Canon PIXMA iP4200 InkJet Photo Printer
Problem for Canon PIXMA iP4200 InkJet Photo Printer
Canon ip 4200 printer problem
By Jimmy NY - usenet poster
My new Christmas canon ip4200 printer is breaking my heart!!!!
Specifically, it won't pick up photopaper from the "tray"compartment. I
don't understand what happened. It worked great 3 times, but now just
sends a message that there is no paper in the tray. Well, it's the same
paper that worked just fine 3 times!
I've read the manual, quadruple-checked for orientation, paperjam
etc
It prints just fine from the manual feed.
Please help.
Thank you
Same Problem
Aug 02, 2008
-   paper won't feed from tray. continues to tell me to reset-   murses
May 17, 2008
-   I've had the same printer for a couple of years and I just started having this problem. I followed the instructions in the User's Manual to clean the paper feed rollers but it hasn't fixed the problem. The Manual says to not do this too often because it "consumes" the paper feed rollers. I fear I may have to buy a new printer. -   rosygirl
Best Solution
posted on Jun 10, 2008
Very Helpful)
sajibgp
Rank: Guide
Rating: 87%, 7 votes
Service error 6A00 Cancel printing and turn the printer off and then back on.
If this doesn’t clear the error, see the printer manual for more detail.
Was this helpful?
Yes
No
Solution #2
posted on May 27, 2006
Helpful)
Perkins
Rank: Apprentice
Rating: 0%, 0 votes
My interpretation from the book is that photo paper is best fed from the
top, but any normal weight (20-24 lb) paper can be fed from the tray. It is
a tougher track for the heavier papers in the tray.
Was this helpful?
Yes
No
Solution #3
Somewhat Helpful)
Ranny
Rank: Apprentice
Rating: 0%, 0 votes
Thank you truly for taking the time to answer.
I can hear the ink carriages move and also hear the back of the plastic
tray flip up, but the feed rollers do not seem to move (I observed this
with the back door flipped down).
As i said, I don't understand why it worked fine only last week & I
haven't touched it since.
I'm using the 4x6 canon photo paper & it is in the tray oriented
properly.
What next?
Marc
Was this helpful?
Yes
No
Solution #4
posted on Aug 11, 2007
Not Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Maybe you should check the paper feed setting on the printer properties. Try change it to automatic feed paper
Solution #5
posted on Jul 14, 2009
Not Rated)
masabuj
Rank: Apprentice
Rating: 0%, 0 votes
error 6a00
Was this helpful?
Yes
No
Solution #6
posted on Sep 24, 2008
Not Rated)
basar122
Rank: Apprentice
Rating: 0%, 0 votes
i have same problem pl. give me solution
Was this helpful?
Yes
No
Solution #7
Not Rated)
Bomber
Rank: Apprentice
Rating: 0%, 0 votes
If you look into the paper feed area, can you see the feed rollers turning,
but the paper not moving? If so, I would try to wipe off the feed mechanism
with a damp cloth. I can't imagine that it should need that this soon out of
the box. If that doesn't help, I can't offer another suggestion. Does the
photo paper you are using meet the Canon specs?
Was this helpful?
Yes
No
Popular Solutions for Canon PIXMA iP4200 InkJet
Questions and Unsolved Problems for Canon PIXMA iP4200 InkJet
Do you recommend Canon PIXMA iP4200 InkJet Photo Printer?
Answer
Answer
I have a problem with the paper feeder.The printer worked a minute ago when I printed a thick sheet,... (More)
Answer
I've a iP4200 printer. The waste ink absorber is full & needs to be replaced.
Answer
The middle light keeps flashing and does not stop -(No paper jam) - light blink 3 times the stop... (More)
Answer
The printer is not very old...I am having trouble with the paper feed. ..paper crumples a bit in rt... (More)
Answer
Prints in green and small black cartidge stays alight
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Canon PIXMA iP4200 InkJet...:
Top Printer Experts
Rank: Guru Guru
Solutions: 745
Experience: 30 Years of professional repair and design.
Ask Me
Find more Printer Experts
Top Printer Repair
(800) 836-9287
Celebrating 14 Years Of Outstanding Printer Repair...
Laser Repair 911
(918) 583-5483
Elite printer Services, Inc. is a full service HP...
Elite Printer Services
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
