Question about Philips 55PP9401 55" Rear Projection Television
PHILLIPS 559401 REAR PROJECTION TV
THANKS FOR THE TIPS. WHEN I TURN IT ON FOR 2 MINUTES AND THEN TURN OFF, ONLY THING I SEE OR HEAR IS THE SOUND OF THE AUDIO COMING ON, BUT NO PICTURE OR VISUALS.
THANKS AGAIN
  • 38 Answers
Ok the problem u have is that u need to have a scope and a volt meter to test the circuits what i would do is check and see if u have a 130 v on the horiza output transistor first. but if u dont have any meters there is nothing u can do to fix the problem. and just rember that phillips allwas wonts u to buy the board that is y it is not cheep to repair a magnavox or phillips sometimes u can buy another tv lot cheaper. i hope this help some what marty.
Posted on Oct 13, 2008
Have an older model philips(1995)rear projection.the power light comes on green,i hear sound from the speakers,but the screen does absolutely nothing.i took the cover off and can see the lamps...
Ur tv projection lamp,when was the last time you replaced the projection lamp?Tv projection lamp was replaced last 1 1/2 or 2 years ago.The tv been on and used 4 or 5 hours a day.The tv projection lamp life it over.Require a new projection lamp.
Aug 18, 2010 | Philips Magnavox 9P6034C 60" Rear...
Phillips hdtv model 30pw9110d/37 won't turn on
Common short the cover cap over the video & sound boards short out if you remove it the cap only (shield metal) it usually will fix this
Apr 28, 2009 | Mitsubishi WT-46805 46" Rear Projection...
SET WON'T POWER UP
i hate to tell u but maganvox bigscren are not ment to be repaired so now i said that i need the model number on the tv to help u but most all magbavox phillips and sylvania tvs most of them are big screens u have to buy the hole board from magnavox and it cost as much as the tv did. but i will try and hp u if u get me the model number and i need to know if u turn the set on and wait 2 mins and trun it off do u see and thing on u screen at all please let me know marty
Oct 13, 2008 | Philips 55PP9401 55" Rear Projection...
TV wont come on anymore
Common problem. Check the site www.tvrepairkits.com. They should have a kit to fix it.
Oct 05, 2008 | Philips Magnavox 9P6034C 60" Rear...
Picture/sound goes out after 10 minutes of TV use
Rear projection hdtv, most likely damaged tubes. Don't repair this by your self get a tv repair man to do it before you injure your self.
Jun 24, 2008 | Pioneer SD-582HD5 58" Rear Projection...
Phillips 60pp935217
I have a phillips HDTV monitor model 60pp935217, i don't get an hd picture but i do have sound. Please help.
Apr 08, 2008 | Philips 60PP9352 60" Rear Projection...
TV turns itself off after a few seconds, no picture at all
I had a similar problem with my Phillips 42 in. LCD HD TV.
Here's the problem. The Power Supply Board. I opened my TV up(warranty was up of course) and found several bad capacitors. Phillips and several other companies were sold capacitors that although were highly rated failed within 5 years because of a lack of preservatives. All sorts of electronic equipment is now being effected due to these defective capacitors.
Solutions?
1. Take it in and have it fixed
2. Open it up, check the board for faulty capacitors(bulged or leaking) Buy a new Power supply board and install it.
3. Remove PSB, remove faulty capacitors and replace with compatible new ones.
Hope this helps
Mar 28, 2008 | Samsung HLP4663W 46" Rear Projection HDTV
No picture shows
HI THERE, I HAVE A PHILLIPS 42 INCH PLASMA SCREEN TV ITS ABOUT 2 YEARS OLD THE SOUND IS PERFECT BUT THE PICTURE IS DEAD MODEL NO IS 42PF55200/10 I HAVE HAD IT GIVEN TO ME TO SEE IF I CAN REPAIR IT BUT AT THE MOMENT NO SUCH LUCK THANKS JOHN
Dec 30, 2007 | Pioneer PRO-1009W 57" Rear Projection...
Trouble w/ my Phillips 50P8341 50 IN. HELP!!!
there is most likely a prob. with the keybd. switches all need to be replaced at the same time.
Aug 22, 2007 | Philips 50P8341 50" Rear Projection...
Philips 55PP9401 55" Rear Projection Television Logo
85 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
