Question about Toshiba Satellite A1O A15 A20 A25 A30 A35 A40 A45 Series 15 inch LCD Display- LP150X06 CD-ROM Drive
Toshiba laptop A25 integrated ethernet and wireless lan not working
I can't get the toshiba laptop A25 integrated ethernet or wireless lan to work. Device manager says that they are installed and working properly. But the icon under the network connection has them both "X" out. I have hooked it up to a working wireless router. But the system says that the cable is unplugged. Tried the same cable in another laptop and it works.
  • Anonymous Jan 04, 2009
    Couldn't find the file you mention. I'm running XP home. Any other suggestions? My model is A25-S307.
Right, you need to click
>Start
>Computer
>Vista C
>Toshiba
>Drivers
>WLAN
>Realtek
Then find a file called Setup, there may be several. You are looking for the one which is an Application. Mine is around 450kb in size.
Double click it to correctly install the Wireless adapter.
Follow the instructions on screen. This should take no more than 90 seconds from start to finish.
Good Luck
Posted on Dec 28, 2008
Is this laptop is wifi ready?
Yes it is wifi ready.
click me for more info
Toshiba review unit had the following specifications: Intel Core 2 Duo T8100 2.1GHz processor Intel X3100 Integrated Graphics 2GB RAM DDR2 15.4" WXGA 1280x800 screen Intel PRO/Wireless 3945ABG (802.11a/b/g) 10/100 Ethernet LAN Modem port VGA-15 pin DVD-SuperMulti drive (+/-R double layer) supporting up to 11 formats Headphone and microphone jack webcam Battery: 6-cell (4800mAh) Lithium Ion battery Weight: 5.7lbs
Sep 15, 2011 | Toshiba Satellite Pro L300 Notebook
Toshiba laptop will not connect to modem with ethernet. works fine with wireless
if you are sure that the ethernet cable and lan port are in good condition please try to uninstall reinstall the driver of the lan device.
Sep 04, 2011 | Computers & Internet
I bought a used Toshiba 1135-s125. I purchased a Fry's USB WIFI. It will connect but XP won't set IP. XP help tries to connect , but never does. The original wifi pci card is not installed. Wifi did work...
Communications
• Integrated V.92/56K modem; Data and fax support
• Integrated 10/100 Ethernet LAN
Optional Upgrade: Integrated Wireless LAN (IEEE 802.11b)
module... IS GONE! doesn't matter if it connected.
Make sure the related switch rear left is off, even though it is not there the switch being on may make the machine think to look for it.
Install any software given for the Fry USB
Does the wireless show a connection to your Wifi radio setup?
Go to your Control panel - network connections see that there is a WIFI ICON CLICK THAT OPEN AND LOOK AT THE STATUS sorry capson...
Folder tabs General Support open support look to see the IP status
Check the repair to get an IP
Are you trying to connect to your own Network ;-)
Check if you can hardwire cat5
After this write up I should of asked this first
Jun 28, 2010 | Toshiba Computers & Internet
Lan connection not working on Toshiba satellite laptop
Try setting up a new Broadband internet connection. Input all the appropriate Login info and you ought to be good to go via the LAN port. Everything else is aimed towards Wireless.
Sep 19, 2009 | Toshiba SATELLITE A10 A15 A20 A25 A35 A40...
Definition of the sound card, internet lan & wireless lan
The definition of the sound card, is a chipset integrated into the main board of your laptop, in order to provide sound to your built-in speakers, or to the headphone jack on your laptop. Internet LAN (or Local Area Network) is a port located either on the side or the rear of your computer, where you would plug in a Cable/DSL High-Speed Internet connection, using an Ethernet cable (also called RJ-45). Wireless LAN is the same idea, only instead of using an ethernet cable to provide you access to the internet, it uses a wireless signal or radio frequency, to connect to a wireless access point (usually provided by a wireless router in the area). More in-depth information can be found at the following links:
Sound Cards: http://en.wikipedia.org/wiki/Sound_card
Internet LAN: http://en.wikipedia.org/wiki/Ethernet
Wireless LAN: http://en.wikipedia.org/wiki/Wireless_LAN
May 06, 2009 | Acer 4220-2346 Notebook
Satellite a25-S2792 toshiba laptop soundmax integrated digital audio driver
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=DL&os=&category=&moid=665687&rpn=PSA20U&modelFilter=A25-S2792&selCategory=3&selFamily=1073768663&selModel=665687|PSA20U#
Mar 25, 2009 | Toshiba Satellite A25-S2792 P4 3.06GHz...
Lan and wireless driver for toshiba a135-s2246
Unfortunately, the Toshiba Satelite A135-S2246 was never designed to run XP, only Vista. Which is why you can't find any drivers for XP. The nearest you can get is to find a laptop running XP SP2 that is using the same LAN (ethernet controller) and WLAN (wireless ethernet controller), and see if they will work.
Here are the drivers I found for XP (please check which one's you are trying to install):
Atheros WiFi card driver:
http://www.wireless-driver.com/download/atheros/2007-7-23/Atheros-ar5bxb6-AR5424-mini-PCI-E-Wireless-Card-Driver-Download.htm
Intel WiFi card driver:
http://downloadcenter.intel.com/default.aspx
You will need to search for the card that you have.
LAN (ethernet controller):
http://www.realtek.com.tw/downloads/downloadsView.aspx?Langid=1&PNid=6&PFid=6&Level=5&Conn=4&DownTypeID=3&GetDown=false#1
You can pick third or fourth from top depending on your preference.
Please remember that Toshiba, Microsoft, Atheros, Realtek, Intel and especially myself accept no responsibilty for what may, or may not happen when installing drivers not specifically designed for your system. All that said, I hope it works for you.
Dec 05, 2008 | Toshiba Satellite A135-S2246 Notebook
Wireless lan
Is it the wireless connection you have lost, or the card? If it's the wireless drivers you are in need of, you can download them from DriverGuide; http://members.driverguide.com/driver/detail.php?driverid=161640 Note: Free registration is required.
May 26, 2008 | Toshiba Satellite A105 Notebook
Toshiba Satellite A1O A15 A20 A25 A30 A35 A40 A45 Series 15 inch LCD Display- LP150X06 CD-ROM Drive Logo
782 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
