Question about AMS Lutron SFSQ-LF Skylark Slide-to-Off Fan Speed Control and Single-Pole Light
Light switch Installed a new chandelier which works but the switch doesn't turn it off or on
  • 417 Answers
If the previous light worked ok and you didn't touch the wall switch, you must have a faulty connection at the chandelier end, check the connections again. Is there a seperate switch on the chandelier?
Posted on Oct 13, 2008
I installed 2 3 way lighted dimmer switches (DR703PWV) in my Living room Chandelier, and the control for On & Off is working as it is supposed to, but when I try to dim the chandelier flickers from...
Install one dimmer at the load end feeding the light. Install a standard 3way switch at the other end. Make sure the dimmer switch is rated for the type of bulbs in the fixture. ie Led, halogen etc.
Mar 16, 2011 | Pass & Seymour Trademaster 3-Way 15 Amp...
The light in the kitchen doesn't come on. If you hold it sideways, it comes on. The fireplace doesn't come on and there is no crackling sound. Everything else works.
only problem I shared with you is the chandelier... the door, upon opening, turns the chandelier on... you'll see the switch in the hinge area of the door
Jan 02, 2011 | Mattel New Mattel Barbie Townhouse
The townhouse chandelier wont light up
the door opening turns the chandelier on... plus, make sure its plugged in good
Dec 30, 2010 | Mattel New Mattel Barbie Townhouse
Is there a button that has to be pushed in order to turn on the chandelier? My daughter wants it to work and I can't seem to figure it out.
The chandelier only works when you open the front door. Make sure the front door and chandelier are properly secured or the chandelier will not come on. Hope this helps.
Dec 26, 2010 | Mattel New Mattel Barbie Townhouse
I just installed a chandelier. This is a new connection. So I ran a 3 wire from the chanderlier to a new lutron slide dimmer. I then ran a 2 wire from this dimmer to the switch. When I turned the...
Lutron Dimmer manuals
http://www.lutron.com/Service-Support/Technical/InstallationInstructions/Pages/InstallationInstructions.aspx?syst=Dimmers+%26+Switches&prodn=Maestro%C2%AE+dimmer+%26+switch
Lutron manuals show a couple things that might be affecting you lights.
1) Wattage: If you have wrong wattage dimmer
2) Type of light bulb: Dimmers work on different types of bulbs
3) Wiring: You say you got 3 wires going to the chandelier? Why you got 3 wires? Is this a 3 way switch? Are the chandelier bulbs wired separately so you can control groups of bulbs with different switches?
Does the dimmer have 3 screws? A dark-colored screw and 2 brass screws? If so, then that sounds like a 3-way dimmer. A 3-way, is where more than one switch controls the same light.
Does the dimmer have 2 screws? Then that dimmer controls a single circuit. Your black Hot wire from breaker box connects to one screw and the black wire to Load connects to other screw.
A quick glance at Lutron wiring manual shows that Hot and Load wires connect to either screw.
The question is your 3-wires from the chandelier ... does the black Hot wire from breaker arrive in the ceiling box first? Or does it arrive in the wall box first? If your Hot arrives in ceiling box, then the Hot must come down to the switch box and connect to a screw on the dimmer >>> a second wire connects to other screw on dimmer and travels up to the ceiling box where it connects to black wire on chandelier. The white wire on chandelier connects to white Neutral.
4) Dimmer might be bad
Oct 16, 2010 | Lutron #DVW-603PGH-WH 600W White Single...
Hello, All of a sudden my kitchen ceiling lights are acting flakey...here is the problem. There are two ceiling fixtures, both of them were controlled by two separate on/off switches on opposite ends of...
I would suggest you call in an Electrician. It sounds like there is a definate short somewhere and if you don't address the issue immediately, there could be a very real issue of a fire. Please do not put this off as something that may fix it's self. hope this helps.
Oct 12, 2009 | Hunter 52" Ceiling Fan With Light And...
Tried to install a ceiling fan to replace a dimming light chandelier.......light on fan and fan itself works but only by the pull chains....it will not turn off or on by the wall switch that controlled the...
Trip the breaker and verify that the fan/light will not operate. If tripping the breaker kills the circuit and flipping the wall switch would not, the switch is probably bypassed. Place the wall switch to "off" with the breaker tripped to the "off" position as well. Gain access to your wiring connections at the fan. Look for a single (black) wire that is not connected. This should be your hot return from the wall switch Make your fan/light connections to this wire. (Are you sure that the ground wire that you connected is a ground? If it is, it should be bare copper with no insulation). Your white (neutral) connection to the three white wires should be fine. If you don't find a single wire in the ceiling box, call on an electrician. Regards --WoobieDog--
Jul 07, 2009 | Hampton Bay 46056 Callaway II Ceiling Fan
Did I burn out my chandelier?
the watts on the bulb doesnt matter but it sounds like your switch is fried
Jan 04, 2009 | Dryers
AMS Lutron SFSQ-LF Skylark Slide-to-Off Fan Speed Control and Single-Pole Light Logo
133 people viewed this question
Top AMS Electrical Supplies Experts
Craig Butler
Craig Butler
Ottoniel
ashburton
Are you an AMS Electrical Supply Expert? Answer questions, earn points and help others
