Question about Brother HL 1440 Laser Printer
Alarm and Data lights
The alarm and data light turn on for about 2 seconds and then go off for about 5 seconds. It still prints, but this has to be telling me something is wrong.
    Sergeant:
  • 352 Answers
Hi, this may clear the fault: Try updating your printer drivers:
Create a new folder on your desktop and name it newhpdrivers(substitute your manufacturer in new name). Un-intall printer and printer software completely. Go to manufacturers website and navigate to their drivers/downloads or support menu. Select your model, choose the relevant software and download to the new folder you created on your desktop. Power down your computer. Reconnect the printer to the computer and turn printer on. Power on pc. Windows will detect new hardware and ask if you have the manufacturers install cd or a location to check for install files. Direct the wizard to your new software, follow the rest of the setup instructions and your done
anaanymous
Posted on Oct 13, 2008
5 yellow blinks and nobody else ,
Issue: Alarm / Power light flashes orange 5 times consecutively (Print Head / Cartridge Error)
Solution: Reseat the print head iP3000
  1. Confirm that the printer is powered on.
  2. Open the paper output tray and top cover.
    Note: Gently open the paper output tray while holding it.
  3. After confirming that the print head holder has moved to the center, open the inner cover.
  4. Remove all ink tanks
  5. .Raise the print head lock lever and remove the print head.Re-seat the print head into the print head holder and lower the print head lock lever until a click is heard.Insert the appropriate ink tank into the slot at the right end and push down on the PUSH mark on top of the ink tank until a click is heard. Install the other ink tanks in the same manner.Close the inner cover and top cover.Properly installed: Note: Check that each ink tank is installed in the correct position
Solution: 2 Reset the printer
Resetting the Printer By resetting the printer's power, the print buffer is cleared and certain sensors are reset. If there is invalid data in the buffer, or sensors are stuck in a particular mode; errors may occur. Follow these steps to reset the printer:
  1. Turn the printer off with the Power button (if available).
  2. Disconnect the data cable from the printer (not applicable to WiFi, Bluetooth or Infrared) .
  3. Unplug the printer's power cord for approximately 10 minutes, and then plug it back in. If troubleshooting a communication issue, reconnect the data cable (not applicable to WiFi, Bluetooth or Infrared).
  4. Turn the printer back on.
Aug 30, 2011 | Canon PIXMA iP3000 InkJet Photo Printer
When I turn on the printer, the data and alarm lights come on. There is nothing in the printer que. I have power cycled the printer. I was trying to print a pdf file.
From the Service manual:
Toner low: The Data and Alarm LEDs blink once every five seconds.
Toner empty: The Data and Alarm LEDs blink once every second.
Alarm & Data LEDs are ON: Toner empty
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Feb 11, 2011 | Brother HL 1240 Printer
Drum, alarm, and data lights on--won't prnt
This unit might need resetting!
Here's how..
There's two ways to reset it
First: Soft Reset
1. Open front cover.
2. Hold down button located under LED's until all LED's are lit.
3. Release button and make sure drum LED is off, then
4. Close cover
Second: Factory Reset
1. Turn the printer off.
2. Hold in the circular button on the front panel of the printer.
3. Turn the printer back on.
4. When the DRUM light is lit by itself let go of the button.
5. Hold in the circular button on the front panel again.
6. Once the Alarm light comes on, let go of the button.
This will perform a factory reset on the printer.
I hope that's everything you want.
Please accept this answer if this will help you.
Thank you for using Fixya.
Aug 01, 2010 | Brother HL 1440 Laser Printer
Ready light doesn't stay lit, alarm light is red
Because I was getting gray shading on my pages and data was still being printing, I decided to change the toner cartridge. Now the pages are clean and white and all the lights function properly. Most cartridges that are running on empty don't print any data at all or at least print the data at the top of the page and gradually gets fainter sp? on the page. Who would have thought just by changing the cartridge would solve the problem? So glad that's all it was........wasn't excited about having to buy a new printer.
Jul 22, 2009 | Brother HL 1440 Laser Printer
Alarm light is RED and data light is AMBER - both are on permanently
This means toner is empty. This condition was probably preceded by a period of "toner low" indications, data- and alarm LEDs blinking shortly every fifth second or so (maybe you never noticed that). Replace toner cassette and it should work normally.
Jun 02, 2009 | Brother HL 1440 Laser Printer
We have a Brother H 1240 Laser printer. The alarm and data are blinking and it will not print. I have tried to reset with no results. Can you tell me what to do?
generally, if the alarm data are blinking every 5 seconds, that indicates the toner is low.
there are no other possible errors. may be your toner is completely empty as well. are the other 2 lights blinking or on?
Apr 17, 2009 | Office Equipment & Supplies
Drum light on Ready light on Alarm light on Data light on
Alarm and Data lights on together is from low toner. If shaking of the toner cartridge is not helping, change the toner.
Drum light is usually on because of the print counter. If the print quality goes really bad, change the drum and reset the counter by holding the front button wile the front cover is open till all lights come on. Release the button and close the cover.
If just Data light is on, check the print ques, some jobs might got stuck there.
Apr 28, 2008 | Brother Office Equipment & Supplies
Printer won't print
According to the operation manual: If alarm light and data light blink every 5 seconds- TONER LOW (purchase more toner and have it ready when the 'toner empty' is indicated). If alarm light and data light stay lit- TONER EMPTY (replace toner cartrige with new one).
Apr 21, 2008 | Brother HL 1440 Laser Printer
Brother HL-1440
(blinking every 5 seconds) Toner Low Indicates that the toner cartridge is nearly empty. Purchase a new toner and have it ready for when Toner Empty is indicated. (solid) Toner Empty Replace the toner cartridge with a new one. User's Manual is available at the following location: http://www.brother-usa.com/Data/Documentation/Printer/User/UM_HL1440_1450_1470N.pdf Hope this helps.
Aug 22, 2007 | Brother HL 1440 Laser Printer
Brother HL-1440/ flashing alarm light and flashing yellow data light
Brother HL 1440 Laser Printer Logo
75 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
