Question about RC 4WD REMOTE CONTROL RACING CAR
Nitro rc car
It starts ok for a few seconds then dies off as if its starved of fuel tryed tuneing but is not the problem any sugestions welcome thanks martin
  • 3 Answers
Check that your fuel tank is fully sealed as fuel is pumped through it via exhaust pressure, other wise check the fuel lines/carby aren't blocked. You may also have too much fuel, as it would build up and stall your car in a few seconds. Try a pinch test: start car then pinch the fuel line near the carby, if it revs a fair bit harder then stops- could be to rich, if it doesn't rev any different before it stops it's too lean and needs more fuel.
Posted on Jul 28, 2009
Why does my briggs and straten model 313-707 hard start then dies after a few seconds when it is running it acts like it's starving for fuel replaced fuel filter fuel cap and cleaned carb
Try replacing the plug.could also be a spark problem from the coil .you can purchase a spark tester which you can fit between the plug and lead .pull start mower and watch if spark is good.if ok then get a can of carby clean start mower and spray carby clean spareingly while running and if it keeps going the fuel is the problem
Aug 14, 2014 | Garden
Traxxas revo 2.5r
the engine shutt down just if load and not bobtail
Dec 29, 2013 | Traxxas Rc Revo Nitro Monster Truck
3.3 revo hard to start after started it will not idle and when it dies it does not want to restart. This did not happen until I drve it thru alot of wet grass last year
Hi
2 stroke engines are very simple. If there's fuel (under pressure) and a spark it will run. Check the glow plug by trying to start it with glow plug removed but still connected and touching the engine body. If the little center wire glows bright red, then it's OK. Only do this for a second or so. If the plug is OK then it has to be a fuel problem. Traxxas has a long history of cracked gas tanks. Good luck
Apr 30, 2010 | Traxxas Rc Revo Nitro Monster Truck
Nitro car wont start?
Motor could be damaged from getting too hot. I would try to reset carb settings back to neutral from the factory. The manual that came with the car should tell you how many turns out they should be. Also check the fuel lines to make sure they did not get damaged. Nitro motors normally run best at 210 - 240 degrees. Much more than 240 degrees can damage the motor. It is always better to run a little rich than lean.
Dec 30, 2009 | Cars & Co Remote Control Buggy Nitro Gas...
Saw starts and runs for a few seconds (while warm) then dies like starved for fuel. Will restart with choke, but does same thing again. Sometimes it will run for a few seconds longer at full throttle, but...
Air filter clean?
Air filter port set for summer or winter ?
Check the fuel filter inside the tank to ensure that it is not dirty or hasn't fallen off.
Aug 16, 2009 | Garden
I just got a used rc car from a friend its a older one
Nitro engines can be difficult to start and keep running unless they are in perfect tune. This take quite a bit of experience, even the experts have difficulties sometimes Go to http://www.radiocontrolzone.com/ for web help. Or go to your local hobby shop and ask for help.
Jun 29, 2009 | Electric Kyosho Ef 49 Gear For Rc Car 20...
2001 chevy cavalier fuel problem?
try a little starting fluid and if it starts it might be the fuel pump or the fuel filter .. starting fluid will let you know if its a fuel problem or just what .. thanks Jerry
May 11, 2009 | 2001 Chevrolet Cavalier
93 Pontiac Lemans will start and then begin to die.
sounds like the fuel filter is pluged or bad maf sencor or may just need a tune up
Jan 17, 2009 | 1993 Pontiac LeMans
RC 4WD REMOTE CONTROL RACING CAR Logo
114 people viewed this question
Top RC Toys Experts
LP
Tom Chichester
Kevin K.
Are you a RC Toy Expert? Answer questions, earn points and help others
