Question about LG WM-1832C Front Load Washer
Start/pause button doesn't work
My LG WM-1832CW front load washer will not turn on once it has been programmed for a load. All the lights are on, but it fails to acknowledge the pressure on the button. It started by doing this occasionally, then more regularly, requiring several presses of the button. It became more and more difficult to start until now, when it will not start at all.
    Problem Solver:
  • 6 Answers
I had this problem with another model LG washer dryer and the problem was just the tiny switch (6mm x 6mm) on the circuit board had worn out. They cost about 30 pence on eBay and are very easy to remove and re-solder onto the circuit board as there are only 2 pins. This saved a huge amount of money for a new control board.
Posted on Mar 28, 2014
  • Mr Fix it
    Mr Fix it Mar 28, 2014
I have exactly the same problem. Could redlea acknowledge if your problem has been solved?
Posted on Mar 15, 2009
  • LG Master
  • 19,396 Answers
You need to replace the whole control panel assembly.
You can find replacement parts by clicking here and inserting model number.
Posted on Oct 13, 2008
Can I get an on line manual for model # WM-2233HW LG front load washer
Yes, LG has the user's manual for the WM-2233HW on the product site. Click on the Support tab here: http://www.lg.com/us/appliances/washers/LG-WM2233HW.jsp . The link to the manual is on the right side of the page. The manual is in a pdf so you will need Adobe Reader or a similar program to read the file. The direct link appears to be http://www.lg.com/common/product/support.jsp?localeCd=US&productId=WM2233HW&uri=/us/appliances/washers/LG-WM2233HW.jsp&categoryIdCms=2# . If this link doesn't work, please start at the first link I provided.
I hope this helps.
Oct 02, 2011 | LG WM-2277HW Front Load Washer
Why does my lg front loader washer wm-1832cw sometimes give anle code and sometimes works
you have either a hall senser /stator/or main board/problem.... may even be a voltage issue. check your recepticle see if its good. easy first check plug to see if its been arking on the plungs
Jun 03, 2011 | LG WM-1832C Front Load Washer
I'm getting a LE code on a LG 2277HS front load washing machine.
http://www.fixya.com/support/t260950-lg_tromm_wm2277hw_will_not_spin_both
Jun 04, 2010 | LG WM-2277HW Front Load Washer
Washer will fill up with water but will only spin
is it noisey on spin? sounds like control board to me. try this , open door and turn steel bowl by hand, left then right. if u can turn the bowl in both directions it is not the bearings. please reply 4 more help.the bowl should turn free in both directions.
Apr 14, 2010 | LG WM-1832C Front Load Washer
Lg intellowasher model wm 1290fhb door will not open. tried waiting 1 hour! tried power on and off, tried child lock
  1. Press the SPIN SPEED and SOIL LEVEL buttons simultaneously.
  2. Press the Power button, while pressing the SPIN SPEED and SOIL LEVEL buttons. Then buzzer will sound twice.
  3. Press the Start/Pause button repeatedly with about 1 second interval until the lamps goes out.
  4. The washer powers off and unlock the door.
Oct 18, 2009 | LG WM-1290FHB Front Load Washer
I need the user manual for my lg tromm wm2277hw because I don't know how to get it to spin without going through the whole wash cycle
for a drain and spin : turn unit on hit spin Button 1 time then start/pause button
this a drain and spin only..
Jun 15, 2009 | LG WM-2277HW Front Load Washer
Lg 1832cw
Mike, you don't need to yse any glue cause it is a press fit bearing. I had to do the same thing. I was able to go to my local bearing supply for replacements. And it was much cheaper that going to an online place to buy them. It pay s to search.
Jim
Nov 16, 2008 | LG WM-1832C Front Load Washer
LG WM 1832CW
if your getting LE code on your LG washer check if your hot and cold water is hooked up right
Jan 27, 2008 | LG WM-2277HW Front Load Washer
"CD" ERROR ON LG WM-3677HW Front Load All-in-One Washer / Dryer
CD means cool down, press the pause start button, the door lock will open. It is an anti crease cycle. It mentions it in the owners manual, but it is hidden deep in the drying section.
Sgt 48
Sep 01, 2007 | LG WM-3677HW Front Load Washer / Dryer
LG WM-1832C Front Load Washer Logo
724 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
