Mitsubishi LT-46151 46 in. HDTV LCD TV Logo
bill brown Posted on Jan 15, 2012
How do u down load patch to try fix green tint on mitsubishi Lt-46151
5 Related Answers
Anonymous
  • 301 Answers
  • Posted on Feb 22, 2008
SOURCE: Mitsubishi WS-65711 green tint only with DVD via Component
there should be a setting in the menu that you need to make sure is set to YpPbPr not RGB if set to RGB it will give you a green pic on the DTV Input.
Anonymous
  • 691 Answers
  • Posted on Jan 19, 2011
SOURCE: Can't get sound out of the LT-46151 - mute is not
check firmware and upgrade if possible
Anonymous
  • Posted on Apr 23, 2011
turned on tv no sound this morning and nothing mute not on worked last night
wcoleman332
  • 23 Answers
  • Posted on Dec 09, 2014
SOURCE: Hello, I have a Mitsubishi LT-46151. When I power the TV ON I'm getting a blue screen and the GREEN power light is flashing. The blue screen continues to show and then the GREEN flashing power light
Hey it sounds like u have did everything, so check and make sure u downloaded the right firmware on a good USB drive such as a 4GB and make sure format it with Fat32 before u download. Have seen that before with jump drive device and follow directions from Mfg website. If does not work then the CPU or Eprom has been corrupted and main board needs replacing.
freetek
Steve Allison
  • 5569 Answers
  • Posted on Jun 04, 2015
SOURCE: LT-46151 mitsubishi tv, Green light flashes, no picture, back light is on, screen is blue.
If you have any later digital camera or phone with a compatible connector and cable, try connecting this first.
The set may be looking at the wrong input for signal.
Using your remote, check the setup menu to ensure that your source (cable, receiver, etc.) hasn't been accidentally changed.
Often, a blue screen means 'no signal.'
My Roku stopped working on my Mitsubishi LT-46151. I switched HDMI ports, but still got nothing. None of the 4 ports will work. Does it sound like a list cause? The Roku works on other TVs, so it it...
Your television hdmi ports are no longer working. You could try to solder new ports onto the board, or you could take it to a specialist in television repair.
2answers
1helpful
2answers
Can't get sound out of the LT-46151 - mute is not on.
Green tint I can't seem to fix
Hopefully someone on here has a manual and can tell you exactly where the tint controls are. Also need to try adjusting the color level, turn it clear down so you have a black and white picture.
Is the picture still green over the screen with the color control
set clear down to black and white? If it does, you might
have an issue with the green gun going out or problem in the
circuitry to it.
By the way, the best way to adjust the picture settings on a
tv are to first turn the color control clear down, then adjust
brightness and contrast for best black and white picture, then
bring up the color level to where it should be and adjust the
tint for best red/green ratio.
Green tint on screen
Is it a green tint at some areas alone, oris the entire image having a green tint? If it is a color patch at the corner or other areas of the screen, in all likelihood it is a degaussing problem. Color patches happen when the TV is moved from one location to another, or if some magnetic source is placed close to a CTV. Did you put a radio or Tape recorder or Walkie talkie toy or any magnetic source near the TV? if yes, remove it. And the automatic Dregaussing circuits in the TV will resolve the problem in a couple of days. But if there is an overall Green tint on the picture, it signifies a problem in the Video output stages, and there is nothing you can do, but call the technician (unless you know solid state servicing?)
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
