Question about Toshiba CF20F40 TV
Toshiba CF20F40 Hi I have a Toshiba TV that makes a clicking sound when it is turned on or plugged up. However, there is no sound or picture. The red light on the front of the set flashes on and off. Do you have any idea as to what the problem could be. I have checked the fuses in the inside of the TV and they are not blown. Any assistance is greatly appreciated.
    Champion:
  • 252 Answers
If you had a knoledge in electronics, check the H.O.T transistor, is a big transistor beside the plyback.
Posted on Oct 13, 2008
No picture or sound
Looks like a power supply issue the only solution to fix this up is to get it repaired.
Goodluck..
May 03, 2008 | Toshiba 32HFX72 32" TV
50" rear projection Toshiba TV.
Sounds like the tv is overheating. Make sure you arnt placing it in a area that will trap the heat like in a corner of a room. You can always put a fan blowing by the back of the tv too so there is some added ventilation. Let me know how it goes!!
Aug 24, 2011 | Televison & Video
Toshiba model 42hp66 Plasma flat screen Problem No picture or sound. Pushing on button 2 clicks are heard A slight hum is heard at the Z SUS board. Green power light is on (power light is...
Hi
There are some factors of this kind of problem.
First you could have a failure in the power supply. Next could be the main board. Lastly you could have a problem with the panel itself, this would mean a new set for sure because the part cost is more than a new set.
However try troubleshooting the problem before spending money on repairing or replacing the television. Possibly you can restore the picture and sound to your television ...
Verify the TV is powered on by pressing the power button on the TV's remote or the front panel of the set. This may seem like an obvious step, but many TVs are equipped with a standby light that will illuminate if the TV is turned off, making it appear that the TV is on when it is not.Cycle through the TV's video inputs to verify that your TV is set to the right one. For instance, if you are attempting to use a digital cable converter box that is plugged into the Video 1 input and the TV is set to a Video 2 input that has nothing plugged into it, the TV will not display any picture or sound and may even say "No signal" on the screen. To cycle through the inputs, use the input selection button, typically labeled "input," "source," "TV/video" or the like.
Re-seat the video and audio input connections to verify a loose cable is not causing the TV's loss of signal. If you have a coaxial cable connected from your wall cable jack directly into the TV, it may have come loose thereby eliminating all picture and sound on the TV. Locate the connection cable or cables of whatever device you are attempting to watch and unplug them from where they plug into the TV. Plug them back in and check for a signal. If there is still no picture or sound at this point, the best option is to contact technical support for further assistance.
Apr 22, 2011 | Toshiba 42HP66 42 in. LCD Television
Tv clicks on red light comes on then begins to blink no picture
Well it seems more to be an issue with the ballast, that doesn't have enough voltage to keep on with the lamp. And the ballast is trying to ignite, that's why you hear that clicking sound. Ballast are not that expensive, they're running around 60-70 dlls, It's worth to try.
Jul 30, 2009 | Toshiba TW40F80 40" Rear Projection...
Red light flashes on power switch, but no picture or sound on tv
tv will not power on. red light on switch blinks. power relay clicks, but no picture or sound.
Jul 28, 2009 | Toshiba DVD Recorder AND Series2 TiVo...
Toshiba tv will not turn on
I have a toshiba tv and it will not turn on. There is a flashing green light that comes on, but there is no picture or sound.
Oct 31, 2008 | Toshiba DVD Recorder AND Series2 TiVo...
Theatre View Toshiba Rear Projection TV 50 Inch with no sound or picture and a red light keeps blinking
I have the sames t.v you have to go in the back flip the power cord switch...then reboot the t.v.
Jun 27, 2008 | Televison & Video
Televison & Video Logo
57 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
