Question about Whirlpool Refrigerators
Whirlpool Side by Side - Overheating
The dividing section of our side by side (the part that separates the freezer from the refrigerator) is very very hot to the touch where the doors rest. The walls on the inside do not feel hot. What could be causing this?
  • pwilkinson Oct 14, 2008
    It may be normal, but burning and I mean burning hot?
  • deborah5960 Apr 10, 2009
    The strips on the inside of the door panels get really hot, I never noticed this before. Is there something wrong here?
  • 943 Answers
HI thanks for your question. the heat between the two doors is normal. its heated there to stop moisture, from hitting a cold surface , and turning to water, so its normal. but pull fridge away from the wall. remove the back panel by the compressor. clean all coils. thanks the appliance doc. please rate my answer. thanks
Posted on Oct 13, 2008
  • john gagnon
    john gagnon Oct 14, 2008
    HI is the freezerok is it cold freezer cold. no strange noises.i cant tell how warm it is im not there. but it does get very warm
  • john gagnon
    you see the hot freon lines run through there to help cool the refrigerant so if the coils at the back are dirty, then the freon gas gets hotter and hotter, so this is why its so important to have clean coils . thanks the appliance doc please rate my answer. thanks
Overheating
The fan you should be checking is behind unit , under a cardboard cover , its the condensor fan motor, desined to disapate heat in that section.
Mar 30, 2014 | Kenmore 53642 / 53644 Side by Side...
My whirlpool is over heating its a side by side, the piece tht divides freezer from fridge is very hot
Here is a tip that I wrote about the reasons why the sides and/or seals couldbe getting hot on your refrigerator.
RefrigeratorTrouble The Outside of Refrigerator Hot
heatman101
Aug 26, 2011 | Whirlpool GS5SHAXN Side by Side...
How do you adjust freezer basket dividers?
We have a similar, though not identical Maytag/Whirlpool refrigerator with bottom freezer. My comments refer to our specific freezer, it is possible that there is some variance in the freezer baskets. Although it LOOKS like you ought to be able to adjust the divider from side to side, with our basket, you CANNOT. the key is to look at the spacing of the wire pieces that make up the basket body. On ours, the spacing at the center, where the divider is factory mounted, is wider than all the adjacent wire pieces. This means that in locations other than the center, the divider does not fit. We just removed the divider to give more flexible placement of items. To remove the divider I suggest first pulling the entire basket out of the freezer. Take your food out so you can turn the basket sideways, and you will see the clip mechanism that is built-in to the divider itself. You need to use a flat screwdriver or similar tool to flex the inner part of the clip back and then wiggle the divider until it pops free of the basket. Repeat process on the other end of the divider.
Aug 10, 2010 | Whirlpool GX5FHTXTS Stainless Steel Bottom...
Whirlpool Side by Side: Freezer freezes refrig doesn't cool.
check for a blockage. There is only one cooling section, divided by airflow for freezer / fridge.
Perhaps something sticky is in the vents, or the freezer section has poor airflow, resulting in ice formation.
Unplug the unit for several hours, clean out vents, and make sure freezer section has good airflow from the vents.
Aug 30, 2009 | Whirlpool GS6NBEXR Side by Side...
Vertical divider separating the refrigerator section from the freezer section is extremely hot to the touch on the exterior surface. So, hot it almost burns your hand. What could this be and how would I...
The fan behind the fridge at the bottom which cools the compressor , is not turning . Remove the back panel covering the compressor and see if something is blocking the blade . If not , motor is bad , so put a small fan there to keep the coils and compressor cool until you can get a new motor .
Aug 09, 2009 | GE Monogram ZISS420NRSS 42" Built-In...
Frig not very cold & metal between freezer and frig gets hot
Poor cooling and a hot divider mean that air is not moving effectively over the condenser coils under the fridge. Check to see if the fan is blowing under there while the compressor is running. If not, then the condenser fan has failed and needs to be replaced. If it is, then use a vacuum with a long nozzle to give it a good cleaning under there.
Jul 20, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Freezer running, ice maker not producing, hot in middle divder.
The dividing section should be warm, to keep unit from sweating. (by design). Cleaning under the refrigerator was what cooled it down. You cleaned the condenser. The condenser allows the refrigerent to cool down. When it was dirty, the condenser could not get enough air to cool down.
Mar 14, 2009 | Kenmore 57029 Side by Side Refrigerator
No ice cubes
your freezer has to be below32 degrees to make ice,can you tell me if the freezer and frig are working ok?mike
Sep 12, 2008 | Whirlpool ED2FHEXN Side by Side...
Whirlpool Side by Side Refrigerator is turning on and off not getting cold at all. Freezer section barely cool and the vents during the times its on barely puts out air
it sounds like a bad:
  • start switch (on the side of the compressor) or
compressor itself
  • the start switch clicks  off usually when the compressor is pulling too many amps or the compressor is overheating. if the compressor is not even running then its probably not overheating.
so either the compressor is pulling too many amps (bad compressor) or the start switch is bad and cannot handle the amps required to start the compressor.
Jul 18, 2008 | Whirlpool Refrigerators
Defrost side by side fridge
no you can not. there are no separate defrost control for freezer and fridge. the evaporator is located in the freezer section and it is supposed to defrost automatically. what is the problem in the first place?
Feb 08, 2008 | Whirlpool GS6NBEXR Side by Side...
Refrigerators Logo
259 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
