Back to:
Tags:
IBM Blade Center HS40 - Heat Sink Retention Module
IBM blade HS40
By maartenw - usenet poster
Dear All,
anyone has experience installing FreeBSD-5.3 on to IBM Blade HS40 ?
I have difficulty when installed FreeBSD-5.3 on to IBM Blade server HS40,
the keyboard doesnt want to work when arrive on installation menu.
from IBM blade HS40 documentation:
"Although the keyboard that is attached to the BladeCenter is a PS/2 style
keyboard, communication with it is through the Universal Serial Bus (USB)"
best regards,
-dikshie-
mailing list
To unsubscribe, send any mail to ""
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on May 27, 2006
Not Rated (0)
Cornish
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
On Tue, 9 Nov 2004 21:04:06 -0800, Brooks Davis
thanks it works well. FreeBSD-5.3-RELEASE can be installed well on to
IBM Blade HS40.
But I face another problem. If I reboot the HS40 I have entered onto
qlogic bios. if I dont
enter onto qlogic bios device then the HS40 will hang on probing isp
devices after reboot.
with best regards,
-dikshie-
mailing list
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on IBM blade HS40:
I don't want to Accept this solution
Solution #2
Not Rated (0)
Kim1
Rating: 0%, 0 votes
--xjyYRNSh/RebjC6o
Content-Type: text/plain; charset=us-ascii
Content-Disposition: inline
Content-Transfer-Encoding: quoted-printable
=46rom the eratta:
(31 Oct 2004, updated on 5 Nov 2004) For FreeBSD/i386 and FreeBSD/amd64,
when installing FreeBSD 5.3 using an USB keyboard the keyboard will stop
working once the kernel boots, because a PS/2 keyboard is always
considered to be attached. As a workaround, select ``Escape to loader
prompt'' in the boot loader menu and enter the following lines at the
prompt:
set hint.atkbd.0.flags=3D"0x1"
boot
Note that if you use the boot floppies, this is set by default.
After the installation, add the following line to /boot/loader.conf:
-- Brooks
--=20
Any statement of the form "X is the one, true Y" is FALSE.
PGP fingerprint 655D 519C 26A7 82E7 2529 9BF0 5D8E 8BE9 F238 1AD4
--xjyYRNSh/RebjC6o
Content-Type: application/pgp-signature
BEGIN PGP SIGNATURE
Version: GnuPG v1.2.1 (GNU/Linux)
iD8DBQFBkaFFXY6L6fI4GtQRAof5AJ4i04NJFqNUjUvrFWL/83QMvgmdEQCgpvhY
RHHlDlX3zQHVZvKRD4Z9HEo=
=ruKd
END PGP SIGNATURE
--xjyYRNSh/RebjC6o--
Thank You!
Can you Help with these System Cooling problems?
System Cooling
i am tryin to install microsoft office but the system...
System Cooling
n?o consigo configurar o outlook no meu pc atravez do meu...
System Cooling
i face the problem about driver bcos my driver are out of...
System Cooling
I don't think I'm in the right place, since my problem is...
System Cooling
Ac only works for a minute or so then goes off. Now when I...
Loading problems.
Repair Service
Find System Cooling Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
