Question about Dell 922 All-In-One InkJet Printer
Printer won't turn on.
I inadvertently pushed the wrong buttons on the control panel while trying to make a copy. I then pushed the buttons in the right order. The printer would not print. I turned the printer off: now I can't turn it back on. Help!!
    Genius:
  • 1,269 Answers
Try to unplug the power cable for about 2 minutes then plug it back in. Check if you can turn it on now. Double check the power plugs. Try to plug on a different power outlet.
Posted on Oct 22, 2008
My RCA Truflat T.V won't turn on and the FPA lock is turned on, I have the original remote. what should i do?
TV won't turn on • Press the TV button. Make sure the TV is plugged in.• Check the wall receptacle (or extension cord) to make sure it is "live" by plugging in something else.• Something might be wrong with your remote control. Press the POWER button on the front of the TV. If the TV turns on, check the remote control solutions on page 26.• The front panel controls may be locked (disabled). Use the remote control to unlock the front panel controls by selecting the Lock Fr. Panel in the PARENTAL CONTROL menu and press OK (box won't have check mark).Buttons don't work
• If you're using the remote control, press the TV button first to make sure the remote is in TV mode.• The front panel controls may be locked (disabled). Use the remote control to unlock the front panel controls by selecting the Lock Fr. Panel in the PARENTAL CONTROL menu and press OK (box won't have check mark).• Unplug the TV for two minutes and then plug it back in. Turn the TV on and try again.TV turns off unexpectedly • Sleep timer might have been activated. Go to page 24 for instructions.• KidPass might have been activated. Go to page 21 for instructions.• Wake-Up timer turned on the TV and no remote or front panel buttons were pressed for two hours.• Electronic protection circuit may have been activated because of a power surge. Wait 30 seconds and then
turn on again. If this happens frequently, the voltage in your house may be abnormally high or low.
• Unplug TV. Wait five minutes. Plug it in again.
Sep 16, 2011 | RCA 20F420T 20" TV
I moved my washer and then moved it back. The status shows control locked. How do I get it back operational
The "Control Lock", this is actually a safety feature that enables the consumer to lock the control panel to prevent small children from manipulating the controls and accidentally starting the appliance. This can usually be reset and does not require a technician.
With the lock on, the control panel is disabled and you cannot use any of the controls, except the button that unlocks it. Using the STOP or CANCEL buttons will not turn the feature off. It can inadvertently be set following a power outage, leaning against the control panel, or pressing and holding the wrong button. This is usually not an indication of a malfunction.
While you were moving the washer, you may have been pushing on the some of the control panel buttons and locked the control panel.
If this is a Whirlpool manufactured appliance (such as Kenmore Elite, Whirlpool Duet or Maytag Epic), the following link explains how to lock/unlock this feature:
http://www.fixya.com/support/r3608801-control_panel_lock
These instructions are also printed on the front panel of the appliance and in the owner's manual.
If this does not correct your problem, then you may have a more serious problem than a simple operator control button issue (such as an operator console problem or main control board issue). Please post back and let me know if you need further assistance.
May 15, 2010 | Whirlpool Duet GHW9150P Front Load Washer
What does it mean when it says scanner failure?
Hello it means that the scanner bulb temperature is too low or there is some internal or external electrical malfunction.Try these solutions.
1.Check the scanner light.Make a color copy of any document by pressing the Start, Copy, Color button on the product control panel.While the product is making the copy, lift the scanner lid slightly to see if the scanner light is visible.
2.Make sure that the room temperature is suitable for your device
3.Perform a Power Cycle on the unit by following the steps below:
1.Turn the unit off.
2.Unplug the power cord from the unit.
3.Wait 30 seconds, and then re-connect the power cord to the unit.
4.Turn the unit on.
5.Make a color copy by pressing the Start Copy Color button on the control panel.
4.Check the power connections.Disconnect the power cord from any power strips or surge suppressors and then plug it directly into a wall outlet.Try making a color copy by pressing the Start Copy Color button on the product control panel.If the error message displays again, temporarily move the product to a different room, or plug the power cord into a different wall outlet.
5.Perform a partial reset
1.Disconnect the power cord from the product.
2.Press and hold # and 3 while reconnecting the power cord to the product, and then release both buttons.
3.Try making a color copy by pressing the Start Copy Color button on the product control panel.
6.Perform a semi-full reset(Performing a semi-full reset deletes any saved phone numbers on the product).
2.Press and hold # and 6 while reconnecting the power cord to the product, and then release both buttons.
If nothing of these works and you still see the error you should take your printer to support service for repairing the parts.
Feb 08, 2010 | HP OfficeJet d145 InkJet Printer
All lights are flashing. Tried turning the printer off. tried resetting. Checked that the doors are closed, cartridge in all the way.
Try resetting the printer to factory Defaults. First turn off the printer, then open the front cover like if you were to take the toner cartridge2_bing.gif out. Once the front cover is open then push and hold the two buttons on the panel of the printer and turn the printer on. Make sure the front cover is open and that you are pushing the two buttons all the lights will flash2_bing.gif and they will stop at the very bottom light and stay solid once that happens let go of the buttons and close the cover and that should reset the printer. If that does not fix the problem then it could be something wrong with the Controller Board and will probably need to be replaced.
Jan 26, 2010 | Lexmark E234 Laser Printer
Washer does not go on control locked light stays
You may have inadvertently locked the control panel. Before assuming you have a malfunction, read the following: The Control Lock is actually a safety feature that allows the consumer to lock the control panel to prevent small children from manipulating the controls. It can inadvertently be set following a power outage, or by leaning against the control panel. The following link explains how to turn the feature on/off:
http://www.fixya.com/support/r2469429-kenmore_elite_amp_whirlpool_duet
These instructions are printed on the front panel of the appliance and in the owner's manual. If this does not correct your problem, then you may have a more serious problem than a simple operator control issue. If you need further assistance, please let me know. I hope this corrects the problem for you.
Dec 29, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
I am getting a control locked prompt. I have tried pushing the reset for 30 seconds but it still gives me the same prompt. Is there another solution?
The reset or cancel button does not control the locking feature. The following link explains how to correct a control panel lock issue on a Whirlpool Duet:
The control panel lock is actually a designed safety feature that allows you to lock the control panel to keep small children from manipulating the controls. It can be inadvertently set by leaning against the control panel buttons, or following a power outage.
If you have questions, please let me know. I hope this helps you.
Oct 01, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Language
Try this:
  1. Unplug the power cord from the back of the product.
  2. Press and hold the # and 6 buttons simultaneously on the control panel, and then reconnect the power cord.
  3. Continue pressing the buttons until the display goes blank or Reset shows on the control panel display.
  4. If the product automatically turns off, turn it on. CAUTION: Do not perform a NVM resets before the initialization process is completed on the product.
  5. Allow the product to fully start up, and then select the correct language code and country/region when prompted.
Nov 03, 2008 | HP Photosmart C6100 All-In-One Printer
HP C5180 not printing but copies????
These are the steps for windowsxp
For windowsVista after control panel go to Printer or hardware and sounds to go to printers
First check the printer icon. ( Make sure the printer is turned on during this process)
Go to Start> Control Panel (or setup then contro panel) and then go to Printer and faxes (or printers and other hardware)
And check that the printer Photosmart C5100Series has a check mark.
If not right click on the same and left click on Set printer as default.
Next make sure the printer icon says 0Ready.
If not right click on top of the Photosmart C5100Series icon and left click on Clear all documents (untill it says 0ready)
If not try rebooting you computer
then try printing any documents
Good Luck
Oct 03, 2008 | HP Photosmart C5180 All-In-One InkJet...
Resetting to "normal" print
I am guessing that you do not have the Manual.
Try this site for a Manual:
http://support-au.canon.com.au/EN/search?canonsearch=1&lang=EN&category=All-in-One+Printers&series=All-in-One+Printers&model=PIXMA+MP780&menu=Manual
It should have the instructions you need.
Have you tried the Printers Help pages?
Good luck.
Apr 03, 2008 | Canon PIXMA MP780 All-In-One InkJet...
Range shows 'SA 66" in display
After calling customer service with no satisfaction, I did a Google search for SA66 which turned out to be really SAbb code. I found out that this is a special "Jewish Mode" that I somehow turned on while pushing the touch pad disabling it. To end the "Sabbath Mode", Press CANCEL/OFF FOR ONE SECOND, then press and hold Number Pad 6 for five seconds. It worked!
(You can also press and hold the Number Pad 6 for five seconds first, followed by CANCEL/OFF.)
Mar 07, 2008 | KitchenAid KESC307 Electric Kitchen Range
Dell 922 All-In-One InkJet Printer Logo
42 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
