Question about Samsung HLN4365W 43" Rear Projection HDTV-Ready Television
Sound goes out after a while
When the TV first comes on the sound is clear and great. we usually have it set at about 10. But after at least an hour or longer the sound starts to become distorted and crackly. We have to turn it up to about 15-20 to understand anything on the TV. then within an hour of that the sound is completely gone. Only way to have sound is turn tv off and wait. I usually just go to bed and sound is fine by the next morning.
  • Daniel Baker
    Daniel Baker Nov 11, 2008
    I used my DVD player on a component connection and watched an entire DVD with no sound issues. Does the amplifier only work on the cable connection or all connections?
    also is the amplifier easily serviceable/replaceable?
I just lucked out. The cable box I was using just lost all sound. It was tested on two other TV's to confirm that it was the box and not TV. Got a new box from cable company and sound is back. Thanks for all the help.
Posted on Nov 16, 2008
    Genius:
  • 2,920 Answers
Your amplifier is going ouot
Posted on Nov 03, 2008
  • Ronnie Houston Nov 11, 2008
    its replacable and shouldnt cost too much to do it or you may want to run the tv through a vcr to keep the cound.its cheaper to hook up and vcr through the rgb cables than to replace the amp
Hello, my 55513 tv when turning it on was blurry. after a few minutes it became clear. shut off and came back about 3 hours later and it was blurry again for about 10 minutes. about 10 minutes later it...
in the customer menu select convergence when set acts up---look to see if grid of lines is skewed, see some photos and let me know if your problem anything like this..........
Apr 08, 2012 | Mitsubishi WS-55513 55" Rear Projection...
The picture is taking longer and longer to come on. It's not a consistent length, last night had it on several hours, it was off for an hour and a half, turned it back on and it took over 90 seconds for...
if you can get another one for a reasonable i would certainly consider that. the cost to get these lcd's fixed sometimes is not worth it. you seem to have more than one problem with the set.
Oct 30, 2009 | Zenith C32V37 32" TV
Sound takes up to an hour to come on, Mitsubishi 35'' tv
A $700 dollar estimate for a sound problem seems out of line - get asecond opinion (did some one look at it or just a guess). If the sound eventually comes on you probably have a connection (internal) problem or a intermittent part in audio section -cap o/p IC.
If you use a satellite or cable box can you hook your sound from that to an audio system thereby bypassing the TV?
Sep 30, 2009 | Mitsubishi CK-35308 35" TV
65" Sony Sound / No picture 10 & 5 blinks on timer/stand by light
A 10 blink code on this model is usually and ic that has gone out on the d board. If your a novice at tv repair call a service center.
May 12, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Need Help big screen turns on thens goes off
a tv has two components, firstly a power supply produces high voltage to trigger a line transformer, in turn a transformer produces smaller voltages. firstly check if the ht is constantly been produced from a supply, if this is there than go to a line transformer, and check voltages at the output.
Sep 10, 2008 | Panasonic PT-61HX40 61" Rear Projection...
Picture clarity
Sounds heat circuit related, and if under warranty you should notify them before you have to pay for the tuner or sync board.
Feb 03, 2008 | Westinghouse LTV-37WI 37 in. LCD...
TV won't power ON
This problem will need to be repaired , it is most likely the EPROM chip or controling circuts
Oct 28, 2007 | Toshiba 27A62 27" TV
The set is almost 10 years old and has always worked perfect until today. . .
It soulds as of your solder joints are getting old and starting to crack. If the screen goes completely black then I would resolder all the major solder joints on the main PC board, and if you mean that the screen goes to all snow (as if the cable went out) then I would also pull the tuner and resolder the joints inside it too. If you do not have experience soldering on small PC boards then allow a qualified tech to handle it for you. The fact that it works sometimes means that all major components are fine and the repair shouldnt cost too much.
Jul 13, 2007 | Toshiba CF27H50 TV
Screen goes from blurry to clear to blurry
The first thing to check is for loose conections,the problem is related to the high voltage but it can start in the main board with one component loose,when the high voltage is developed it goes to what is call the distributor block,a lot of sets have the focus and screen controls coming out of this block for each picture tube,this block might be bad but before we go to him we need to check everything is solid in the main board.If you are familiar with electronics you can remove the back cover and tap the chassis with a wooden or rubber handle to see if the set reacts,if it does you need to be atentive what area makes it react and flip the board to do some resoldering,If you are not too familiar with tv service you need the assistance from a servicer.Let Us know how it goes or if you need more information.
Oct 27, 2006 | Zenith H32G48S TV
Samsung HLN4365W 43" Rear Projection HDTV-Ready Television Logo
112 people viewed this question
Henry  Thomas
Henry Thomas
