Question about HP Computers & Internet
Monitor has dark wavy lines on edges
My HP P1100 19" monitor is about 10 years old and has just developed black wavy lines on the sides of screen. Also, text is a little wavy at edges. I can see whatever is on the screen, but want to know if problem is fixable, or if I need to get a new monitor.
  • Anonymous Feb 24, 2009
    Fix-4U: Your answer was not very informative. What is the cause of the problem, how is it fixed?
    I have the same problem - and yes I will probably get a new monitor. But I would like to know more about this.
    Champion:
  • 293 Answers
Hi...there,
Well... sure it fixable, but it is going to cost you a bundles... Since you own this monitor for about 10 yrs. It's time for you to give yourself a new LCD monitor for the Holidays... :) Have nice day!
Posted on Oct 14, 2008
White line across screen
If your LCD TV or monitor has stopped working, or is displaying one of the following
symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can
examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life
of your monitor or TV by several years.
Take it to a repair shop.
Apr 05, 2014 | Sony 46 KDL46EX523 LCD TV
HP laptop screen is black
A blacked-out screen doesn't necessarily indicate a broken monitor.
If the computer has run out of charge or is in hibernation or sleep mode,
if the screen is too dark, or if the display cable has come disconnected from the motherboard, the screen may appear black or fail to turn on. To fix a blacked-out laptop screen, troubleshoot the screen settings, check the LCD connector and see if the computer is awake and receiving power.
Touch the touchpad or move the external mouse to see if the computer is asleep or hibernating. If the computer fails to respond, press "Enter" on the keyboard. Press the power button if the screen remains black.
Confirm that the power indicator light, found at the front of the computer or above the keyboard, is glowing solid green or blue. Confirm that the power adapter is plugged into the computer and into a wall outlet. Confirm that battery indicator light is glowing solid green or blue. Hold down the "Fn" key. Press the up-arrow to see if the screen brightness increases.
Some computers also use the "F6" or "F7" keys to increase screen brightness.
Hold down the power button for 10 seconds to turn off the laptop.
Remove the AC adapter from the computer, close the screen, and then turn the PC over.
Slide the battery latch to eject the battery. Pull the battery out of its compartment. Turn the computer back over, open the lid, and insert the edge of a flathead screwdriver or other flat, solid object beneath the bezel above the keyboard. Wedge the edge of the keyboard bezel off of the top cover.
Work your way along the edge of the keyboard bezel to loosen it.
Pull the bezel off the laptop.
Trace the cable coming from the laptop screen to the connector found beneath the bezel. Reconnect the display cable to the motherboard if the cable has come loose from the connector. Line up the tabs on the bezel with the slots along the top of the keyboard. Insert the right edge of the bezel into the gap above the keyboard, and then push the bezel back in place. Turn the computer back on. If the laptop screen is still blacked out, connect an external monitor to the video port on the side of the PC to confirm that the video card isn't defective. If the external monitor works, the LCD screen could be broken. If the monitor doesn't work, the motherboard or video card might need to be replaced. Hope this helps
Jan 08, 2013 | HP VM114UA notebook
Display half of screen
screen back light on the other side is busted which need replacement.
Jul 14, 2012 | Computers & Internet
Gateway VX 920 Diamatron monitor has wavy lines at bottom
Since this is a CRT (Cathode Ray Tube) It is no longer cost effective to repair them. Your Tube Driver circuit (internal non-serviceable parts) is starting to fail.
Apr 05, 2010 | Computers & Internet
KDSusa Analog monitor
I would check the video card , then the connector and if the lines are still there , then you need to replace the monitor
Jul 26, 2009 | LG Flatron F700B 17" CRT Monitor
Flickering, jittery image, white horizontal flashing lines
this is real old right
no photo off i messing up, how can we guess, what you see?
amazing....
my guess power pack shot.
i guess you cant barrow a monitor and try that?
2nd guess blind, the back light failing
or is damage if it was hit, the LCD will have damage
gently flex the frame goes nuts, bingo.
Mar 02, 2017 | HP Pavilion F1703 17" LCD Monitor
Vertical gray stripe on left edge, all pics and text gave a blur
any vertical or horizontal line (any color any size) showing stable on the screen that is the hardware damage at the LCD panel back board ( call panel driver board) . it repair complicate but easy to do change LCD panel (common parts). you need find a PC service dealer to do so.
Feb 07, 2009 | Dell E207WFP LCD Monitor
Severe noise on monitor when viewing white area
Although I still have the problem to a slight extent (very slight wavering of the vertical lines going from dark to light or white) reducing the contrast from 100% to 80% seemed to do the trick. Although this monitor is on the way out, it has lasted about 7-8 years now, at least it will keep going for a while.
Dec 29, 2008 | ViewSonic VE150 15" LCD Monitor
A black vertical line on my screen
it risky if you always use your monitor that has a factory defect..i suggest to return to the store for some replacement of your monitor...coz your monitor has a warranty.
Jan 28, 2008 | ViewSonic G810 21" CRT Monitor
Wavy Vertical Line
you have AC ripple getting into your horizontal output. you have a power supply problem in the monitor. take it to get it fixed.
Jun 26, 2006 | Gateway EV 700 17" CRT Monitor
Computers & Internet Logo
425 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
