Question about Frigidaire Dryers
Dryer does not turn on when button is pushed. There is power to the outlet and power going through the cord to the dryer i checked both with a tester. The lightbulb inside the dryer does not come on and i checked that and the bulb is still good. The unit makes no noise and no movement when the button is pushed.
  • 29 Answers
Sounds like an electrical issue. Are you sure the outlet is wired correctly? You need a 120 volt line going to one side of the outlet and another separate (not split off the first line) 120 volt line going to the other side. You also need a neutral line and a ground. You should measure 240 volt from one 120v line to the other.
Posted on Oct 13, 2008
I had an older second hand dryer and about 4 months after we moved into a new appartment it started sparking when I hit the start button. It did not happen every time. The spark came from behind the dryer...
it's not the dryers?change the outlet and the cord.you could have damaged the dryers too.you answered all your own questions,change them out before you have a fire.good luck
Dec 21, 2010 | Frigidaire Electric Dryer
My dryer will run for a while but then it stops. I can still hear the timer ticking and if I push the button again the dryer will run again.
My Best Guess would be a bad power connection, or just a bad connection, A bad timer or Bad Motor
I would ckeck the power cord connections first and even the outlet. Making sure all the wiring is sucure.
Of course make sure you turn off the breaker to the outlet befor serviceing and unplug the machine befor serviceing
Sep 05, 2010 | Amana DLE330RAW Electric Dryer
My GGQ 9800 gas dryer won't start. It was working
Things to check first on a no start dryer.
Check for power at outlet.
Inspect power cord.
When you try to turn it on do you hear anything?
Check the door switch(does it click when pressed in?)
The next item to check and most likely replace on a completely dead dryer with power and a good door switch would be the thermal fuse located inside the cabinet.
Please let me know if I can help with anything else
Apr 08, 2010 | Whirlpool GGQ8831L Gas Dryer
Kenmore Washer Model 417 44052400 will not turn on at all. Only sign of life is a beep when press the reset/cancel button. Any suggestions?
first of all check with an electric meter to see if the proper voltage is going into the dryer from the outlet
If you have proper voltage from the wall outlet (in USA it's mostly 240 volts for a standard full size dryer) then check where the pigtail, cord, goes into the back of the dryer to insure the connections are tight.
If all of the above checks out as good then my first thought would be the start button since the power goes straight from the cord to the start button then proceeds to the dryer components.
Hope this helped
Dave
Mar 18, 2010 | Washing Machines
Dryer will not turn on. Checked outlet with
unplug dryer and take back panel off. plug back in. use caution your working with 220v. get a reading on power cord where it connects to dryer. if your good there look for a micro fuse, two small wires connected to it very small component. sounds like you have a bad power cord or power surge popped micro fuse. good luck and be safe!!
Jan 09, 2010 | Magic Chef CYE3005AYW Electric Dryer
Whirl pool dryer LEC9000PW0 will not turn on
Has a household fuse blown or has a circuit breaker tripped?
There may be 2 household fuses or circuit breakers for the dryer. Make sure both fuses are intact and tight, or that both circuit breakers have not tripped. Replace the fuse(s) or reset the circuit breaker(s). If the problem continues, call an electrician.
Is the correct power supply available? (Electric dryers only)
Electric dryers require 240-volt power supply. Check with a qualified electrician.
Is the dryer door firmly closed?
Your dryer door may not be fully closed. It may look shut, but may not be latched. Push on the door to engage the latch or latches. Some models have an upper and lower latch. Both latches must be secure for the dryer to run.
Was the Start, Push to Start or Hold to Start button firmly pressed?
Large loads may require the Start, Push to Start, or Hold to Start button to be pressed and held for two to five seconds.
Is the Cycle Control knob set on a Sensor Dry or Timed Dry cycle? (on some models)
The Cycle Control knob must be set in a Automatic Dry or AccudryTM or Timed Dry cycle. The dryer will not start if set on the Wrinkle ShieldTM option.
Is Controls Locked status light on? (on some models)
Press and hold the Cycle Signal button for three seconds. This will turn off the Controls Locked feature.
Did you recently install a power supply cord on the dryer? (Electric dryers only)
The power supply cord may be incorrectly installed. If the power cord is incorrectly installed, the dryer may not start or heat. Review the Installation Instructions to check that the power supply cord is properly installed.
Dec 02, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Dryer will not start
Your dryer may not be receiving adequate voltage to start. Make sure your dryer is plugged in. Also, check the circuit breaker panel to make sure all the circuit breakers are in the correct positions. Or check to make sure no fuses in the fuse panel are blown. Try plugging something else into the same outlet. If it won't work either, then there is likely something wrong with the power outlet. Any of these could be the reason power is not getting to your dryer. Also, refrain from using an extension cord to plug your dryer in.
Nov 13, 2008 | Whirlpool GEW9250 Electric Dryer
Dryer shut off towels were not yet dry, turned dial to restart dryer acts as if it isn't getting power I closed door and pushed start button. Nothing! Checked breakers and power cord at outlet all checked...
Hello mdonettaYou said,
Dryer shut off towels were not yet dry, turned dial to restart dryer acts as if it isn't getting power I closed door and pushed start button. Nothing! Checked breakers and power cord at outlet all checked okay. Any ideas.
yes, try unplugging the power cord or turning off the breaker for 5 minutes. Either will due. Some times the system needs to be reset!
If this does not work there are internal fuses that can be replaced!
Let me know how it goes!
Huuum
Sep 19, 2008 | Dryers
Kenmore Dryer
check your breaker first. Then check your power cord and outlet for burns
Jul 08, 2008 | Kenmore Dryers
Maytag dryer wont start
well I hope I solved your washer problem, as for your dryer .Not turning on, if you here nothing at all when you push start,first check the power cord/outlet/breaker.
Jun 23, 2008 | Dryers
Dryers Logo
78 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
