Question about RCA P46924 46" Rear Projection Television
Rca projection 46in model p46813bl
The colours are splitting looks like there is 3 of everything
    Problem Solver:
  • 10 Answers
Convergence unit is bad 50 - 75 to replace
Posted on Oct 23, 2008
My 52 inch rca hdtv comes on but it looks like the screen is bowed and the colour is off.do you know of any solutions to this problem.
My rca 52 inch hdtv picture looks bowed on the top and bottom of screen. And everything looks like it has a red shadow behind it.
May 12, 2010 | Televison & Video
Rca p46813bl convergence problem bowed in the
OK., I know this set very well. It almost never has a convergence problem.
With the set unplugged, remove the back cover--there is a small circuit board mounted ABOVE the main boards--it is about 10 inches wide and 4 inches tall---On the far right side of it are several DIODES---two are much larger then the rest--what usually happens is one of the large diodes is shorted--5 dollar part---the board only has a few plugs and 4 screws that hold it in---easy to remove--check all the diodes(the two large ones first)
If either of the large diodes read like a fuse you FOUND YOUR TROUBLE.
LET me know if you need ANY help or Advice--I am here to help people---I have seen several sets identical to yours with the problem you describe.
Regards, SD TECH
Oct 06, 2009 | RCA P46924 46" Rear Projection Television
I have a 52 inch RCA projection TV about 15 yr old today the colours are not lining up causing a shadow of red behind white lettering and looking like a 3 D show withought wearing the proper glasses?
you need to replace the convergence supply board, if it's one of the earlier models, you change the chip stk730-130 that will fix it. the board is small and up off the chassis to the right slightle, 4, 1/4'' screws holds it in place.
you might be able to get a whole new board, which would require no soldering to fix.
Sep 15, 2009 | RCA P52926 52" Rear Projection Television
Color is splitting, and almost looks 3D.
the ITC222A convergence option missing repair kit at the following link should repair that issue. The kit contains the parts and the instructions on CD
http://www.tvrepairworld.com/
Jul 19, 2009 | RCA R52WM24 52" HDTV Projection Television
RCA Projection TV Model #p46921, Has bowing effect of pictures
Go to Menu then setup look for convergence if you do not see convergence on menu then you have a open FUSE FL231 it is on right side of FBT flyback transfomer there is 3 of them small brown rectrangler looking caps it will be the one in the Middle.
Jan 31, 2009 | RCA R52WH73 Projection Television
Distorted picture on RCA LCD TV
it can be replaced with a t0220 stile case dioded 220k ohm go to nte look up and do a search on the rca part #moz-screenshot.jpg 259638 search the web for the part.
Jun 29, 2008 | RCA R52WM24 52" HDTV Projection Television
Rear Projection tv problem
This is a problem with convergence. Please post the make and model and further details can be provided.
Thanks,
Dan
Apr 18, 2008 | Televison & Video
RCA p46813BL with no picture but good sound
The good news is your set has a picture therefore is not an output transistor,the problem your set has is a signal processing problem,no video of any source is being processed,is just a different kind of problem and for that you will need the assistance of a servicer to diagnose,try taping where the cables conect to the tv if the set reacts the loose conection is close to that imput panel but if it does not be safe and call for help.
Oct 01, 2006 | RCA P46812BL 46" Rear Projection...
RCA P46924 46" Rear Projection Television Logo
122 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
