I turned on my laptop after an hour i turned it off, and it started up ok, just without any picture. The screen is blank, but if I tilt it to the light, I can see everything, but just barely. it's like the brightness has been turned way down, but I've never touched it. I was told it might be the back light that has blown. i've had this similar problem before, but found that it was only because I plugged it into an external screen. but this is no the case.
  • 4,338 Answers
Have you tried tilting the LCD and see if the symptom change?
If tilting the LCD shows good video, then you have a loose or bad LCD cable going to the System board.
If tilting the LCD does not change the symptoms,then it is the "Inverter" board.
The laptop have an "Inverter" board that goes out and causes this problem. It is located just below the screen on most laptops. I usually purchase them from here:
http://www.smartmicrousa.com/
You may have to copy and paste this link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Nashville,TN
Posted on Oct 13, 2008
  • memphis1981 Apr 18, 2013
    I know it's been years, But I totally forgot about this website. Just so you know. The laptop is in full working order. after 3 years of not having a screen, replacing the back light unit, screen ( which was returned) and everything else, I gave up on it and just attached a screen to it. Then 3 years later I decided to upgrade the operating system from Vista to Win7.... and 'as the light shone brightly and the Advent logo staring back at me, I knew I could finally see!' Stupid Window's Vista!!!!!!!!!!!!!!!!!!!!
My screen wont turn on anymore. The machine seems to function properly, but the screen lights up blank. How can i fix this?
If you connect an external monitor to your laptop and the picture is OK, replace the laptop screen.
Jan 23, 2016 | Computers & Internet
Aspire 7250-3821 white screen only
Have you tried with a external monitor, if that works the gfx card is ok and fault lies in a connector that has released from the motherboard. The lcd isn't getting the signal from gfx card wich only can be the connector or the control circuits(matrix circuits) for the display the latter example requires a new screen.
But if the external monitor doesn't show anything it's the graphics card mounted on the motherboard that has given up and that isn't something can be fixed without replacing the motherboard.
Jan 25, 2013 | Computers & Internet
The laptop starts then windows says loading then a blank screen. battery light was orange and after 3 hours plugging it in now it is blue. could it be the battery?
try doing this step.
-turn off the laptop completely
-turn on the computer and go to Safe Mode by tapping on F8 once you press the power button
-once you were able to login to Safemode, click on start>run>type msconfig.
it should show you a picture just like this:
-go to the Startup tab then click on Disable All
-then click on Services tab
-put a check on "hide microsoft services"
-Click Disable All
-Click Apply then OK
-it will prompt a message that says you need you to restart the computer, click restart now
-see if you will be able to login to Windows normally
Mar 17, 2011 | Lenovo IdeaPad S10e Netbook
Logged into laptop but get blank screen
OK thank you for the information, can you connect this via ethernet?.. Hard wire then get into safe mode with networking, so we can get you onto the internet to run some scans? nancie1186@optonline.net
Jul 11, 2010 | Gateway M-7315U Notebook
Back screen (no screen) upon powering my T60 thinkpad
  1. Take out your battery and the power button for about 60secs.
  2. Start the laptop using the Adapter [without the battery]
  3. Lighten up your laptop...remove any external device attached [printer,scanner,pen drives etc.].
  4. It could also be a RAM problem,try changing the RAM if you have two start with one and exchange them.Clean the edges of the RAM where it get fits into the slots and blow some air in the slots to clean it up of any dirt.
After that when the system starts you can do the system restore START--ALL PROGRAMS--ACCESSORIES--SYSTEM TOOLS--SYSTEM RESTORE to restore it back to an earlier date when laptop was ok. THEN LATER ON PUT THE BATTERY BACK IN.
  • Try restarting after an hour gap.
  • If this doesn't solve your problem call the company people.Their might be a Video Card problem or any other internal hardware problem.
Aug 05, 2009 | Lenovo ThinkPad T61 Notebook
Laptop dell inspiron 1545..when I turned it on. the power is working and the dell logo still appeared on the screen but after that, display in the screen remained blank as if it's still reading for windows...
Jul 23, 2009 | Computers & Internet
Blank Screen
it sounds like a malufunctioning screen.. to test try to see if the computer reacts the same with another screen attached to it*if its a laptop connect and external screen to the port and when u start up press f4*
Jul 12, 2009 | Dell Computers & Internet
Computers & Internet Logo
53 people viewed this question
David Payne
David Payne
