Question about Kenmore Oasis HE 27082 Top Load Washer
Kenmore Oasis washer LD
I Know this is the sign for Long Drain which means that the drain hose is clogged somewere. But I have drained the washer and it started up and again LD Where else can it be clogged?
  • weeha Oct 15, 2008
    We actually found the clog in a rubber hose clamped next to the main drain. Bobby Pin and a coin. I will defiately keep this for the next Clog. Thanks D
    Novelist:
    Champion:
  • 261 Answers
You need to pull the machine out and tilt it back to look at the pump on the right side. Need to remove carefully using a trash bag to contain the water. Then to examine for debris in the impeller. The second part is too remove the washplate by popping the center cover and removing the 7/16 bolt. Then to grasp the basket and lift sharply on it to pop out the washplate enough to remove. In the center you will see some phillips screws to remove, not the position of the pieces and line them up for reference. Next notice the tabs attaching the tub ring to the tub and remove the tub ring after loosing the recirculate hose clipped at the left rear corner. No with some patience the basket will lift out allowing access to a cover held in by two screws. You want to remove and inspect for debris and soda change.
Posted on Oct 15, 2008
We continuosly get an LD code on our Oasis Washer. Hoses are fine and have ran it through the clean cycle several times. any suggestions
LD means long drain ( time ) and is usually attributtable to either a bad water pump, clogged water pump or clogged hose from tub to pump or pump to drain.
Jun 01, 2011 | Washing Machines
Kenmore Oasis Washer won't drain. "Ld" code during
Hi
Error code LD means long drain. This error appears when the washer takes more than 5 minutes to pump out the water till point where pressure switch resets. To resolve the issue you'll need to clean the drain hose, inspect if the drain hose is plugged. If the hose is fine, then remove the front kick panel and access the drain pump and filter, if you are unable to find the pump and filter remove the back panel as well and trace the drain hose to the bottom of the tub. There is a drain filter connected with the drain pump. It usually gets clogged, and needs to be cleaned every 6-8 months or so. The drain filter is a small white filter connected to drain pump with a hose. If it still doesn't work then you'll need to check the connections of the drain pump, check the electrical connections with a multimeter. Hope this helps... Please post back for more information.
Daniel
Nov 26, 2010 | Kenmore 4.5 cu. ft. Oasis Canyon Top Load...
I have an error code that says "LD", what does
The LD stands for Long Drain and it flashes when the water level does not change after the drain pump is on. Check to see if the drain hose or drain pump is clogged or is the drain hose situated too high.
Nov 08, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Have Kenmore elite oasis that is coming with Ld code then F32 which means machine is taking too long to drain. The pump runs fine pumps all the water out. The hose is not clogged water drains freely....
Pressure Switch failure - remove the hose at the top of the machine, and blow in it to clear moisture/buildup.
If not - replace the Pressure switch.
LD = LONG DRAIN
"F21" (AKA SD) is a Long (SLOW) Drain error (LD). If the drain time exceeds 8 minutes this error code will be displayed. In addition, a "SUDS" error may also be displayed. This may be an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
1.First, attempt to unplug the washer for at LEAST 30 minutes to reset the Central Control Unit (CCU). Sometimes this is all that is required to correct momentary glitches with the unit. If the error code returns, proceed to step 2.
2.Check the drain hose to make sure it is not kinked or clogged.
3.Check the electrical connections to the pump and ensure the pump is running.
4.Remove the drain pump filter and check for foreign objects and/or debris.
To check the drain pump, click on the following link for step-by-step instructions
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Aug 02, 2010 | Kenmore Oasis HE 27062 Top Load Washer
Washing machine stops half way thru and flashes code LD?
Long Drain
Ld flashes when the water level does not change after the drain
pump is on.
Is the drain hose clogged?
Is the drain hose height greater than 96′?
Is the pump running? If not, see TEST #7, page 13.
May 06, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
What does the code Ld mean???
Ld flashes when the water level does not change after the drain pump is on. ? Is the drain hose or the drain pump clogged? ? Is the drain hose height greater than 96′?
Apr 26, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
What does LD mean?
LD means long drain. There is a problem with the draining part of the cycle. You might be over sudsing or the drain hose is too low. Let me know if this helps.
Oct 13, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore elite washer problem
you can use a shop wet vac on the drain hose to **** the rest of the water out then you can remove the hoses to check to see if anything is suct in hoses or pump-,mike
Apr 24, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Oasis washer displays code Ld and wont fully drain
LD means long drain. Check to see if there is something clogging your drain hose. If not remove the drain pump from the bottom of the washer tub and clean it out. Also clean the recirculating pump. That should fix it. if not replace the drain pump.
Nov 19, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Ld signal
ld means long drain, could be a bad pump or something stuck in it.also if drain hose is too deep in the drain a syphone can cause this
Jun 22, 2008 | Kenmore Oasis 27042 Top Load Washer
Kenmore Oasis HE 27082 Top Load Washer Logo
121 people viewed this question
Sal De
fordexpert
Robert Rankin
