Question about Kenmore 24 in. 15932 Built-in Dishwasher
Kenmore built in dishwasher~2001 model year ,noisey when running.
When D/W is running ,it has a whirring noise to it. Cleaned out the inlet to pump and found 3 peices of glass ,a nail ,and a plastic bread tie just in front of grinder. Does not seem to be anything else further inside using a small mirror. With inlet cleaned out ,problem still exists. Any thoughts on this .It did not do this a month ago. It came on gradually. It was quiet when running before. At 7 years old, what is a dishwashers lifespan? No preveous problems with this unit. Pump area was in good condition ,with no food build up anywhere.Cleans the dishes fine. I am leaning toward a bearing either in the motor,or the pump. But there is no leaking at all. I did not do an amp reading to see what kind of amperage it is drawing. What do you think?
  • 943 Answers
HI remove the spray tube. remove top cover. look inside that could be a broken piece. this patr can break with pieces of glass going through it. thanks
Posted on Oct 13, 2008
In regards to the 1998 Jag with the whirring noise
Posssible power steering pump noisey. have a shop listen to the noise you say you have.
Aug 28, 2012 | 1998 Jaguar XK8
My Kenmore dishwasher is making a grinding noise during the wash cycle
see this causes:
Water-inlet valve
test the inlet valve for defective and replace
Motor
bearing worn replace
Heater fan
bearing worn, replalce
Pump open the pump and take out the sediment, or debris inside, or replace.
Jun 18, 2012 | Kenmore Dishwashers
Kenmore 587-1519 dishwasher 5 years old just started making a squealing noise during certain times on any wash cycle. Noise is coming from under the tub.
Sounds like something is stuck in the pump. Your pump propeller may be going out causing strain on the windings of the pump. If you have anymore questions please comment me back.
Jul 28, 2011 | Kenmore 24 in. 15199 / 15194 / 15192...
Dishwasher was giving off a whining/grinding noise while cleaning. Now it barely draws any water in to start the cycle and will not start washing at all...only a humming noise
Have you checked that the filters on the hose inlets are clear? Turn off water and undo hose to check, there is a small filter in the inlet. Have you checked that the outlet hose and trap is clear and that it can pump the water out? Have you cleaned all filters? The noise could be the pump blocked or unable to empty.
Jan 25, 2011 | Whirlpool 24 in. DU1148XTP Built-in...
Dishwasher will not drain.
When you start that model, it is supposed to run the drain pump for 90 seconds...i'd suspect, since it's noisey on startup and not draining, that you probably have something stuck in your drain pump (food debris), or possibly the pump is faulty. Remove the pump from under the dishwasher, and check for debris.
Mar 29, 2010 | Frigidaire 24 in. FDBB944C Built-in...
Dishwasher was making whirliing noise during wash, now no wash, only fill and drain
there is a #10 torx screw holding that cover down.do not drill it out. after you take it off you can tell if the chopper is broken.be careful for broken glass.
Oct 17, 2008 | Kenmore 24 in. 15932 Built-in Dishwasher
Kenmore ultra wash 665.16761690
If it is not overfilling, and then leaking, the whirring noise can be a defective water inlet valve, that stays stuck on open, see here : It's overfilling
If it is not overfilling, the two problems may be unrelated, and the noise can be froma foreign object inside the object trap.
See here about leaks and noise
It's noisy
It leaks
Oct 08, 2008 | Kenmore 16919 Built-in Dishwasher
Whining noise with Kenmore 16032 dishwasher
I had a similar issue, I removed the lower spray arm (had to hold center plastic tab with pliers and then unscrewed and lifted up the arm). Then I removed the cover with the screen filter(4 screws) and then removed the top half of the stainless chopper housing (1 screw). Found that things like cherry pits, elastic bands, bread plastic ties had blocked the water inlet to the chopper and the area around the chopper blade. Cleaned it all up, reassembled and machine works great! Mine was so blocked that I was hardly getting any water pressure to the upper rack.
Mar 11, 2008 | Kenmore 24 in. 16032 Built-in Dishwasher
Kenmore 24 in. 15932 Built-in Dishwasher Logo
184 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
vince
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
