Question about RCA RCR311B Remote Control
Lost codes to program my remote
I dont have the codes to program my remote, and my universal remote does not have a code search button, i dont know what to do.
Im trying to connect to my tv and need the codes....its a toshiba tv
Posted on Nov 05, 2008
I need instructions and codes for a Sharp TV. Thank you.
Posted on Nov 20, 2008
  • 23 Answers
Ok. what devices are you trying to connect? TV, DVD etc... and I need to know the brand. I might have codes for you.
Posted on Oct 15, 2008
5 Suggested Answers
SOURCE: I dont have the codes to program my remote
i don't have the code book.can you email me the simplliest way too program this remote.
Posted on Nov 22, 2008
SOURCE: programming my universal remote
press and hold the setup button till it remains red the press tv, vcr or dvd button whatever you are programing and enter the code and try to turn off the tv an if need keep doing this till a code works
Posted on Sep 12, 2008
SOURCE: need instructions to program, and need to know where code search button is, lost my manual book in recent move. thanks
i need to program my radio shack 3 in 1 remote but lost the instructions
Posted on May 25, 2009
  • 325 Answers
SOURCE: i dont know how to put in the code to program
Hello X4rasta2girl,
Here is a link you may find usefull.
http://www.universal-remote.net/philipsmagnavox.html
cheers little dish fitter.
Posted on Nov 15, 2009
What to use a rca universal remote butdont know the code
3 Ways to Program an RCA Universal Remote - wikiHow
www.wikihow.com > ... > TV and Home Audio > Television
wikiHowJump to Remotes Without "Code Search" Button - Using Brand Code Search ... (for example, many stereos don't support remotes). ... in this article to program the remote,but ... If you know the exact code that you need ...
Program an RCA Universal Remote Without a "Code Search"
wikiHowHow to Program an RCA Universal Remote Without a "Code Search" Button. Do you have an older RCA universal remote that you want to use, but it lacks a "code ...Don't let go of the TV button. ... Please tell us everything you know about.
Programming the RCA RCRN04GR Universal Remote
Dec 25, 2015 | RCA Televison & Video
What to use a rca universal remote but i dont know the code
2 Easy Ways to Program an RCA Universal Remote Us
Can you help me program my remote?
hi i have a philips universal a rca tv and a dvd named lennox sound 2003 i want to program the dvd with the remote please help no codes lost
Feb 09, 2009 | Philips Universal PH301S Remote Control
Programming my universal remote
Aug 29, 2008 | Philips Universal PH301S Remote Control
http://www.remotecodelist.com/remotes/magnavox/Philips-Magnavox_PM525S.pdf
This is the user's manual for a Phillips remote control. There is a list of codes in it. They should be rather universal. There's also instructions as to how to program it. I believe that there is a way to program it without using the codes.
Programming with Code Search
1. Manually turn on the device (TV, VCR, etc.) to be controlled.
2. Press and hold Code Search button until the red indicator stays on. Release the Code Search button.
3. Press and release the desired mode button (TV, VCR, etc.). The red indicator blink, then stays lit.
4. Press the Channel Up button repeatedly (up to 300 times) until the device could be controlled changes channel. The red indicator blinks, then stays lit. If you accidentally overshoot the code required, press the Channel Down button to backtrack through the library until the device changes channel. Pressing Channel Up changes direction to forward again. Press and release the Mute button to install the code.
Hope this helps :)
Apr 15, 2008 | Philips Universal PH301S Remote Control
Philips universal remote codes
For the majority of phillips/magnavox universal remotes: Hold code search button down till red light satys on. Press the tv button and the red light should blink and stay lit. With the tv on, push the power button repeatedly until the tv turns off.(dont push the power button again after the tv turns off or it will go to the next code). Push the mute button to save the setting.
Feb 07, 2008 | Panasonic PT-47WX53 47" Rear Projection...
General electric Universal remote control codes
try out this.mash and hold the set up button.when the indacator light bilnks ,press the item in which you want coded.turn that item on by hand,point to it with remote and mash the power button up to 300 times until the item turns off.then hit enter.do not go to to fast,if you over shoot the code you will have to start all over again.let me know if this works for you. halfbreed76. e-mail mckenithfamily @net zero.com
Nov 21, 2007 | Directed 434MHZ Remote Control
What do I have to do?
Introduction Programming a Jasco/GE Universal Remote Control takes about seven steps. As with programming other remotes, you need to know the code of the component you are programming into the remote. While some trial and error may be required to get the right codes input to control your equipment, the pleasure at getting rid of several extra remote controls will far outweigh the hassle in getting it programmed. Instructions Difficulty: Easy Steps 1Step OneManually turn on the device you wish to program. 2Step TwoPress the Code Search button on the remote until the indicator light turns on. 3Step ThreeRelease the Code Search button. 4Step FourPress and release the button for the device you are programming. 5Step FiveEnter the three-digit code for the device using the number buttons on the remote. After the code is entered, the indicator light turns off. 6Step SixAim the remote at the device and press the power button. The device should turn off. 7Step SevenPress Channel Up on the remote with the device on. If the device responds, no further programming is required. 8Step EightTo look up a device code to enter directly into the remote, you can visit the GE Remote Code Locator SAMSUNG 002 012 102 103 112 212 502 512 818 914
Apr 01, 2007 | GE RM24911 Remote Control
Philips Universal Remote PM435S reprogramming
I have the same tv and remote that you do. I went on Philips website and they have instruction manuals and the code lists. You can also press and hold the 'CODE SEARCH' button until the light stays on. Then press 'TV' button. Make sure your TV is on and press Channel Up button until the channel changes on your TV. If you go too far, press the Channel Down button until it changes again. Then press the Mute button to store the code. Good Luck!!
Mar 20, 2007 | Philips PM435S Remote Control
RCA RCR311B Remote Control Logo
468 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
