Question about Sony Grand WEGA KF50WE610 50" Rear Projection HDTV-Ready Television
Switching from HD to Standard screen gets a pinkish/purplish tint in SD only
Sony KF-50WE610 When I switch from HD to standard def it gets a pinkinsh/purplish tint on the screen, making it virutally unwatchable. Switching back to HD works fine. Problem is fixed when I either power reset the Cable box or TV.
I've switched out cable boxes to no avail. This is over the DVI interface.
Thanks for the help.
  • 320 Answers
It is the cable box. Using the HDMI or DVI output on cable boxes is a bad proposition; for some reason the cable box makers have not figured out how to make the HDMI/DVI output work consistently, something that rarely happens with satellite boxes. Use the component output. You will probably not be able to see a difference in picture quality and your problem will disappear. If you liked this solution, please be sure to rate it. Thanks!
Posted on Oct 30, 2008
How do I fix a fuzzy screen
A fuzzy television screen is generally not the fault of the game console itself, but of your television.
The Xbox 360 is an HD game console, and from personal experience, trying to render an hd image in 480i Standard Definition will cause it to look somewhat fuzzy regardless of the television.
Just to make sure it is not the Xbox, I would, if possible, suggest you try the 360 on another television, preferrably with the HD cables (remember that there's a switch on the cable itself that you will need to switch from SD to HD).
Unfortunately, if you do not have access to a high def television, you can always fiddle with the contrast and sharpness on your standard def TV to reduce the fuzzyness, but the screen will always be somewhat fuzzy.
I realize this is probably not the answer you wanted, but to solve this problem for my own Xbox, I ended up purchasing an inexpensive HD Television.
Nov 01, 2010 | Microsoft Xbox 360 Console
Blue hue accross bottom of screen - Sony KF-50WE610
You can try doing this, turn on the Tv and select the service menu, if that tint also shows on the menu, it's most probable to be your DMD board, but if it doesn't it might be the video board..
Jul 03, 2009 | Sony Televison & Video
Sony Grand WEGA KF-50WE610 LED blinks 4 times
4 times blink shows Temp Error and requires temperature sensor replacement in Sony KF-50WE610 TV
May 21, 2009 | Sony Grand WEGA KF50WE610 50" Rear...
SONY KF-50we610
Go to Instuction Manual of Sony KP-50WE610 page-13, there you will see details where is compartment of lamp in tv and how to open it.
Need further info, let me know.
Sep 26, 2008 | Sony XL-2100U Projector Lamp for...
Vertical colored lines on Sony KF-50WE610
Hi Lucian
This is a common Mainboard failure problem on Projectors.
The unfortunate thing is that this can only be solved by having the part repaired or replaced.
Apr 20, 2008 | Sony XL-2100U Projector Lamp for...
50 inch Sony vega tv only 3 years old and picture just went pinkish when I turned it on.
There is a defect in Sony TV's Models: KDF-60XBR950, KDF-70XBR950, KF-42WE610, KF-50WE610 and KF-60WE610. That will be covered by Sony before june 30 2008. Check Sony's web site. Here is the link
Mar 13, 2008 | Televison & Video
Unhooked ps3 from an hd tv and plugged it into an sd tv and it shows no picture.
when in standby mode(redlight) push and hold the power power button until you hear the second beep. This should reset your PS3 to it's standard 480i resolution.
Sep 21, 2007 | Sony Playstation 3 (PS3) Console
Philips 28PW6515-05 flat screen TV
You have a bad connection on the CRT board thats mounted on the end of the picture tube it sounds like, or the socket on that board that plugs into the TV set is intermittant or has a bad solder connection on it. Good Luck
Mar 27, 2007 | Philips 28PW6506 28" TV
Sony KF-50WE610 no picture?
4 blinks = No Vert. Deflection (V STOP), Screen goes to a single horizontal line then the video signal muted. Check IC1509, Q1505.
Nov 28, 2006 | Sony XL-2100U Projector Lamp for...
Sony Grand WEGA KF50WE610 50" Rear Projection HDTV-Ready Television Logo
90 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
