Question about HP DeskJet 932c InkJet Printer
Color Printing I have an HP 932C printer. I cannot get the printer to print color even though I have installed full cartridgesn00
    Sergeant:
  • 352 Answers
Try updating your printer drivers:
Create a new folder on your desktop and name it newhpdrivers(substitute your manufacturer in new name). Un-intall printer and printer software completely. Go to manufacturers website and navigate to their drivers/downloads or support menu. Select your model, choose the relevant software and download to the new folder you created on your desktop. Power down your computer. Reconnect the printer to the computer and turn printer on. Power on pc. Windows will detect new hardware and ask if you have the manufacturers install cd or a location to check for install files. Direct the wizard to your new software, follow the rest of the setup instructions and your done
anaanymous
Posted on Oct 13, 2008
My HP Deskjet 5650 will not print in color even though i have installed a new cartridge yet the test page is in color??
Just check your printing property and choose color print and apply the settings and then ok.
Good Luck
Feb 26, 2011 | HP DeskJet 5650 InkJet Printer
Color cartridge runs out even though I'm only printing b&w typed scripts. Any way to shut it off? Only have use for color printing once in a blue moon Hewlett Packard HP DeskJet Printer #932C
Even though you print a b/w document... unless you say 'black cartridge only' in your printing preferences, all the colors get used.
Find 'black cartridge only' in your printing preferences, or 'print in greyscale' and then print your document. You must specify this for your printer to know that it must use the black only.
Jul 23, 2010 | HP DeskJet 932c InkJet Printer
I have just installed a new color cartridge into my HP Deskjet 932C. The only colors printing is pink. What can I do to solve this problem?
will you get to change the print color and by doing that you have look for the ink then when you fing go get ride of and put now one or I get any other way let me thing..
Apr 22, 2010 | HP DeskJet 932c InkJet Printer
I have an Hp deskjet 932C and it is printing VERY slow (a page every 6 or 7 minutes). It is also printing only in blue. I have changed both the color and the black ink, and I don't know what to do. Can...
I use a small diameter silicone tube tocarefully "prime" stubborn new carts by sucking a drop of each color ink out ofthe tiny print holes in the printhead part of the cart. Ink can dry at the headand since these carts work by electrical excitation, there needs to be liquidof each color at the holes. Slap a drop of water with your finger on the holesto start easy hesitant ones. Do not get the contacts wet. Slow printing can be port sharing or software conflicts, so try switching ports or switch from serial LPT1 cable to USB.
Apr 16, 2010 | HP DeskJet 932c InkJet Printer
My printer has an almost full black cartridge but will not print.
Check the ink lines, the printer head might be clogged, If thats not fixing anything then check your printer settings on the computer and remove the color option. Changing it to black and white can somtimes just be from color, not just black.
May 31, 2009 | HP DeskJet 932c InkJet Printer
Slow printing
Even though the printer doesn't call for new ink, remove or replace the color cartridge. First I removed the color and the test page printed at full speed. I then put in a new color cartridge and it again worked full speed. I believe the problem was somewhere in the half used color cartridge. Hope this solves your problem.
Jan 26, 2009 | HP PhotoSmart 7760 InkJet Printer
Not printing color
Loks like there is a "well" under the "docked" position of the heads (at the right end of the unit, facing it - under the control buttons.) In my unit, ink had built up in this well to the point that some of the mechanical bits were scraping the top of the built-up ink pile. After I carefully removed about two TootsieRoll's-worth of old dried ink with a long scewdriver (using a flashlight to illuminate the area), the color printing seemed to be doing better. Can't tell yet if this has completely resolved the problem, as I have not yet printed enough pages to prove the point...
Nov 05, 2007 | HP DeskJet 932c InkJet Printer
HP DeskJet 932c InkJet Printer Logo
65 people viewed this question
Ben Johnson
