Question about Canon Office Equipment & Supplies
Computer says that fine cartridges are not installed .correctly. This is not so, and subsequent re-installation, makes no difference. \\\\\\\\\have tried removing usb cable and the mains lead,waiting some time,and re-connecting. No difference. Comment please.
    Sergeant:
  • 352 Answers
Try updating your printer drivers:
Create a new folder on your desktop and name it newhpdrivers(substitute your manufacturer in new name). Un-intall printer and printer software completely. Go to manufacturers website and navigate to their drivers/downloads or support menu. Select your model, choose the relevant software and download to the new folder you created on your desktop. Power down your computer. Reconnect the printer to the computer and turn printer on. Power on pc. Windows will detect new hardware and ask if you have the manufacturers install cd or a location to check for install files. Direct the wizard to your new software, follow the rest of the setup instructions and your done
anaanymous
Posted on Oct 13, 2008
Left side of unit displaying E7 message? Unit was overheated on left side! Right side working.
Are you talking about Canon MG2220 LED? If you are check this out.
https://support.usa.canon.com/kb/index?page=content&id=
ART137855
E07 FINE cartridge is not installed in the correct position.
Make sure that each FINE cartridge is installed in the correct position.
Jan 21, 2017 | Office Equipment & Supplies
Tip
Canon MP 460 An Error Message Is Displayed On The LCD
If an error message is displayed on the LCD, take the corresponding countermeasure described
below.
Message Action
There are no photos in memory
card.
There are only invalid images on the memory card.
Photo data edited/processed on a computer should be printed from the
computer, not from the camera.
There is no paper. Reload the paper correctly and press [OK].
The paper is jammed. If paper has jammed in the machine, clear the jam, reload the paper in the
machine correctly and then press [OK].
Ink has run out.
U041
Replace the FINE Cartridge, and close the Scanning Unit.
If printing is not finished yet, just press [OK] on the machine to continue
printing in the “no ink” state.
Replace the FINE Cartridge with a new one as soon as possible after
printing finishes. The machine may be damaged if printing is continued
under the ink out condition.
The following ink cartridge cannot
be recognized.
U051
U052
U053
U059
The FINE Cartridge may not be installed properly, or the Cartridge may not
be the compatible with this machine. Install the appropriate FINE
Cartridge. If lines are misaligned or the resulting output is not satisfactory,
carry out the FINE Cartridge Alignment.
Some ink cartridges are not installed
in place.
U075
U076
Confirm that the FINE Cartridges are installed in the appropriate positions.
See “Replacing A FINE Cartridge” on page 75.
The ink absorber is almost full.
Press [OK] to continue printing.
Contact the service center.
The ink absorber is almost full. Printing will no longer be possible once
the ink absorber is full. Contact the service center immediately. Press [OK]
Incompatible device detected. Depending on the model or brand of your device, you may have to select a
print mode compliant with PictBridge before connecting the device.
You may also have to turn ON the device or select Play mode manually
after connecting the device to the machine. Perform the necessary
operations according to the instruction manual supplied with your device.
If the error is still unresolved, there is a possibility that you are using a
digital camera or digital video camcorder that is not supported by this
machine. Use a digital cameras or digital video camcorder compatible with
this machine.
Auto head align has failed. Make sure all required boxes on the head alignment sheet are filled in, and
that the sheet is set in the correct position and orientation on the Platen
Glass.
If the machine is connected to the computer, you can align the FINE
Cartridge using the MP Driver. Follow the procedures described in the
Printer Driver Guide.
The following ink may have run out.
U162
This FINE Cartridge may have previously been used, or the ink may have
run out. The function for detecting the remaining ink level will be disabled
since the remaining ink level cannot be correctly detected. If you want to
continue printing without this function, press [OK]. Canon recommends to
use new genuine Canon Cartridges in order to obtain optimum qualities.
on Dec 08, 2009 | Office Equipment & Supplies
I just put in new ink cartridges. It scans fine but will not print from my computer
Hi Karen:
If it worked before you installed this cartridge, there are 3 possibles that I would check.
1) The new cartridge is defective
2) The new cartridge is not installed correctly
3) The pull tab that covers the ink ports was not removed before the cartridge was installed.
Dec 27, 2015 | Office Equipment & Supplies
Won't print dark enough
Forget buying a new toner cartridge and don't bother re-installing anything - This is a power supply problem - The electrolytic capacitors fade away after a few years of power on and the high voltage to the printing engine drops too low.I tried a new toner cartridge - no help - re-installed drivers - no help.If you can handle a soldering iron or know a friend who can, replace the following capacitors on the power supply board on the LHS (power cord side). Make sure you use low impedance 105 degree power supply types. Warning - high voltage !!! power cord out and wait 30 minutes before touching anything.
C374 341 503 529 (47uF/35V), C526 (1uf/50V), C506 (0.47uF/35V), C515 (100uf/50V). All the others tested fine in mine. Also make sure you install them the correct way around!
Now I have "black as black can be" prints just like new and I can set print density back to 2 not 5.
enjoy ;-)
Apr 24, 2012 | HP LaserJet 3030 All-In-One Printer
How do i reset ink cartridge cl511for my canon ip2700
1. Make sure that the power is turned on.
2. Open the Front Cover.
The FINE Cartridge Holder moves to the replacement position.
3. Remove the empty FINE Cartridge.
(1) Pinch the tabs and open the Ink Cartridge Locking Cover.
(2) Remove the FINE Cartridge.
4. Prepare the new FINE Cartridge.
(1) Take a new FINE Cartridge out of its package and remove the orange protective tape (C) gently.
5. Install the FINE Cartridge.
(1) Put a new FINE Cartridge in the FINE Cartridge Holder.
The Color FINE Cartridge should be installed into the left slot and the Black FINE Cartridge should be installed into the right slot.
(2) Close the Ink Cartridge Locking Cover to lock the FINE Cartridge into place.
Push down the Ink Cartridge Locking Cover until it clicks.
(3) Confirm that the Ink Cartridge Locking Cover is closed correctly.
6. Close the Front Cover.
Sep 20, 2011 | Canon Office Equipment & Supplies
How do I load the ink cartridges into the Canon Pixma printer MX320?
1. Make sure that the power is turned on, and open the Paper Output Tray.
2. Lift the Scanning Unit (Cover), then hold it open with the Scanning Unit Support on the right side.
3. FINE Cartridge.
(1) Take a new FINE Cartridge out of its package and remove the orange protective tape gently.
The Color FINE Cartridge should be installed into the left slot and the Black FINE Cartridge should be into the right slot.
(E) Closed correctly
(F) Not closed correctly (the cover is tilted)
6. Lift the Scanning Unit (Cover) slightly to set the Scanning Unit Support back to its original position, and gently close the Scanning Unit (Cover).
Oct 05, 2010 | Canon Office Equipment & Supplies
How do i replace the ink on my canon mx340
These are the steps originally from the http://www.usa.canon.com/cusa/consumer/products/printers_multifunction/office_all_in_one_inkjet_printers/pixma_mx340#ServiceAndSupport
Install the FINE Cartridges
1. Lift the Scanning Unit (Cover) (A) and fix it with the Scanning Unit Support (D).
Close the Document Cover (E) and lift it with the Scanning Unit (Cover).
important:
  • Do not touch the buttons or LCD (F) on the Operation Panel (G). May result in unintended operation.
  • When opening the Scanning Unit (Cover), the FINE Cartridge Holder moves automatically.
  • If the FINE Cartridge Holder does not move, make sure that the machine is turned on.
  • If the Scanning Unit (Cover) is left open for more than 10 minutes, the FINE Cartridge Holder moves to the right. In this case, close and reopen the Scanning Unit (Cover).
2. Make sure that the FINE Cartridge Holder (H) moves to the installation position.
3. Follow the next procedure to insert the Black g0070683.png and Color g0070684.png FINE Cartridges into their corresponding slots g0070683.png and g0070684.png.
4. Open the Ink Cartridge Locking Cover g0070683.png on the right side.
Pinch (I) firmly and pull up the cover.
5. Remove the Black FINE Cartridge g0070683.png from its package.
important:
  • Handle the FINE Cartridges carefully. Do not drop or apply excessive pressure to them.
  • Be sure to use the supplied FINE Cartridges.
  • Be careful not to stain your hands or surrounding work area with ink on the removed protective tape.
  • Do not touch the Electrical Contacts (K) or Print Head Nozzles (L) on a FINE Cartridge. The machine may not print properly if you touch them.
6. Pull the orange protective tape (J) in the direction of the arrow and remove it carefully.
7. Place the Black FINE Cartridge g0070683.png into the right slot g0070683.png.
important:
  • Do not knock the FINE Cartridge against the sides of the holder.
  • Install in a well-lit environment.
  • Install the Black FINE Cartridge g0070683.png into the right slot g0070683.png, and the Color FINE Cartridge g0070684.png into the left slot g0070684.png.
8. Push down g0070683.png of the Ink Cartridge Locking Cover until you hear a click to close it completely.
View the Ink Cartridge Locking Cover g0070683.png straight on and check that it is locked correctly (not at an angle).
9. Insert the Color FINE Cartridge g0070684.png into the left FINE Cartridge Holder g0070684.png in the same way as the Black FINE Cartridge.
10. Lift the Scanning Unit (Cover) slightly (1) and fold the Scanning Unit Support (2), then gently close the Scanning Unit (Cover) (3).
important: Do not touch the buttons or LCD on the Operation Panel. May result in unintended operation.
11. Make sure that the LCD changes as shown in the illustration and go to the next step.
  • It takes about 1 - 2 minutes before the LCD changes.
important:
  • Once you have installed the FINE Cartridges, do not remove them unnecessarily.
  • If an error message is displayed on the LCD, make sure that the FINE Cartridges are correctly installed.
note: The LCD will turn off if the machine is not operated for about 5 minutes. To restore the display, press any button except the ON button.
Aug 12, 2010 | Canon PIXMA MX310 All-In-One Printer
Canon Printer Blinking in Orange : 7 times, The
Install the ink cartridge(s), and close the access
cover.
Sep 05, 2009 | Canon PIXMA iP1300 Printer
Won't print gives error message above power and function push button incorrect color cartridge installed---was working fine yesterday no cartridge was done...
uninstall and reinstall printer and make sure u follow the promp and put the right cartridge in the right spot....black and color....2 different chambers
Apr 19, 2009 | HP PSC 750 All-In-One InkJet Printer
Camera won't connect
I had the same problem. The driver did not install correctly. I then connected the camera without the memory card in, and the driver installed correctly. Subsequent connections of camera with memory card installed, worked fine.
Nov 18, 2008 | Canon Powershot A1000IS 10MP Digital...
old marine
old marine
