Question about Toshiba Satellite A305-S6863 Laptop
Sound crashes often, then cannot adjust volume
(I'm not completely sure this is the exact model. Mine says it has an Intel Core2 Duo processor t5550, and 3gb memory.) At least half of the time when I try to adjust the volume on this computer, it doesn't do anything and it tells me it's not responding so I click "restart the program" and the taskbar and desktop icons disappear for a second, the reappear. But the volume icon in the taskbar doesn't come back so I still can't adjust the volume. I tried going to the control panel after that and adjusting it from there, but then it crashes again. If I restart the computer the volume icon comes back and I can sometimes adjust it then. This is really annoying; anyone know what's going on? I'll try to get more information if you need it. Thanks!
  • hanikac Oct 13, 2008
    Oh, and when it's not responding the physical volume wheel doesn't do anything either.
  • 50 Answers
Sounds like your sound card drivers are corrupted and causing problems with your OS. You may need to either upgrade them or reinstall them.
What OS are u using?
Posted on Apr 20, 2009
My core 2 duo E6550 does not work on my foxconn g41mxe motherboard
http://www.newegg.com/Product/Product.aspx?Item=N82E16813186187
Motherboard supports Processors with a Front Side Bus (FSB) of either 800Megahertz, or 1066MHz.
1333MHz FSB support is done with OVERCLOCKING.
http://ark.intel.com/products/30783/Intel-Core2-Duo-Processor-E6550-%284M-Cache-2_33-GHz-1333-MHz-FSB%29
Intel Core2 Duo E6550 processor has a 1333MHz FSB.
http://www.manualowl.com/m/Foxconn/G41MXE/Manual/297328
I reduced the view size to 120 percent. Go to Page 27.
Press DELete key to enter BIOS Setup.
Use Down Arrow key to highlight - Fox Central Control Unit
Press the Enter key
CPU Frequency Setting should be set to 333 (333MHz)
Intel processors are 'Quad Pumped'
333MHz x 4 = Approximately 1333MHz. (1332)
http://www.foxconnsupport.com/cpusupportlist.aspx?type=mb&socket=Socket%20775&model=G41MXE&cputype=Intel
Note the version of the BIOS program also.
Regards,
joecoolvette
Sep 25, 2012 | Foxconn G41MXE Core 2 Quad Intel G41 DDR3...
My Wifi is not working. My laptop sound is scratchy. I want to upgrade my processor from celeron to core 2 duo which one i should select for cpu upgrade?
Two main things to know before you can attempt a Processor upgrade.
1) What Processor socket is on the motherboard?
2) What motherboard chipset is on the motherboard?
(Northbridge and Southbridge chip. Unless it's a motherboard that supports Intel Core 13, Core i5, Core i7, and Core i9 processors)
According to specifications I found online just now, the BenQ Joybook A53 comes with an,
Intel Core2 Duo T7250 processor,
http://laptops.techfresh.net/benq-joybook-a53/
Scroll down.
(Only 512MB's of DDR2 Sdram (SO-DIMM) ram memory that operates at 667Megahertz?
{ PC2-5300} Yecch! You need at LEAST 1GB of ram memory. (512MB + 512MB = 1GB.
2GB would be best)
http://www.laptop-software.com/benq/benq-joybook-a53-features-and-specifications/
Information on the Intel mobile Core2 Duo T7250 processor,
http://en.wikipedia.org/wiki/List_of_Intel_Core_2_microprocessors#Core_2_Duo_2
Scroll the page down until in the left column you see T7250. Then read across, and match the headings above.
Uses a Socket M processor socket,
http://en.wikipedia.org/wiki/Socket_M
Is your problem directed to a BenQ Joybook A53 Notebook PC, or is it another model?
Sep 16, 2011 | BenQ Joybook A53 Notebook
Dg41 is the best
Please get DG41/CN/TX motherboards it the best. this is due to fact that it carries a better graphic resolution card, lates technology DDR3 SD RAM ram, etc.
Intel DG41CN Motherboard
  • Form Factor: Micro ATX
  • Compatibility: PC
  • Chipset: Intel G41 Express
  • Compatible Processors: Intel Celeron, Intel Pentium, Intel Core2 Duo, Intel Core2 Quad
  • Video Interface: PCI Express x16
  • Storage Controller Type(s): Serial ATA II x 4
  • Intel DG41TX Motherboard
    • Compatibility: PC
    • Compatible Processors: Intel Celeron, Intel Pentium, Intel Xeon, Intel Core2 Duo, Intel Core2 Quad
    • Front Side Bus Speed: 1333 MHz
    Regards,
    Pourmoi
    Dec 23, 2010 | Intel DG31PR Motherboard
    I want to know that did intel d945gcr supports core 2 duo processor...............plz
    This mother board will work if we have a compatible processor like Intel Core2 Duo, Intel Pentium D, Intel Pentium 4.But the processor should be greater than 2.99Ghz if the processor is less than this then it will to work.Dual core processor means there will be two processors working
    The detailed specifications of the new Intel D945GCCR Motherboard are:
    • Form Factor:MicroATX
    • Processor:Intel Core 2 Duo, Intel Pentium D, Intel Pentium 4 and Celeron D processors in the LGA775 package
    • Supported System Bus:800 MHz / 533MHz
    • Chipset:Intel 945GC Express Chipset with ICH
    • Supports Hyper-Threading Technology
    • Graphics:Intel Graphics Media Accelerator 950
    • Graphics Connector:One PCI Express* x16 graphics connector
    • Memory Support:Dual-channel DDR2 533 / 400 MHz, 2 DIMM slots (2GB Max)
    • Expansion Slots:Two PCI connectors
    • One PCI Express* x1 connector
    • Audio:Intel High Definition Audio with 5.1 Surround Sound
    • USB Ports:Eight Hi-Speed USB 2.0 ports (4 back / 4 front)
    • Storage One IDE (ATA 100/66/33)
    • Four Serial ATA ports (3.0 Gb/s)
    • On-Board LAN:Intel PRO 10/100 Network connection
    • Warranty:3 year limited warranty
    Hope that solve your problem!
    Thanks for using Fixya!
    Dec 15, 2010 | Intel D945GCCR Motherboard
    Compatible processor
    Here are the compatible processor for this motherboard.
    Compatible Processors Intel Pentium 4, Intel Celeron D, Intel Pentium D, Intel Core2 Duo, Intel Core2 Extreme
    Dec 03, 2010 | ASUS P5L-VM 1394 Motherboard
    Is there something I can do to increase the volume on my Dell Inspiron 1525? Thanks
    go to the control panel and click on sound you will see the icon in form of speaker then adjust all volume to the point of your choice and click on apply then you are through
    Feb 20, 2010 | Dell Inspiron 1525 (dndppa1_3) Intel Core...
    I need mother board softwares for the model E4500 help me?
    thats a intel core 2 duo not a mother board ? find the mother board number ....
    Oct 09, 2009 | Intel Core2 Duo E4500 Processor - 2.20GHz,...
    Hi i m havung dell 1525 with core2 duo processor in it ..and at top of the dekstop there are 8 options like internet,web cam,help and support............is removed ..i can't see them now.........plz help...
    sounds like the dell 'quickset' software has been removed- insert the driver disk that came with the 1525 and follow the install instructions - then scroll down until you come to the desktop software section and reinstall the control software - hope this helps
    cheers
    Nov 19, 2008 | Dell Inspiron 1525 (dndppa1_3) Intel Core...
    Cpu enquiry
    There really is no difference, there are differences in the E numbers though. Those are specificallt about it's GHz's, it L1 and L2 cache.
    Though Intel Core 2 Duo is the same as Intel Dual Core. It's just a different name. This confusion is caused because of Intel changing the names of it's processors series. The Pentium brandname for example is gone. Intel Pentium Dual Core is now called Intel Core 2 Duo.
    I hope this answered your question.
    Greetings,
    DarkNeogen.
    Jan 25, 2008 | Intel Core 2 Duo E6600, 2.4 GHz E6600...
    Toshiba Satellite A305-S6863 Laptop Logo
    93 people viewed this question
    Top Toshiba Computers & Internet Experts
    Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
