Question about Inland ProSound 1000 Computer Speakers
Not sure how to do proper instalation for this product.
Need help with proper instalation to my PC. I have to many plugs on the back of my PC not sure which one to use to connect my spekears. Need complete guidelines for instalation of the spekears to my PC.
  • 761 Answers
Usually
speakers are connected to.
On rear of case will be either 3 ports in line or 6 in a group each has a different color and unless you have multiple speakers which require to be set up from diagram that came with them
standard speakers plug into the Green port
Posted on Oct 13, 2008
Digital sender 9250c there is power but no display in the screen formatter LED light blinking is working but network light not blinking
Depending on what operating system your running. You need to make sure your product is plugged in through a usb connection. Now if your computer doesn't find the product that's ok you just need it to be plugged in. then you need to download the proper drivers for it. For instance if your running windows 7 64 bit, you need to download the drivers making sure you have 7 64bit drivers. In this case you want to install the firmware update make sure you see a yellow smiley face after the firmware is installed to your Digital Sender
Jan 04, 2014 | HP 9250c Digital Sender (CB472AABA)
Hp digital sender 9250c show continue turn off then on .what is the problem and how can i solution this problem
1422807-h20565.pngDrivers Software Firmware for HP 9250c Digital Senderh20565.www2.hp.com
Mar 18, 2013 | HP 9250c Digital Sender (CB472AABA)
My digital sender disp show continue turn off then on what can ido now
My hp digital sender 9259c need an RFU upgrade
Jul 02, 2012 | HP 9250c Digital Sender (CB472AABA)
Photosmart for 300 series
Depending on what operating system your running. You need to make sure your product is plugged in through a usb connection. Now if your computer doesn't find the product that's ok you just need it to be plugged in. then you need to download the proper drivers for it. For instance if your running windows 7 64 bit, you need to download the drivers making sure you have 7 64bit drivers. In this case you want to install the firmware update make sure you see a yellow smiley face after the firmware is installed to your F340 HP Deskjet F340 All in One Printer Drivers
Apr 27, 2012 | HP Computers & Internet
What is error code 22 hp digital sender 9250c
Depending on what operating system your running. You need to make sure your product is plugged in through a usb connection. Now if your computer doesn't find the product that's ok you just need iticon1.pngto be plugged in. then you need to download the proper drivers for it. For instance if your running windows 7 64 bit, you need to download the drivers making sure you have 7 64bit drivers. In this case you want to install the firmware update make sure you see a yellow smiley face after the firmware is installed to your Digital Sender
[img src="http://i.fixya.net/uploads/images/1422807-h20565.png">Drivers Software Firmware for HP 9250c Digital Senderh20565.www2.hp.com
Aug 02, 2011 | HP 9250c Digital Sender (CB472AABA)
HP 9250c digital sender is giving error login failed code 22 using common access card
Jun 29, 2011 | HP 9250c Digital Sender (CB472AABA)
I need to install my printer LBP 2900 how?
Without knowing the OS that you are installing this into, make this difficult to properly resolve .... Here is a link to the Canon-Europe website ... this is where you will select your OS and and follow the online steps to locate the correct driver software in relation to your OS ..... http://software.canon-europe.com/products/0010177.asp be sure to read everything closely as you work your way closer to receiving a usable driver download .... if you cannot download this directly onto your PC .... download the software, saving onto a USB flash drive ....When you are ready to install, be sure to have the USB flash drive on hand to plug into the PC you wish to install the driver onto.
Sep 03, 2010 | Canon LASER SHOT LBP-2900 Printer
Hai mr.igot problem when i install usb bf-810 iwas isntal driver but when i plug the port inthe PC it's show"USB devivice not recognice"can u solve my problem
Before you start installing the driver, please don’t plug your USB TO Serial Adapter into the USB port of your computer.  Follow the steps below to install Windows® 98 or Windows® ME driver 5.1 Turn on the power of computer and make sure the USB port is enabled and can working properly. 5.2 Insert the driver of USB-SERIAL ADAPTER into CD-ROM drive. Select “Install Products - USB-SERIAL ADAPTER - Install”. 5.3 Select the “Next” to install.
Before you start installing the driver, please don’t plug your USB TO Serial Adapter into the USB port of your computer.  Follow the steps below to install Windows® 2000 driver 6.1 Turn on the power of computer and make sure the USB port is enabled and can working properly. 6.2 Insert the driver of USB-SERIAL ADAPTER into CD-ROM drive. Select “Install Products - USB-SERIAL ADAPTER - Install”. 6.3 Select the “Next” to install.  Before you start installing the driver, please Don’t plug your USB TO Serial Adapter into the USB port of your computer.  Follow the steps below to install Windows® XP driver 7.1 Turn on the power of computer and make sure the USB port is enabled and can working properly. 7.2 Insert the driver of USB-SERIAL ADAPTER into CD-ROM drive. Select “Install Products - USB-SERIAL ADAPTER - Install”. 7.3 Select the “Next” to install.
.1 Driver Installation (MAC OS X) 8.1.1 Power on your computer and make sure that USB port is enabled and working properly. 8.1.2 Insert the USB adapter software driver into CD-ROM driver. 8.1.3 Click "USB-SERIAL ADAPTER\DRIVER\MAC\OS X " folder run on "PL2303_1.2.1r2.dmg", it will auto run the program and appear "PL2303 driver" folder in the desktop. 8.1.4 Click on "PL2303 driver" folder , execute "USBSerialOSX1.0.9b6.pkg" will auto install, you may change the driver directory that you want to install. 8.1.5 System will demand restart computer. 8.1.6 Plug in the USB-Serial adapter into USB port. 8.1.7 To make sure that your computer can use the device, you have check the "Apple System Profile"-"Device and Volumes". It will show the USB Device.It will show in USB port "USB-Serial Controller". 8.2 Driver Installation (MAC OS 8&9) 8.2.1 Power on your computer and make sure that USB port is enabled and working properly. 8.2.2 Insert the USB adapter software driver into CD-ROM driver. 8.2.3 Click "USB-SERIAL ADAPTER\DRIVER\MAC\OS_89" run on "PL2303_OS9_v136b1.hqx",it will auto run the program and appear "ProlificUSBSerial" file. 8.2.4 Copy "ProlificUSBSerial" file into "system folder"-"Extension". 8.2.5 Plug in the USB-Serial adapter into USB port. 8.2.6 To make sure that your computer can use the device, you have check the "Apple System Profile"-"Device and Volumes". It will show the USB Device.It will show in USB port "USB-Serial Controller". Follow the steps below to install driver of USB-Serial adapter:
hope that helps you
May 29, 2010 | BafoTech BAFO BF-810 Serial Adapter
Where can i get the installation softare for simpletech 250???
you can check on the official site from here http://www.simpletech.com/commercial/products/simpledriveexternalpininfarina.html ;you need to plug in USB to be recognized by you PC or laptop after that you can acces your hard drive when is instaled make a reboot to be sure that is instaled properly.
Dec 10, 2009 | SimpleTech 250GB USB2.0 7200 RPM External...
Inland ProSound 1000 Computer Speakers Logo
93 people viewed this question
Top Inland Audio Players & Recorders Experts
Brian Sullivan
Brian Sullivan
Steven Burn
Steven Burn
Are you an Inland Audio Player and Recorder Expert? Answer questions, earn points and help others
