Question about Acer Aspire 5100 Notebook
My laptop turns off all of a sudden for no reason
My laptop loses power and turns off
  • 85 Answers
Sorry dear.........i can't understand your language......plz brief again.
Posted on Jan 02, 2009
Did you check your power cord entering your notebooks power supply jack! sometimes the tiny male pin that is inside the notebooks power jack will come out or become loose. The solution to this is either replace the mother board, as most repair centers will recomend or two take the notebook apart to get to the motherboard and solder the pin back on. Note this is not for beginners and you will need someone who can do professional soldering with a strong silver solder. You need to take the power supply housing off and than you can solder the pin in place and replace the housing. The hardest part is breaking down the notebook and putting it back together. But if you lable your parts and screws and do it in a clean work surface with a rubber floor matt under you and maybe a anti-static braclet (as you don't want to short anything out) you should be able to do it.with knownedge of soldering small parts. this is the number one cause for most warranty work done on notebooks and laptops, cause we forget that the power supply is getting pulled on when we use them sitting on our bed or lap and moving around alot. That is why it is a good idea to always use a lapboard of some sort to set your notebook on, plus you want to have air flow under the notebook for the fans intake and exhaust, this will keep it running cooler and faster.
Tip, You should keep your Anti Virus Programs up to date anddefragment your notebook at least once every week or two along with disk cleanup and error checker, By clicking >Start>Programs>Accessories>System Tools>Disk Cleanup, and Disk Defragmenter. Or click "My Computer" Than right click "Drive c" than click "Properties".
A good program to install for free is ccleaner found at, this software is free, with no adware, spyware, etc. it cleans your PC's temp. files and fixes any issues your system may have, Everyone i have seen use the program gets back anywere from 500 MB's to !.5 GB's of disk space back. it is well worth trying. Go to the site and check it out, it explains what you need to know to make an informed desision for your self.
John T.
Posted on Oct 15, 2008
Do you scan for virusses?
Posted on Oct 13, 2008
What are some reasons my 93 cavilier z24 would suddenly lose power. it starts and runs, however it is rough and it struggles to pull it self down the road
Could be a long list of things.
Is the check engine light on ?
Have you checked compression ?
Are all the cylinders firing ?
Oct 28, 2014 | 1993 Chevrolet Cavalier
Turn off Suddenly
Does the battery hold any charge? Also, please check the screw near the video port; is it lose? If it is lose, then please tighten it. For now, if you would move this laptop, please do not touch that area (the video port and its surrounding).
Mar 07, 2014 | Dell Latitude E6510 Laptop
NF210 Will not turn or or indicate rechraging
Sounds like a capacitor may have burned out on the motherboard, and may be related to the power regulator for the battery. The power regulator on laptops is what regulates how/when/if the battery is charged. Either way, your last posting is correct in that the motherboard needs to be replaced to correct a potentially faulty part soldered into the motherboard.
Jul 30, 2012 | Samsung NF210-A02 Netbook
My computer suddenly quit working. The power just went off
The most common reasons for that are
1. power adaptor or battery isn't working - power problem. Some laptops require the battery to be in the machine even when it's running of the adaptor. If it runs out of 'juice' it will just go off suddenly.
2. overheating - It can get full of dust and dander and overheat the cpu which will also cause the machine to go off suddenly. It shuts off to protect the cpu from burning up. Sometimes if they get hot enough it can still take out the cpu... If the cpu fan stops working it will also overheat.
3. Control Panel - Power settings - check to see if there's a timer set to turn it off after so long etc.
Jul 08, 2011 | Fujitsu LifeBook A1110 Notebook
Acer Laptop runs but shuts off suddenly
this is an overheating problem, computer have a thermal protection sensor that senses extreme temp.
i suggest return to your service provider and have them check again, it could probably cause by, the fan isnt plug or there is a lot ob obstruction to exhaust that tned to build up heat around your pc
Aug 03, 2009 | Acer Aspire 5720-6661 Notebook PC
My computer refreshes itself out of nowhere and I lose everything
there is 2 reasons
1- memory problem,change the (Ram)
2-OS , change the windows
Jun 09, 2009 | Sony VAIO Z1RAP1 (PCG-Z1RAP1) PC Notebook
Sony Vaio PCG-6h4l laptop turns off for no reason. While using laptop on batteries it works fine and does not power off while using. But while using with electricity the laptop turns off for no reason,...
It could be that the laptop disables it's battery when you connect it with the power supply. When the power supply then fails it won't have enough time to switch back to battery. You'd best first try another power supply, and post back here if that doesn't help.
Jun 07, 2009 | Sony Computers & Internet
Laptop loses power and shuts down for no reason.battery is dead and theres no back up power
  • use a power cord - if the problem persist..--if it works then it is the battery that needs replacement; or else
  • try to reseat the memory, try to switch the memory on its slots (if there are multiple slots) - it could be the memory
  • if it comes to the point of no power at all after the above steps then it is the system board.
Apr 28, 2009 | Computers & Internet
Laptop crashes (G4) often and boots up to an error message stating the date is before 2001. The date reverts back to 12/31/1969. Programs are out of wack as a result.
sounds like you have a power problem. Can your computer run on the battery? If you run it on the battery and pick it up and jiggle it, does it turn off. The reason the date is reverting to 1969 is because once the computer loses all it's power (battery and cord), it loses all information that requires power, which includes the date. I'm guessing that your power cord requires some tweaking to get it to turn on properly (light up) and that the battery is close to dead or doesn't have a great connection so it sometimes loses contact and your computer just clicks off.
Feb 26, 2009 | Apple PowerBook G4 Mac Notebook
Acer Aspire 5100 Notebook Logo
55 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
