Question about Indesit 24 in. D63S Free-standing Dishwasher
Fitting instructions for indsit built-in fridge freezer
Have a cabinet unit with a door fitted with large hinges. Trying to mount the fridge freezer inside results in side of appliance being scraped by the hinges - they are too big. Rang for instructions and pathetic photocopy arrived, so dark we can hardly see the picture and the instructions are in Italian! We have worked out how the appliance doors fit to the cabinet doors at the opening edge but cannot fathom how the cabinet hinge edge fits either to the cabinet or to the door of the appliance. Any clues would be very gratefully received!
Jane
  • 183 Answers
SOURCE: Dsihwasher Door adjustment
Turn the spring tension screw anti clockwise to reduce the spring strength Regards Engineer
Posted on Aug 05, 2007
markevans
  • 148 Answers
SOURCE: indesit d61 dishwasher
contact parts dept for unit. check on line. should be easy to get.
good luck
mark
Posted on Dec 28, 2007
SOURCE: Broken door handle Indesit dishwasher DG 6100
broken door handle solution
Posted on Mar 07, 2008
IFIXALL
  • 868 Answers
SOURCE: rubber door seal problems
Try gorilla glue ,it needs to be wet with water to be its strongest.Please rate this .Thanx!
Posted on Jun 05, 2008
SOURCE: Indesit D61 dishwaher
I've had this problem when the sprayers are partially blocked, might be worth checking them if you have this problem, tweezers can be helpful for removing bits of rice or whatever may be causing the block.
Posted on Jun 21, 2010
How do I replace the bottom socket where the door hinge slides in
I assume you mean the hinge that is on the cabinet and not the door? If its the door part that has failed, you will need to get a new door. If its the cabinet hinge, some of these are screwed onto the cabinet from underneath the fridge. Others however, are mounted inside the cabinet and are not really designed for replacement. Ive fixed a few over the years on different brands where the plastic hinge has broken but it can be a bit messy. The cabinet needs to be carefully peeled or bent back on the bottom corner of the fridge to access where the hinge is mounted. Unscrew the hinge and if you are lucky, the Manufacturer has these as a spare part. If not, the only way is to go to a hardware or cabinet parts store to try and source something that will suffice. Do NOT be tempted to put a normal gate or door hinge onto the fridge door and screw it onto the cabinet. Inside the cabinet especially around the edges are whats called "mullion heater" pipes or in older fridges, mullion elements. If you screw through a pipe, you will lose the gas and fridge will be shot. If you screw through an electrical mullion heater, there is a danger of electrocution.
Dec 23, 2014 | Dometic RM2852 Refrigerator
Proline fridge
Do not tighten down the hinges on the top of the unit, until it is just where you want it. They have a very large range of movement to allow for the potential of a refer box becoming out of square.
When you got what you like, then crunch down on the screws on the top of the unit.
kindly,
Jim
Jan 13, 2014 | Freezers
The top door is rusted out where the hinge fits. I want to patch it up to use in my shop. I tryed mounting some flat type door hinges but it don't work well
without knowing the refrigerator its a tough one, but refrigerator hinges are designed to allow the magnetic door seal to seal properly, flat door hinges typically not a good choice for this application
  • Either pop rivet some new metal plate to replace the rusted area and use existing hinge
  • try get replacement door from used refrigerator or refrigerator recycle place.
  • buy new/used fridge from kijiji :)
Aug 24, 2011 | Kenmore Top Freezer Refrigerator
How to remove doors of a whirlpool 6vmw47 top mount fridge/freezer
Hello Hicherringto,
I understand that you would like instructions on how to remove the doors on your fridge. Most common on top mount freezers/fridges you need to start at the top and work your way down.
1. Locate the freezer hinge top part where the door swings.
2. Remove the plastic cover over the henge. (top of the box if covered)
3. Remove the screws holding the henge in place.
4. Lift up on the henge
5. Open the freezer door and lift up (the door should lift off the bottom pin)
6. Open the Fridge door and remove the screws from the hinge that the freezer door sat on
7. Remove the hinge from the fridge door by lifting up
8. Open and lift up on the fridge door
9.Reinstall in reverse
That is the easiest way to remove the doors on a top mount freezer fridge. Note that when you reinstall the doors you will have to adjust the hinges so that the seals seal properly. The hinges have enough of a grove that you use them to adjust the doors.
Thank you for choosing FIxYa.com
Justin
Apr 16, 2011 | Whirlpool Refrigerators
Freezer door opens easily
The freezer door has a rubber gasket fitted with magnet beading. In case the gasket is torn or the magnet strip is missing due to continuous use the door does not close. Just replace the gasket and you will see that the door does not open unless you physically open it.
Jul 13, 2009 | Refrigerators
Freezer door hard to close
Any adjustment is at the hinge, you probably find that you have fitted it too close and it is pinching the gasket in the corner. Tilting the fridge back can help, but the doors must be able to swing closed freely first. This can be done by adjusting the footing screws below the front of the fridge.
Mar 23, 2009 | Amana ATB1832AR Top Freezer Refrigerator
Fitting an integrated fridge freezer!
Hi Gareth. I fitted a door to my Hotpoint hsz2321L today. I used self tapping screws through the brackets into the fridge door sides. Looking at the old fridge that came out showed that this was the method used previously. No seal is broken and so the fridge is working perfectly. I do have an issue re-fitting the door onto the new fridge though. The pivot hinge on my fridge doesnt give enough clearance and so it catches on the unit at the side of it. The old fridge (a Bosch) cad cabinet hinges that would sort of concertina out to give clearence. Anyway, good luck.
Nov 23, 2008 | GE Profile GCG1700LII 15" Built-In Trash...
The freezer door on our GE side by side fridge does not shut tightly in the center of the door causing a frost and ice build-up on the outside of the door, ( in the inside edges. We have been told that...
There are ways to adjust the hinges, and loosening the screws on the plastic door liner will allow you to "warp" to door a little bit in an effort to get it to line up flat and square to the opening. Sometimes the gasket gets folded up on the hinge side and won't let the door close properly. If you try these adjustments and the door just can't be fitted nicely, you have a serious ploblem. Use something straight to see if the cabinet is warped or if it is the door that is warped.
Jul 23, 2008 | GE Refrigerators
Freezer door misalignment on ARB8057CSL
Before adjusting hinges you need to take a good look across the door from the side to make sure the door is not warped rather than the hinge misaligned. Cannot give much info on hinges but most do not give much adjustment and most can be accessed it is possible that one of the fixings is loose. The other possibility is that the seal is preventing the door from closing, although it does sound as though it is the top hinge not pulled towards the cabinet properly. Sorry to be vague. Hope this is of some help.
Sep 11, 2007 | Amana ARB8057CSL Bottom Freezer...
Indesit 24 in. D63S Free-standing Dishwasher Logo
508 people viewed this question
Top Indesit Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Eric Taylor
Are you an Indesit Dishwasher Expert? Answer questions, earn points and help others
