4 speakers hooked up to it. I have 2 cable tv inputs on the TV, 1 is through the cable box, 1 is without the cable box, which allows me to get some digital and hd channels. when I watch through the cable box input, my external sound works fine, when I go with the direct cable input for hd or digital I get no sound at all from the external source. I have tried both my external amplifier and my stereo system, neither work. I am using the standard variable output jacks from the TV
SOURCE: variable audio out has no output
I turned off the internal speakers in the TV and the external speakers then worked.
SOURCE: Zenith SR2075DT 1995 TV
In your on screen menu have you gone to set up? Here you would select cable and not off air and then do an automatich channelprogramming. I hope this helps.
SOURCE: Zenith 27" HDTV second antenna input not accessible on TV/remote
Hi and welcome to FixYa,
Pls verify if your particular model/versions has a PIP feature. To my understanding, the 2nd Antenna/Cable IN goes to a 2nd tuner that is primarily used for the PIP (picture in picture) mode. This mode would allow you to watch simultaneously 2 different TV channels.
Pls post back. Good luck and thank you for using FixYa.
SOURCE: Concierge by Zenith Input Problems.
I had the same tv at my motel and wanted to hook up my Wii. Turning to Channel 999 worked.
SOURCE: Zenith C27A24T 27" TV does
Greetings - You need to have you DVD player hooked up to the video inputs - See below. Don't mind the mouse scratch out lines. The Device on the right represents your DVD player.
You then have to choose video as your source on the TV (not channel 3 or 4) using your remote - see below.
You should be good to go.
Enjoy your movies,
Mikeywaf
