Question about Sharp Cameras
Just bought a Sharp VL-ZL at a yard sale. Great price but I'm beginning to see why. First came the 'dew' issue, but I read here what that is and what to try. The next day a new problem occurred, and this one's not only weird, but I can't find anyone online with a similar issue. The cassette door will not stay closed with a tape inserted. Take the tape out and it closes fine. Any thoughts? Thanks.
5 Suggested Answers
t00nz
  • 4738 Answers
SOURCE: Lens cover sticks closed.
If you're careful this problem is a relatively easy fix for many digital cameras. The design of the lens cover mechanism is usually simple and very similar throughout camera brands. Here's an example fix for a Canon A400 with similar problems:
http://camerarepair.blogspot.com/2007/11/repair-of-stuck-lens-covers.html
Posted on Nov 10, 2007
SOURCE: battery compartment
same problem , no solution, i e-mailed like 10 times to buy ine cover lid, i think they re out of business
Posted on Mar 16, 2008
SOURCE: fujifilm s5000 I want to buy a new battery door. Is that possible?
http://shop.thefotogeeks.com/index.asp?PageAction=VIEWPROD&ProdID=4754
Heres your answer.
Posted on Aug 07, 2008
  • 116 Answers
SOURCE: I have a Sharp ViewcamZ VL-Z900. DEW error
Dew has condensed in the camera. Eject the cassette but leave the cassette door open.remove the battery . Borrow a hair drier . set it to optimum temperature(not vey hot but but hot enough to cause discomfort when blown on fingers). direct the hot air through the cassette compartment door for about five minutes. reattach the battery and reinsert the tape.
Good Luck,
Luwangula
Posted on Sep 18, 2009
satavlad
  • 405 Answers
SOURCE: Sharp VL-Z1 will not load the cassette...
Modification is available to fix this problem, contact sharp repair facility.
Posted on Oct 26, 2009
My digital camera wont work and it keep saying DEW. what does that mean? it is a sharp vl-z5 digital camera
I HAVE A VIEWCAM VL-Z7, I STARTED TO CHARGE MY BATERRY TO THIS JUNKY UNIVERSAL CHARGER AND FOR SOME REASON IT TURNED ON BUT 1 MINUTE LATER IT TURNED OFF AND NEVER TURNED ON AGAIN
Dec 11, 2009 | Sharp Viewcam VL-Z1 Mini DV Digital...
"DEW" on the screen
its showing that because it stands for something taht u can read up on in the manual
Oct 06, 2009 | Sharp Viewcam VL-Z1 Mini DV Digital...
Good Luck,
Luwangula
Sep 18, 2009 | Cameras
Bypassing of DEW sensor
there is no way to bypass it, but simple modification is available to correct this problem. contact any sharp authorized repair center.
Sep 13, 2009 | Sharp Viewcam VL-Z1 Mini DV Digital...
Camcorder shows dew all the time
http://ataplow.googlepages.com/sharp-dew-problem just click this link read the instructions carefully and follow them properly to resolve this problem. thanks.
Jan 27, 2009 | Sharp VL-Z5 Mini DV Digital Camcorder
Dew lamp lights up and camera shuts down
Nov 17, 2008 | Sharp Viewcam VL-Z1 Mini DV Digital...
Sharp vl-z8 dew light keeps coming on
It seems that the due detector can suffer from bad soldering or soldering alteration after few months of use.
1. The (ideal but uneasy) solution consist to fix this solder by making a clean new one, I personally did it, and it worked for a few months without a problem anymore ; but then it came back again.
2. The other solution consist in short-circuiting the dew detector to eradicate the problem.
Of course, it will also mean that when real dew will happen you may use the video tape recorder when you shouldn't, but at least you should not see the problem coming back again some months later.
To know more about this dew detector circuit and how to fix it the way you want go there:
a zoomed picture of where to fix the detector can be found here:
http://ataplow.googlepages.com/sharpdew.jpg
Hope this will help as it helped me,
Good luck,
Fabien.
Sep 25, 2008 | Sharp VL-Z800U Mini DV Digital Camcorder
Sharp Viewcam z
either it has moisture in it (let it dry), or the dew sensor is bad and needs to be replaced.
Nov 29, 2007 | Sharp Viewcam VL-Z3U Mini DV Digital...
Dew indicator
look inside the camera to the front.wou will see 2 solder bloba,run a line of solder between them to by pass the dew,it works
Nov 04, 2007 | Sharp Viewcam VL-Z3U Mini DV Digital...
Cameras Logo
21 people viewed this question
Top Sharp Cameras Experts
ray gallant
Are you a Sharp Camera Expert? Answer questions, earn points and help others
