Question about Quartet gbc Shredmaster 2240S (Strip-Cut) Shredder
I need wiring diagram
The chain came off and tore the wires from on and off switches ,i need a wiring diagram to reinstall wires
  • 58 Answers
Contact Michael Business Machines for your local dealer 1-800-223-2508
Good luck, Tom
Posted on Mar 27, 2009
20 year old Hampton Bay fan requires new 3-speed pull chain fan switch replacement. I did not copy the wiring pattern for the L, 1, 2 and 3 positions. There are 3-wires: black, white and blue.
Typically AC wire protocol designated black = line voltage (means \'death\') and white is neutral (cold).
The blue one will be a switched line to the motor and a meter capable of checking continuity should allow you to determine the proper wiring.
Oct 14, 2014 | Hampton Bay Dryers
Hi has anybody got an wiring diagram for a 1985 jcb 814 as kids have tore out all the wiring and ignition switch
Man, you have a problem!! Try ebay or a used machine breakers yard for a used harness. There are dvd's available for the JCB range covering parts but you may get one for wiring. Try the JCB owners forums for help
Aug 15, 2014 | Electrical Supplies
I have an jcb 814 and kids have tore out all wiring and ignition switch has anybody got a wiring diagram
See an old fixya regarding an 814 slew problem. A reader offered this guy a diagram, dated Oct 25th, 2013. Don't know if you can back track?
Aug 15, 2014 | Cars & Trucks
I did not make a diagram when replacing the light switch
Red from switch goes to two blacks, blue from switch goes to two blacks and the black wire goes thru top of light and attaches to blue fan light wire. If you want a good fan, look for blade pitch(13 degree or higher)Or CFM's above 5500 on high.
Oct 02, 2013 | Hampton Bay 24002 Ceiling Fan
Cannot turn off a pull-chain fixture
It sounds like you have accidentally by-passed the switch. The switch only needs one power leg to the pull-chain switch and the other 3 wires go on the other wire of the switch. The white wires get connected together as you have done.
Please turn off the power before you make a change.
Sep 19, 2009 | Kitchen Appliances - Others
I need a pull chain DIMMER switch for my fan light. Only one set of wires supplies the fan and light. Surely SOMEBODY has a pull chain dimmer ??? Thanks. Bill
Bought three fans for the bedrooms, all hunters with pull chain dimmers. Less than one year and two of the three dimmers are shot. Can't find a replacement so I bypassed it. Remove light assembly and unplug 9pin connector. Remove black vented dimmer assembly by removing wire nuts and disconnecting the 2wire connector(black and white wires). Cut the 2wire connector off and save it in case you find a part someday. Wire nut black to black(hot) and white to white(neutral). You will disable the pull chain by wire nutting those two wires together.
Jul 29, 2009 | Hunter Ceiling Fan Light Switch Control
Which color wires connect to pull chain switch
do you have a Menards, or a Lowes in your area, if you do they can give you the answer to this question, it is a bad idea to get this information from on line unless you go to the website for the fan and see if they have the correct wireing diagram on their website......
Jun 27, 2009 | Craftmade International Craftmade Omni in...
Ignition wire came lose inside my stihl 210c chainsaw .
28866.png This is the only diagram that is offered for this model but on the multifuntion switch (#33) The wire is layed through the upper part of it with the metal connector sticking out of the left side and once there you will pull the wire to the right until the metal connector is seated in the switch. After this reinstall the switch into the handle houseing and make sure that the contact spring (#24) is sitting on top of the switch and when in the off possition making contact with the metal conector of the wire on the switch.
Mar 15, 2009 | Oregon Scientific Oregon Chainsaw chain...
Quartet gbc Shredmaster 2240S (Strip-Cut) Shredder Logo
333 people viewed this question
Top Quartet gbc Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Quartet gbc Office Equipment and Supply Expert? Answer questions, earn points and help others
