Question about Adobe Photoshop 7.0 for PC
Can't access some filters in Photoshop 5.0
Some of my filters in Photoshop 5.0 are suddenly not accessible from the main screen. Those that appear in the Plug-ins/"Filters" folder are there, but not the 50 or so that appear in Plug-ins/"Effects". This is after several years of using them regularly.
  • Anonymous Jan 21, 2009
    Same problem... What the heck is the deal?
No idea
Posted on Oct 14, 2008
Mco 153s can not find how to access oven light for replacement there does not appear to be access from above under filter no door solid metal only
On page 20 of your owner's manual:
To replace oven light:
1. Disconnect power at main fuse or circuit breaker or pull plug.
2. Remove the top grill by taking out the 2 screws that hold it in place. (See Figures 3.)
3. Remove charcoal filter.
4. Pull out the Lamp cover. (See Figure 4.)
5. Replace the light bulb with a 30-watt bulb.
6. Replace light housing to original position
7. Replace charcoal filter.
8. Replace top grill and secure with screws.
9. Connect electrical power.
Aug 10, 2013 | Magic Chef Over The Range Microwave
Tip
How to set up internet on Samsung Jet
Ensure that you have the appropriate network key code needed to enable you to access a secure Wi-Fi network.
If you are connecting to a secure Wi-Fi network with MAC address restrictions, you will require pre-authorisation for the router. You will need to find your Samsung Jet's MAC (Media Access Control) address. This is a 12-character code which may be needed by the network controller to enable the phone to connect. See Getting the Samsung Jet's MAC address below.
You can get to the Wi-Fi application either via the main menu or using a homescreen Wi-Fi Widget.
  1. To get to the Wi-Fi application via the main menu, press the MENU button (either on the home screen or the hexagonal button beneath)
  2. In the main menu, swipe your finger sideways to go through the menu pages until you see the Wi-Fi icon. Press to select.
  3. The Wi-Fi application opens.
  4. Alternatively, to use the Wi-Fi Widget, from standby, press the home screen. The Widget toolbar opens up.
  5. Scroll down to find the Wi-Fi Widget icon. Press the Wi-Fi Widget. The Wi-Fi Widget will pop up on the main screen.
  6. Press the Wi-Fi Widget on the main part of the display to launch the Wi-Fi application. The Wi-Fi application opens.
  7. Once in the Wi-Fi screen, press the large Wi-Fi button in the middle of the screen to turn it on. Wi-Fi is activated and the button turns blue.
  8. Press SEARCH Nearby Wi-Fi access points (APs) will appear as small circles on the display, with their names next to them.
  9. Press the circle representing the Wi-Fi Netowrk you want to connect to. An options panel appears.
  10. You can press CONNECT to connect to the network or press ADD if you want to add it to a list of preferred networks for easy access later.
  11. You are taken into a settings menu for the Wi-Fi access point. If the Wi-Fi access point requires a network key code, scroll down to the Network Key panel. Press to select.
  12. The numberpad appears. Type in the network key code and press DONE. You are returned to the previous settings screen. Press SAVE
  13. A list of connections appears. Press the back arrow button
  14. If you initially pressed CONNECT, the phone will connect to the selected Wi-Fi network and a confirmation message will appear. The display now shows the new connection, illustrated by blue dots linking the circles onscreen (Figure 15).
  15. If you initially pressed ADD, you will be returned to the Wi-Fi screen. Press the circle representing the Wi-Fi network you want to connect to. A pop up panel appears.
  16. Press CONNECT. You will be connected and the connection illustrated onscreen.
Press the back button to return to the home screen.
  1. From the home screen press MENU to enter the main menu (Figure 1).
  2. In the main menu, press INTERNET
  3. Choose which browser option you want (Home, Enter URL, Bookmarks, etc.) (Figure 18) and press to select. If you press Home you will be taken to the pre-loaded home page.
  4. If required, use the numberpad to type in an URL or scroll a list to select bookmarks. When an URL is completed press GO. Alternatively press the bookmark you wish to access. You will taken to the web page requested.
  1. Activate Wi-Fi and press SEARCH, as before.
  2. When the Wi-Fi access point you want to connect to appears on the display (Figure 8), press it to select.
  3. A pop up options panel appears (Figure 9). Press DETAILS
  4. Details of the Wi-Fi access point appear onscreen.
  5. Scroll down by dragging your finger up the screen. Towards the bottom of the settings list, DEVICE MAC appears, with a string of 12 charactesr beneath (Figure 21). Each handset has an individual MAC address, and this panel will display your Samsung Jet's unique Mac address.
Make a note of the MAC address. You will need it if you want to use the Samsung Jet's Wi-Fi to access a secure Wi-Fi network using MAC address restrictions. This can be added into the wireless router settings access list.
on Apr 17, 2010 | Samsung Jet S8000 Cell Phone
If i have wireless internect, how do i link my wii with it?
Wireless Connection
1. On the Wii console's main menu, click on the 'Wii button' in the lower left corner.
2. This will take you to the settings screen. On this screen, click on 'Wii Settings'.
3. In the 'Wii System Settings', click on the blue arrow on the right to reach the second screen of options. On this screen, click the 'Internet' button.
4. Select 'Connection Settings'.
5. Select an open connection, indicated by 'None'.
6. Select 'Wireless Connection'.
7. Select 'Search for an Access Point'.
8. At this point, the Wii console will search for any identifiable Access Points nearby. Once this search has completed, you will be directed to choose the Access Point that you wish to connect to. Click 'OK' to display the list of available Access Points.
9. Select your Access Point from the list of available Access Points.
If your connection appears as a closed padlock, then the Access Point requires a security code or passphrase. The security code or passphrase can usually be found on the security tab of your wireless router settings.
If your connection signal appears yellow or red, the stability or strength of the connection is not optimal. If possible, remove any obstacles between the Wii console and the Access Point. I've also found that changing the channel on your router to channel 1 or channel 11 can sometimes help with singal stability and strength.
10. Click 'Save' followed by 'OK' to save your connection settings...
11. ...and select OK again to start an automatic connection test.
If the test succeeds, Internet Setup is complete and your Wii conosle is wirelessly connected!
Jul 13, 2011 | Nintendo Wii Console
Can i connect a pc to a wii to view pc screens a my tv
Instructions things you'll need:
  • Wireless router
    • 1 Determine if your Internet connection is compatible with the Wii's online console features. If you are using a dial-up connection you will not be able to connect to the Internet through the Wii console. The best connectivity is with a cable, DSL or fiber-optic connection.
    • 2 Start up your Wii. Go to the main menu. Click on the Wii icon button on the bottom left side of the screen.
    • 3 Select the "Wii Settings" button with a wrench icon. Go to the "Wii System Settings" menu.
    • 4 Click on the arrow on the right side of the screen to scroll to page two of the settings. Click on the "Internet" tab.
    • 5 Select "Connection Settings" from the menu that appears. Your screen should show three connection slots all saying "none" next to them. Select "Connection 1."
    • 6 Choose "Wireless Connection" from the pop-up screen. A new screen will appear that reads "Search for an Access Point," "Nintendo Wi-Fi USB Connector," and "Manual Setup." The easiest way to set up the Wii online is to select "Search for an Access Point."
    • 7 Wait a moment for your Wii to find an access point. When the words "Choose the access point you want to connect to" appear on your screen, click "OK."
    • 8 Pick your access point. Choose the point that is listed with a green signal strength icon.
    • 9 Save the settings by clicking "OK." Your Wii console will perform a test. A window will pop up asking you to perform a Wii system update.
    • 10 Complete the system update. Read and agree to the "User Agreements." You should be able to view movies, TV shows, websites, news and games from your PC on your TV.
Apr 17, 2011 | Nintendo Wii Console
Reset cisco airnet 1130ag
There are 2 ways to reset the access point.
Using the MODE Button
Follow these steps to delete the current configuration and return all access point settings to the factory defaults by using the MODE button:
1. blank.gifOpen the access point cover
2. blank.gifDisconnect power from the access point (the power jack for external power or the Ethernet cable for in-line power).
3. blank.gifPress and hold the MODE button while you reconnect power to the access point.
4. blank.gifContinue pressing the MODE button until the Ethernet LED turns amber. (approximately 2 to 3 seconds). Then release the button.
5. blank.gifAfter the access point reboots, you must reconfigure it using the web browser interface, the Telnet interface, or the access point console port.
Using the Web Browser Interface
Follow these steps to delete the current configuration and return all access point settings to factory defaults using the web browser interface:
1. blank.gifOpen your Internet browser. You must use Microsoft Explorer (version 5.x or later) or Netscape Navigator (version 4.x or later).
2. blank.gifEnter the access point IP address in the browser address line, and press Enter. An Enter Network Password screen appears.
3. blank.gifEnter the username Cisco in the User Name field.
4. blank.gifEnter the password Cisco in the Password field and press Enter. The Summary Status page appears.
5. blank.gifClick System Software. The System Software screen appears.
6. blank.gifClick System Configuration. The System Configuration screen appears.
7. blank.gifClick the Reset to Defaults button.
Note blank.gifIf the access point is configured with a static IP address, the IP address does not change.
8. blank.gifAfter the access point reboots, you must reconfigure it.
Aug 13, 2010 | Cisco Aironet 1131AG 802.11a, 802.11g/b...
Please give me authorization code for adobe photoshop cs3
Adobe Software Activation http://www.adobe.com/products/activation/phonenumbers.html
Chat activation Chat activation specialists are available from 6am to 3pm Pacific Time Monday through Friday. The yellow "Chat Now" button will be shown on the right when our specialists are available to assist you.
Phone activation You can activate your product via the Internet or by phone, either with a live customer service representative or through the 24-hour automated voice response system. To activate by phone, find the number to call by selecting your location from the following list (these numbers are also accessible from the activation screens that appear automatically when you install your product). For more information, see the software activation main page.
Jan 12, 2010 | Adobe Photoshop 7.0 for PC
Apps on main screen won't fully close
This turned out to be just undocked apps from the quick access bar. I just had to drag them back to the quick access bar.
A more rigorous reading of the user's manual led me to this solution.
Dec 25, 2009 | Samsung Eternity Cell Phone
Icons suddenly appear huge- iphone
Double tap the screen with 3 fingers and it will unzoom. Then to switch the feature off, go to settings, accessability and turn off zoom feature.
Hope this helps and if so please vote.
Thanks
Jim
Oct 18, 2009 | Apple iPhone 3G
Adobe Photoshop 7.0 for PC Logo
349 people viewed this question
Top Adobe Computers & Internet Experts
lemesee
Are you an Adobe Computer and Internet Expert? Answer questions, earn points and help others
