Question about Nor-Lake Norlake Refrigeration 4' x 6' Kold Locker Walk-In Cooler - 6' 7'' High w/Floor
Fridge I have a Norge refrigerator, model NT198M. What is the cubic foot capacity of this fridge?
How many cubic feet is Kenmore Coldspot Refrigerator Model 10674254400 Serial ER3139075
Kenmore appliance model numbers have a three digit prefix (106 in this case) for the manufacturer. The rest of the model number indicates a lot of the specifics for the refrigerator. The third digit is the second group indicates the capacity. This fridge is a 22 cubic foot model (or slightly smaller).
I hope this helps.
Apr 15, 2017 | Kenmore Refrigerators
WHAT THE CUBIC FOOT SIZE FOR THE MEASUREMENTS OF 62"H x 23.5"W x 24"D?
The cubic ft capacity spec on a fridge is measured inside, and varies depending on its design, especially on whether it has an ice maker, although those measurements you give seem to be for a bar fridge or similar.
Your measurements come to 20.3 cu ft on the outside, but remember that is not relevant, you have to measure the dimensions to make sure it fits.
Feb 25, 2016 | Refrigerators
What is the cubic foot size of this fridge...
Greg,
If you put in the make and model of your refrigerator, it did not come through with your question. As far as sizing goes, most manufacturers will usually put part of the cubic foot size in the model number. For example, I just installed a refrigerator that at the store they labeled it as a 21.2 cubic foot refrigerator and the model # starts out as GTE21GS... That .2 cubic foot does not show up in the model but the 21 does, so that should give you a basic starting point. Hope this helps!
Aug 14, 2015 | Refrigerators
How to calculate cubic feet of a fridge
simple maths
33.5 x 19.75 x 20.25 = 13397.9063 cubic inches
then divide that by how many cubic inches in a cubic foot
13397.9063 / 1728 = 7.75341797 cubic feet.
obviously that depends on whether the sizes you have given are the internal or external measuresments and what furniture there is inside the freezer i.e wire racks/shelves but i suspect that this is a chest style freezer.
Alternativly you can look on the data plate which will give you the capacity.
Sep 19, 2014 | Refrigerators
I just need the specifications/dimensions of my Kenmore Elite Refrigerator, model #106.54609300. I need a new fridge of similar size to fit in an enclosed space. I have searched all over the web and...
I have this exact model. Here are the specs:
depth: 30"
height: 68.5". with hinge: 69.5"
width: 35.5"
15.5 cubic feet in the refrigerator section
10.0 cubic feet in the freezer section
25.5 cu ft total
Sep 08, 2011 | Kenmore Refrigerators
I am looking for the dimension and capacity of fridge 69852990
Measure Exterior Height & Width and Depth for Dimension.
Interior Space = Then, Measure all open accessible area inside the fridge and add the two together, following the formula of H+W+L Freezer and H+W+L Refrigerator,add together and BAM ya got cubic inches.= Square inches, then divide by 1,728 (the number of cubic inches in a foot (3) Cubed.
Example 1: 60 inches tall, 42 inches wide, 30 inches deep = 75600/1728 = 43.75 Cubic Foot AREA
Example 2: fREEZER dIMS = 24 DEEP x 18 HIGH x 36 WIDE =15552/1728 is 9 CuFt. Refridgerator 36 wide, 36 high 28 deep = 36,288/1728 = 21 CuFt. + 9 CuFt. = 30 Cubic Foot Capacity.
By the Math Wiz RUDY :)
Apr 18, 2010 | Kenmore 20.6 cu. ft. Top Freezer...
Fridge not cooling freezer iceing up???
check the fan in back of freezer check or proper running condition not stuck or frozen also make sure not blocked by food the fan takes the air from freezer and blows it down into fridge area to cool it also check for ice build up in the fan housing and thaw as necessary
Nov 15, 2009 | Avanti Top Freezer 9.9 Cubic Foot Total...
Looking to buy a maytag side by side fridge freezer in black/chrome what is the sm allest depth they do that will fit in with my kitchen units
Maytag and most other manufacturer's, are making what's called "counter depth" fridges. These fridges typically only extend out from the wall only as far as a traditional countertop (24" to 26" +/-).
However, most of these fridges have a smaller Cubic Foot capacity inside them, so large familes would be advised to stick with traditional fridges, which have the largest capacities available.
With that being said, here's a link to Maytag's site that will let you pick out the style of fridge you want and select the counter depth model you prefer.
http://www.maytag.com/catalog/kitchen_products.jsp
I hope you find the fridge that you want and that this little bit of information has been Very Helpful for you. Best regards!
Oct 01, 2009 | Refrigerators
Don't know if this old fridge is worth saving.
Can't tell the age without the serial number, but it is a 21 cubic foot refrigerator. Plug it in, if it cools could be a good garage fridge.
Jun 14, 2009 | Refrigerators
Need Cubic Foot Capacity of this refrigerator please
Find a five year old child with a tape measure
and ask the child to measure the inside of the fridge
then width x lenght x hight = result
Then give child a lollie
Apr 16, 2009 | Refrigerators
Refrigerators Logo
49 people viewed this question
Top Nor-Lake Refrigerators Experts
John Tripp
John Tripp
Michael Galve
Michael Galve
Are you a Nor-Lake Refrigerator Expert? Answer questions, earn points and help others
