Question about Amana AER5515QA Electric Kitchen Range
Oven door on my Amana big oven 5.14 electric range wont shut tightly
The oven door does not shut completly, The locking hook is in the right position and the range will go into its cleaning cycle but so much heat is lost through the gap at the top of the door the handle has turned yellow. I checked the hinges at the bottom and they are very tight. Is that how the door is adjusted?? It looks like the door is about 1/2 inch to low
3 Suggested Answers
SOURCE:
aborcass
  • 2651 Answers
SOURCE: oven door won't close tight
order and replace door springs part # 32052801 youll need 2
Posted on Feb 26, 2008
  • 415 Answers
SOURCE: I have an amana model ART660L electric self
if it the type that the top raises then you have axcess to the cover to the lock if not then it will have to be unplugged and the back panel removed depending on the model a small motor will have a long rod attached with a screw undo the screw and pull the rod forward or push in this will unlock the door mech
Posted on Aug 19, 2009
Why does the oven cleaning light come on when i turn the oven on
Make sure that you slide the oven door latch all of the way to the left after the clean cycle. If the latch is still positioned to the right in the locked position then the CLEAN light will continue to blink. If the door latch lever is positioned properly to the left and the CLEAN light is still flashing then you could have a problem with the latch mechanism or the electronic oven control. You can try to reset the electronic control board by unplugging the range for several minutes (or shutting off the breaker for the range outlet) to completely disconnect electrical power. If the CLEAN light still blinks after you restore electrical power then you will likely need to have the range serviced by a technician.
Sep 09, 2016 | Hotpoint Kitchen Ranges
Unlock oven door on amana ACF4225AW ?
Below is a link to sears parts direct. You can download an owners manual. See parts diagrams and order parts.
After cooling the oven door should unlock.The lock mechanism shows on the second link to cabinet parts.
The switches on the lock are sometimes the cause.
Good Luck.
Manual Amana Electric range ACF4225AW PACF4225AW0
Link to cabinet parts.
AMANA Electric Range Cabinet Parts Model ACF4225AW PACF4225AW0
Aug 24, 2014 | Kitchen Ranges
Got F9 on Amana range model ACS3350 while trying to clean oven. The door is locked and got constant beeping with F9 error code. Powered off oven for 10 minutes and powered on, still getting the door...
Shut off the circuit breaker to it for FIVE minutes, then back on. If the problem persists then do the following:
A latch locks the center top INSIDE of the door during cleaning.
Run a piece of semi-stiff, flat object, like a cardboard strip that is in L shape behind the top lip of the door from RIGHT TO LEFT. You may need to push it along with your finger jambed in there when it reaches the latch. With a little push the latch should open.
Try to run the oven, if F9 shows again, press cancel Oven to quiet it. The Lock state is still in place. Move the latch hook manually all the way to RIGHT. Then shut off the circuit breaker for FIVE minutes, then back on. The oven should work ok.
If this fails again try the five minute shut off with the latch in other starting positions.
If none of these work then the latch mechanism, or it's motor is really broken. Replace or ditch and never buy Amana again!
Sep 01, 2011 | Amana AOCS3040SS Electric Single Oven
Amana range model 770M door won't fully close
Is the door hitting the door lock hook. Or a strike pin hitting the inside door panel. If this is a self cleaning range the door seal is a metal mesh and does hold the door slightly away, this is normal. More info ?
Sep 01, 2009 | Amana ACF4215 Electric Kitchen Range
Aug 19, 2009 | Amana Kitchen Ranges
Dacor oven door does not close completely
Place a hammer handle between the hinge and the door frame. Exert moderate pressure to close the door. It should spring back to normal position. Do both sides.
May 05, 2009 | Dacor Epicure ERD36 Dual Fuel (Electric...
Oven door is locked
the oven door should only unlock the door when it deems the temperature a safe temperature.. there are 2 other possible reasons.. the door lock motor could be bad.. or the control is bad.. you would need an electric volt meter to test to see which it is.. if you need further assistance please ask b4 rating
Apr 09, 2009 | Amana ACS7270AS Electric Kitchen Range
My Amana oven door will not shut tightly.
twist a tesher like a roll and put it betwing the door and the frame of stove then close the door gently to bring back the hinges to position.
Nov 17, 2008 | Maytag MER5755QAS CleanDesign Electric...
Oven
The lock spring unhook back cover must open / gas must be shut down. before open back cover., spring might cut spring hook corroded possibility door door lock malfunction.
Jan 03, 2008 | Hotpoint RGB745 Gas Kitchen Range
Self cleaning oven door locked before I got the door closed.
Try holding in on the door switch while resetting the clean cycle.
This should rotate the latch. Once the cycle starts, cancel it. The latch should go to the unlock position.
You will have to hold in on the door switch during all these steps.
If this does not work, post back with the complete model number from the oven and I will see what else I can come up with.
Nov 25, 2007 | GE JGB916SEKSS stainless steel Gas Kitchen...
Amana AER5515QA Electric Kitchen Range Logo
270 people viewed this question
Top Amana Kitchen Ranges Experts
Sal De
Ismael Rodriguez...
Paul Carew
Are you an Amana Kitchen Range Expert? Answer questions, earn points and help others
