Question about Karcher 2500 PSI Pressure Washer
Have a Karcher steamer SC1002. The safety cap will not turn. Did not leave any water in it after I last used it. According to the instructions I needed to contact customer services but they were no help. Any suggestions please as how I can release the cap so I can use the machine. Thank you
  • jaybeegeezer Dec 11, 2008
    I have the same problem with my steam cleaner. The valve inside the cap is stuck and will not engage to release. The only solution I can think of is to break the plastic part at the top of the cap so as to enable a pair of grips to turn the threaded part. Have yet to try though as I am still looking for technical details.
  • 92 Answers
Dear friends,
I once solved a problem like this with a simple trick. The problem is that it should be done by a qulified tecnician. I will suggest this trick, but do not take responsability if unqualified persons try to do it. The trick is to fill the steamer again with water from some where else. Most probably the cover of the steamer has to be removed. Thou one can try to fill ot from the outlet. Now when there is water in the steamer, one must put it on, and let the temperature rise. When the temperature is at its normal reading, you just let it cool slowly. (leave as much water inside as possible). As it is cooling, you must try at intervals to unscrew the tap. If it is still very hot this is not possible(safety)....if it is too much cold, also not possible. So find the RIGHT and SAFE temperature. And the tap can be removed.
fulltech
Posted on Dec 18, 2008
Any replacment for sc505 portable steam cleaner
It sounds like you may have lime or hard water deposits around the screw threads on the cap from the water used to create the steam in your steamer.
I use white distilled vinegar, that I -
  • first warm in the microwave
  • then slowly pour over the sides of the cap so that the vinegar can get "under" and around the cap.
    • I also stop and try to tighten and loosen the cap trying to work the vinegar into the threads.
    • Depending on the severity of the lime build up, depends on whether the cap comes off the first time, you may need to repeat pouring the warm vinegar over the cap or soaking the cap in the vinegar overnight (with a vinegar soaked rag) - I hope it helps??
May 10, 2016 | Euro-Pro Shark SC505 Shark Portable and...
Water coming out of detergent pipe from top for karcher 3030 b jet wash
DISCONNECT HYDRO OR WITH ENGINE NOT RUNNING DISCONNECT SPARK PLUG THEN RE-LEAVE WATER PRESSURE BEFORE SERVICING the detergent pipe plugs into a pipe on the pump, under which is a spring and ball bearing (stuck open, debris) WEAR YOUR SAFETY GLASSES
Apr 01, 2014 | Karcher Garden
Hi -- For my White Wing Steam Cleaner: After I plug in the unit, and wait over 10 minutes, the Pressure gauge shows that the pressure at 2 (maybe 2.5, I can't recall as I'm typing today) -- not...
Re: Low pressure on WhiteWing steam cleaner
1. Make sure the safety switch for the hose handle on the right side of the hose handle is turned to the closed position. To do that, push it away form the hose.
2. Make sure the steam release button (next to the on/off button on the control panel on the steamer) is in the Off position.
3. Make sure the safety cap is tightened.
4. Make sure you have enough water in the tank (at least half a bottle of water)
I hope this helps.
Jul 31, 2011 | Vapor WhiteWing Steamer Canister Vacuum
I have just used the karcher steam cleaner and now cannot get the safety top off. Rio
i cannot get the cap off my karcher sc1122 even though its cooled down
Nov 16, 2009 | Karcher 1201 Canister Vacuum
Karcher SC 1502 steam cleaner can't get cap off water tank
Dear jrider784,
I solved a problem like this on FIXYA, just a few months ago. I gave this solution. Try to fill the machine from somewhere else. You can do this from the outlet. If you manage to do this, put on the machine. ( now you know that when there is hot water in the machine, the tap goes round free for safety). Now as the water starts to cool down....start trying to see if you can unscrew it. My plan is that with the hot water, the safety will start to work again. If the cap does not release the safety on cooling, then there is no other way but to destroy the cap and replace with a new one. Very important to mention that this job must be done by a qualified technician or some one who knows what he is doing. Working with hot water is very dangerous.
Regards,
Fulltech.
Jul 27, 2009 | Karcher DE4002 Steam Vacuum
Karcher 211 - no motor action
Dear Tigger82 (also montaver2000),
This explaination is relavent to various Karcher models, especialy your model. When you are using the machine with the gun open....presurised water comes out of the lance. When you close the gun, the machine stops. This happens by means of a Spill Valve or often called the Control Valve. When the gun is closed, this spill valve cotracts with built up pressure and at the same time works on a miro switch which cuts the electricity....and thus stops the electric motor. Now in many cases when the gun is again opened, this spill valve sticks and keeps the electric circuit closed.
In all cases you must open the cover, and locate this spill valve. Sometimes it is easy to see a micro switch on it. If you remove the miro switch from the spill valve the motor will for sure turn.
Now the spill valve gets stuck for many reasons. One of the reasons is that you leave the machine under pressure for a long time and even store away the machine with pressure still in the system. A spill valve also gets stuck due to detergent. I sometimes service the spill valve and lubricate with special solicon grease. But the best way is to change the spill valve with a new one. So in a few words, the spill valve is stuck and leaving the microswitch off. So the electric motor cannot turn. One final hint is that sometimes the spill valve is difficult to remove. So all one has to do is attach water supply and switch on the pump. With the pressure produced the spill valve will be pushed out. In my oponion this job must be done by a person who knows what he is doing. Carefull that you have safety electrical breakers. See that you have safety shoes, safety gloves and eye protection.
Regards,
Fulltech.
Apr 29, 2009 | Karcher K2.26 Electric Power Washer
Knob
The safety cap (knob) turns counter clockwise to open so you can put water in. Turn clockwise to close after filling.
Aug 03, 2008 | Eureka Enviro Steamer 310 Stick Vacuum
Karcher 2500 PSI Pressure Washer Logo
408 people viewed this question
Top Karcher Garden Experts
John Trevino
Harold Baxter
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
