Question about Numark CDN95 2-Disc CD Player
Numark cdn95 left player skip even with new cds
Sometimes skip and at times do not read cd at all, put same cd in the right player and plays fine.
CDN95 uses the same CD transport as a CDX, aka....junk. Its mostly likely defective, replace left CD drive.
Posted on Oct 17, 2008
SOURCE:
Sony cdp cx 355 skips on first track
Could be some dust or debris in the unit. Also be careful that you are not putting fingermarks near the hole section of each CD you put in, as the CD plays from the centre out.
Jul 02, 2017 | Sony MegaStorage CDP-CX355 300-Disc CD...
3 disc Phillips cd player sometimes skips. It is
At some time in its life, the laser that reads the CD starts to get too weak to operate reliably. That's probably what's happening here. Unlike mechanical parts that can be inspected for wear, electronic parts tend to work fine one day, then the next, poof. The laser assembly is replaceable if you can locate the part and find someone to install it. An electronic service shop could give an estimate for repair. If you can provide the full model number, I'll see if I can find the part number.
Mar 08, 2010 | Teac AD-600 3-Disc CD Changer
CDs skip
Hello
Ok, it sound to me that the laser lens which actually reads the cd's has some dirt particles on it.
There is a very cheap method of solving this problem.
Just go to any cd shop and buy yourself a decent laser lens cleaner disc, follow the instructions and you should be set.
Kind regards
Andrea
Dec 13, 2009 | Technics SL-PD6 5-Disc CD Changer
On
this is the result of a bad tracking rail and motor. replace the optical assembly asap to combat this issue.
May 26, 2009 | Sony Audio Players & Recorders
Cd player showing error 43
Still under warranty?... check that.
Mar 24, 2009 | 2008 Hyundai Elantra
Player 2 skips and plays a different track
May need manual cleaning or Cd Mechanical assembly may need to be replaced
Dec 03, 2008 | Nu Mark Numark Cdn36 Dual CD Player CD...
Numark CD MIX2 right deck skipping, sounding scratchy
Did you by any chance buy it from a b stock retailer?...send it back...also reduce your burn speed when recording cds
Aug 04, 2008 | Nu Mark Numark Cd-Mix-2 Dual CD...
New laserunit won't work
You seem confident enought to take it apart, have you tried cleaning the runners that the laser runs backward and forward on.
Some times they collect dirt/dust and the laser can't move smoothly so it jerks and skips.
Mar 13, 2008 | Denon DN-961FA CD Player
Durabrand CD player skips while playing.
hi i've had the same problem i though it was the laser or the laser rail until i opened it!! Then i checked the laser, the rail and all the other mechanical it worked fine, until i got to the laser it had a hair right in the middle, don't bother trying the cd cleaner it doesn't work! all i di is take out the laser cleaned it with a cotton suabe and alochol for a bout a minute and now it works beautifaully! also clean the circle thingy that spins and holds the cd! any little particle will make that laser not read the cd right! while ur there tryin cleaning the unit from dust! it's the worst ememy! well hope this helps!
Feb 19, 2008 | Audio Players & Recorders
CDs wont play
archo69..big chance your laser is on its way out..it also can be the bottom lense is dirty to ,but this requires your stereo to be removed .dismantled and cleaned manually
Feb 07, 2008 | Aiwa CDC-Z127 CD Player
Numark CDN95 2-Disc CD Player Logo
597 people viewed this question
Top Numark Audio Players & Recorders Experts
 Grubhead
Grubhead
Colin Stickland
Colin Stickland
Morne Olivier
Are you a Numark Audio Player and Recorder Expert? Answer questions, earn points and help others
