Question about Samsung HCL5515W 55" Rear Projection Television
PCL5415R conv. board problem. Having trouble finding part number. I have the manual Samsung
I have been told that my convergence board on my PCL5415RX/XAA is bad. I bought the manual but am unable to find the "CONVERGENCE BOARD", I have been told part number is AA95-00705A. I am not a TV repairman but have very good electrical skills. Can someone help? Samsung is useless when it comes to tech support. I have the picture breakdown and parts list that I could e-mail to someone. THANKS
  • Rogee4659 Nov 04, 2008
    Hi I am having the same issue with my PCL5415RX/XAC TV as well. I ended up havi ng a local repairman come to my home and see what the problem was. he said it was the Convergence board part # AA95-00705A. They quoted me a total of $400 to repair. I'm assuming that a person could just replace the board as long as everything hooks up the same. Any thoughts out there? Is it as simple as just getting the part online and replacing it oneself? Or would there be other issues to contend with?
    Thx,
    Rogee
  • Samsung Master
  • 5,568 Answers
I'll take a look if you want to forward them to me:
freetek@lycos.com
This convergence board problem seems to be very common and if they are not too model specific (firmware embedded) there may be service companies repairing them. I don't; haven't done a whole lot of service for years partially due to the difficulty of trying to pry stuff out of the hands (or shelves) of Asia.
Posted on Oct 13, 2008
Convergence board
A bluish picture is not a result of its bad convergence board. Check its video output card, for any loose solder terminals or damaged component/s. If you wish to get some details, check the site linked here. http://electronicshelponline.blogspot.com/ Pull up older posts. Check the site in 'Mosaic' view. It will make search easy.
Jan 04, 2014 | Samsung PCL5415R TV
I have a samsung rear projection tv manufactured 2/2003. model #PCL 5415R. PROBLEM: convergence Need part number of convergence card and where to purchase it.
Please save your money and get this unit repaired, just because the set displays a "Convergence"SYMPTOM does NOT mean that changing that board will fix the unit, 9/10 it will NOT. I see this time and time again in the shop whereby people think they can fix their TV whatever, and mistake the SYMPTOM, for the cause and try to fix, usually unsuccessfully at that. The CAUSE must be repaired as well as the symptom, simply replacing a board will seldom "Repair" anything as the original fault that caused the symptom still has NOT been fixed. Please get a "Quote" they are free and at least then you will know what is the problem, even if you decide NOT to repair you have that information.Also one MUST have a Service Manual to be able to order the parts as without this number you simply cannot get parts.. it is that simple.
Mar 17, 2010 | Samsung PCL5415R TV
I need a new convergence board, can I install it myself? Where would I find a convergence board?
I presume actual model number is PCL5415R---you can buy the
AA95-01799Rboard--it is available :
I would suggest since it is over 100 dollars it makes more sense if you have a convergence problem to buy and replace the two STK-392-040 convergence chips on it--there may be a fuse on the board bad--easy to find--
You can buy a pair of the chips on Ebay for less than 20 dollars
Let me know if you have questions--I have seen people who replace the board have new problems-cheaper and better to repair the one in the set.
I am here to help people--if this information helps you rate this solution--I do this here for free.
SD TECH
Nov 02, 2009 | Samsung PCL541R 54" Rear Projection...
Samsung model number PCL5415R The blue bulb is weak. where can i get one and can I replace it it is a 52inch projection HDTV ready
You may also have a problem with the convergence. There are three color cans that project the image on the screen. A red one, green one and a blue one. The blue one is the one that you should try and adjust. Have you tried to realign the convergence yet? You should be able to go into the menu setting and locate this option is is typically done using the remote. What you will see is some cross marks starting in the center and move to the four coners. When you adjust it you will want to align all three (red, green and blue) crosses where neither color is more prevalent. If you are unable to get the blue can to align with the others, there is a problem with the convergence board. These boards or ICs can be replaced, if you have a repairman fix it your looking at around $250 - $400. If you would like to fix it yourself you can get the parts from...
http://nfm.partsearch.com/Model/Samsung/Samsung/PCL5415R.aspx
NOTE: "Most of the text above was gathered from another online source"
Aug 28, 2008 | Televison & Video
Greenlines on pcl5415r
I suspect the convergence ics bad. samsung takes stk ic cost if you had it done is 250.00 If you can solder you could replace them , part are 30.00 total
good luck doctor video
May 18, 2008 | Samsung PCL5415R TV
Samsung SP43J5HF Rear Projection Tv
Hi Daml
You can find this part from Samsung UK , click HERE to check it out and also to order it. Delivery is within 7 days.
Could unfortunately not find anything for Australia.
Let me know if you need any further assistance.
Thanks for using Fixya !
Apr 30, 2008 | Televison & Video
My samsung projection tv #pcl5415r don't want to perform perfect focus adjustments
perfect focus functions are based on service mode setup...or factory settings. if the alignment of these setting are loss then the unit wont perfect focus. does the unit have a complete loss of convergence. a complete loss of convergence indicate possible failure of convergence amps.
Jan 03, 2008 | Samsung PCL541R 54" Rear Projection...
Convergence out; having problems realligining red lines
Check all six small,soldered in pico fuses under IC heatsinks..
rated at 3.15 amp = do not exceed.............let me know.....T.
Nov 27, 2007 | Sony KP-51WS500 51" Rear Projection...
SAMSUNG PCL5415R
Probable bad convergence IC's---STK units on large heat sink.
Also,possible blown fuse (soldered-in) hidden under heat sink.
Samsung is known for making the fuse devices hard to find.
Let me know if you need more help....T.
Oct 19, 2007 | Samsung PCL5415RB 54" Rear Projection...
Samsung 54" rear projection PCL5415R Won't Turn On
Although I am not incredibly familiar with your model, There is most likely a small board mounted above the others near the crts, there is a small red connector with a blue wire if you unhook it it will remove power from the convergence IC's and if they are shorted it might come up with conv out, will need a new module.
May 04, 2007 | Samsung PCL5415RB 54" Rear Projection...
Samsung HCL5515W 55" Rear Projection Television Logo
206 people viewed this question
Jerry Greenberg
Jerry Greenberg
