Question about Olympus WS-100 Digital Voice Recorder
WS100 solution suggested
"the dat files were removed off the recorder. put them back on and it should work fine. also try to format the recorder through the menu and not the computer" I can't get them back from my desktop as the device says its full and won't erase when I try to clear all...any further advice please?
pipitita
  • pipitita Oct 13, 2008
    "when the device is plugged into the computer, you should be able to see the contents of the drive... you should see folders. if the folders are not there then copy the folders back to the device after deleting whatever is on the device"
    the problem is that there are "no folders" on the device, the 'get info' shows virtually empty but I can't transfer the folders as it thinks it "full"  ... any idea how to clear the full and or how to transfer the files? pipitita
  • pipitita Oct 15, 2008
    I still can't delete contents of recorder since it doesn't recognise the contents as there are apparently no files whenever I try to delete all. Yet when I try to get the files back on the device, it says its full and can't take them...anybody help here please???
    Sergeant:
    Champion:
  • Olympus Expert
  • 479 Answers
When the device is plugged into the computer, you should be able to see the contents of the drive... you should see folders. if the folders are not there then copy the folders back to the device after deleting whatever is on the device
Posted on Oct 13, 2008
  • Randy Morton Oct 15, 2008
    you will need to format the recorder through the computer, then put the folders back on there
Am I able to recover erased file on Olympus WS100 digital voice recorder
Sorry NO...once files are deleted they are gone...there is no"recycle bin".
Sep 16, 2010 | Olympus WS-100 Digital Voice Recorder
Font enlargement of the Manual of Olympus WS100
If you download it in PDF format and use the magnification tool in Adobe you should be able to read it
Apr 19, 2010 | Olympus WS-100 Digital Voice Recorder
Softwere for DS-330
DSS Player (version 7.0): http://www.olympusamerica.com/files/DSSPlayer.zip After unzipping the file, click on the SETUP.EXE file to begin installation. License key: 8360 0121 0002 6901 5480
Jun 08, 2009 | Olympus DS-330 Digital Voice Recorder
Olympus Voice Recorder WS100
The recorder is not provided with any installation software. It is considered a plug and play device and should connect to Windows XP or Windows Vista and display as a removable disk drive. You can then copy and paste the files from that drive to your hard drive. The files will play using Winodws Media Player.
Mar 11, 2009 | Olympus WS-100 Digital Voice Recorder
No space available.
Format of the DS-30
If you format the recorder, all files will be removed and all function settings will return to defaults except
date and time settings.
1 While the recorder is stopped, press the MENU button for 1 second or longer. The menu opens ( P91,93).
2 Press the + or – button to choose “Format”.
3 Press the OK or 9 button. The “Cancel” indicator flashes.
4 Press the + button to choose “Start”.
5 Press the OK button. After the “Data Will Be Cleared” message is on for two seconds, “Cancel” will turn on.
6 Press the + button again to choose “Start”.
7 Press the OK button. Formatting begins and an indicator flashes
on the display.
“Format Done” displays when formatting ends
Dec 24, 2008 | Olympus DS-30 Digital Voice Recorder
Olympus W_S 100 can't record/erase
Oct 12, 2008 | Olympus WS-100 Digital Voice Recorder
Problems caused by "improper device removal"
the recorder has .dat files in each folder and must not be deleted. if you still have them on your computer, then you can transfer back to the recorder and the recorder should work fine
Jul 03, 2008 | Olympus WS-100 Digital Voice Recorder
Ws 200s deleted files but still full
I had the same problem. I downloaded the instruction pamphlet at http://www.olympus.co.jp/en/support/imsg/vtrek/download/manual/ws/man_ws100_ws200s.pdf and reformatted the recorder. It seems to work fine now.
Formatting the Recorder (FORMAT)
If you format the recorder, all function settings will return to their defaults.
All files stored in the recorder will be deleted.
If you have important files that you want to save, connect the recorder to a computer and
transfer those files from the recorder to the computer before formatting the device.
1 Press the MENU button.
2 Press the FF or REW button to choose “FORMAT”.
3 When the PLAY button is pressed, “nO” is displayed.
4 Press FF or REW to select “yES”, and press the
PLAY button.
After “ARE yOU SURE” is displayed, “nO” will be displayed.
5 Press FF or REW to select “yES”, and press the
PLAY button.
“DONE” displays when formatting ends.
s It may take up to several tens of seconds to finish the initialization. Do not remove the battery or detach
the battery compartment from the recorder during that time. Otherwise data may be damaged.
s Never format the recorder from a PC.
s When the recorder is formatted, all the stored data, including locked files, are erased.
Mar 20, 2008 | Olympus WS-200S
Recording Time
I have one of these recorders, I actually have 4 or 5, since discontinued I believe, and one is stuck at 43 min remaining.
I think that problems start when you remove the battery while
the recorder is / was in the process of recording (or in play mode) I now press stop while recording before opening the battery case to switch a battery
Mar 04, 2008 | Olympus WS-100 Digital Voice Recorder
Olympus WS-100 Digital Voice Recorder Logo
88 people viewed this question
Top Olympus Audio Players & Recorders Experts
Mitch Davis
Mitch Davis
Are you an Olympus Audio Player and Recorder Expert? Answer questions, earn points and help others
