Question about HP Office Equipment & Supplies
How to change black color inkonHp2175all in one
    Novelist:
  • 180 Answers
Supported HP ink cartridge part numbers The HP PSC 2100, 2170, and 2200 all-in-one series products use the ink cartridges listed in the table below. The HP 58 tri-color photo ink cartridge replaces the black ink cartridge for six-ink photo printing. Ink cartridges Part number HP 56 black ink cartridge (19 ml) C6656A HP 57 tri-color ink cartridge (17 ml) C6657A HP 58 tri-color photo cartridge* (17 ml) C6658A HP 27 low capacity black ink cartridge (10 ml) C8727A HP 28 low capacity tri-color ink cartridge (8 ml) C8728A * Replaces the black ink cartridge for six ink photo printing and includes cartridge holder. Replacing the ink cartridges The power must be turned ON to the all-in-one or the print carriage will not come to the center.
  1. Locate and raise the print cartridge access door on the front of the unit, just above the output tray. The print cartridge carriage will move into the middle of the access area. Figure 1: Raising the front access door and the ink cartridge latches How  to change  - c00224418.jpg
  2. Press down lightly on the top of the ink cartridge latch of the ink cartridge to be replaced and then pull the lower section of the latch toward you to unlatch the ink cartridge.
  3. Grasping the sides of the ink cartridge, pull the cartridge toward you to remove it as shown in Figure 2. Figure 2: Removing the cartridge after raising the latch
  4. Remove the replacement cartridge from its packaging, and touching only the black plastic, gently remove any tape covering the nozzles. Do not touch the gold-colored contacts. Figure 3: Removing the protective tape c00224420.jpg
  5. Holding the ink cartridge with the printed label up, slide the cartridges one at a time into the print carriage as shown in Figure 4. The black ink cartridge (HP 56 or HP 27) goes on the right side (with the gray latch) and the tri-color cartridge (HP 57 or HP 28) goes on the left side (with the blue latch). If the optional photo cartridge (HP 58) is installed for six-ink photo printing, it is installed in place of the black ink cartridge. Figure 4: Inserting the cartridge c00224421.jpg
  6. Place your hand on the latch as shown in Figure 5, with the thumb pulling the end of the latch toward you. While holding the end of the latch out, press down on the top of the latch until it stops and then release the lower portion of the latch with your thumb so that it catches under the tabs. Do not force the latches into place or damage to the unit might occur. Close the all-in-one after latching the ink cartridges in place. Figure 5: Latching the ink cartridges in placHow to change - c00224422.jpgsrc="http://i.fixya.net/uploads/images/c00224422.jpg" alt="c00224422.jpg" class="h_mi" />
  7. Close the print cartridge access door.
  8. A message will appear in the front panel display requesting that the ink cartridges be aligned. Press ENTER on the front panel to start the cartridge alignment. Two pages will print. Following the instructions printed on the second page, place the first page on the scanner glass in the lower-right corner and then press ENTER to finish aligning the cartridges. Remove the page from the scanner glass when complete.
Storing the option photo printing cartridge while not in use The optional photo print cartridge (HP 58) that may be purchased separately for six-ink photo printing includes an ink cartridge protector. The protector is designed to keep the photo cartridge from drying out when it is not in use and for holding and protecting the black cartridge when the photo cartridge is in use.
  • To insert a cartridge into the protector, slide it into the protector at a slight angle until it snaps in place.
  • To remove a cartridge from the protector, push down and back on the top of the protector to release the cartridge and then slide the cartridge out of the protector.
Figure 6: Inserting and removing ink cartridges from the ink How to change - c00224423.jpgtector c00224423.jpg Fixing error messages that appear after changing a cartridge After inserting the cartridge, one of the following messages appears:
  • Check the black (or color) cartridge
  • Replace the black (or color) cartridge
  • The wrong black (or color) cartridge is installed
These messages indicate that the ink cartridge is not making good electrical contact, is bad, or is the wrong cartridge. Complete the following steps to diagnose and correct the condition:
  1. Open the front of the unit to access the print cartridges (as shown in Figure 1).
  2. Remove the ink cartridge indicated in the message and inspect it.
  3. Verify that it is the correct part number and if it is, reinsert it.
  4. Close the lid to see if the problem is corrected.
  5. If the message is still displayed after a few seconds, remove the ink cartridge again.
  6. Unplug the power cord from the back of the unit.
  7. Clean the electrical contacts on the ink cartridge with a soft clean cloth, slightly dampened (not wet) with clean water. Each contact is very small and shaped like a rounded square. FiguHow to change - c00224424.jpgg the cartridge contacts c00224424.jpg
  8. Inside the HP all-in-one product, clean the contacts in the print carriage (the cartridge holder) with a clean cotton swab slightly dampened with clean water. Allow them to dry for five minutes before reinserting the cartridge(s) and turniHow to change - c00224425.jpgnter. Figure 8: Contacts to be cleaned c00224425.jpg
  9. If the problem remains, replace the ink cartridge.
  10. If the problem still exists after trying all of the steps above, contact HP for assistance.
Posted on Oct 13, 2008
The ink cartridge holder will not come into the middle so I can open the container to replace the ink cartridge.
Posted on Mar 13, 2009
P50 dose not print black color
You might have to run the head clean more than once - if no black at all is printing.. Alternatively, set out a page of all black (background) and print few pages on high print quality setting.
good luck!
Feb 17, 2015 | Epson P50 Inkjet Printer
Its really not a problem as much as it is a question. I would like to know if I can switch the text color from black to another color to print documents? I am low on black and it is not printing clearly...
Try changing the font color on you word processor software (Microsoft Word) from black to say red ! Select 'all the text', change the color and print it. Should work.
Dec 30, 2010 | HP PhotoSmart C4180 All-in-One Color...
Black and wight picture
The tv have a colors wheel.The tv make humming,buzzing motor loud noises or flickering black and white pictures.The colors wheel is dead,require changing,bcause of the colors wheel axsis rubbing on it sides or worn out,than have black & white pictures.Hire a tv tech, to do the job.Because changing the colors wheel is not easy.Require take out many machanicals parts,before even can change the colors wheel it self.
Sep 01, 2010 | Samsung DLP HL-P5663W 56" TV
My HP Officejet 7410 All-in-One Inkjet Printer is doing the following: 1) It prints in color even when the document is black and white (using up the color ink) 2) It prints much more slowly than it did...
go into your driver and change your color preferences to black and white. that way when you want to print color you actually have to tell it to do so. which will save your color ink, and will print much faster. full color printing of a black and white document uses all ink colors except black to make what is called process black.
Dec 18, 2009 | HP OfficeJet 7410 All-In-One InkJet...
I need to know what buttons to hold down on a riso 390U in order to get a different color ink to print in a drum
That's almost correct. Risos have two kinds of drums: black and color. The black drums have to stay black. If you want to print color you need to a) buy the appropriate color drum or, b) change the color in a color drum you already have. If you change from, say, blue to red, you're going to have purple for a little while. It's not a really efficient way to get things done.
Oct 05, 2009 | Riso RZ390 Duplicator
I have a riso RP3100ui. I am looking to buy a used drum. Currently i use only black ink. I see used drums on ebay and alike but they are colored drums. Can I put a black in cartride in a rp3100 drum and...
No.. A color drum is a color drum. You can change any color drum and re-program it to be a different color but you can't use a black drum for anything else. The RP is a sophisticated machinge and even the card inside the black drum is different. I think it would give you an error at some point.. Besides the fact you'd go through about a half a tube of ink before you got the new color.. I've converted color drums as you say.. even after 5000 sheets of paper I still have the old color on the sides and stuff. My local service shop changed one of my drums to a different color for $175.. I thought it was a good deal after doing it myself once. Helluva mess. You want to use a color drum as black.. Might work..maybe.. but I've never tried it.. If there's a problem with your black drum... buy a color drum and strip it for parts (except the printed circuit board) and get your black drum working.
Jun 25, 2009 | Riso Office Equipment & Supplies
I am out in black
As far as I can tell, your printer model does not support color to black printing. Sorry.
The best I can suggest would be for programs like word or excel, etc.. to change everything that is black, to a dark blue.
Apr 10, 2008 | Computers & Internet
Won't print black
just try with tet page of printer and also reinstall the driver and see. bye
Sep 26, 2007 | Epson Stylus Color 740 InkJet Printer
716 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
