Question about LG LS-L1210CL Mini Split Air Conditioner
NOISY FAN ON CASSETTE UNIT
I AM A HEATING & A/C CONTRACTOR, HAVE A CUSTOMER COMPLAINS THEIRLG CASSETTE UNIT WHISTLES AT LOW SPEED.
FILTER IS CLEAN, COULD NOT FIND MODEL # ONLY SERIAL#605KANY00071. PLEASE E-MAIL POSSIBLE PROBLEMS.
ALSO NEED NEAREST SUPPLY HOUSE FOR PARTS IN CODE AREA
60510
THANK-YOU LEROY
  • 30 Answers
Probably Ball Bearing Problem Replace Axial Fan Motor Ball Bearing Will be ok Almost Done
Good luck
Posted on Feb 16, 2009
When a air conditioner freezes up can one put it on fan low speed
If the unit is freezing up then you have a problem. One is the air flow is to low going through the evaporator coil this could be caused buy a dirty filter, dirty coil and fan blade or low freon charge. the lower the fan speed the colder the coil temperature. the coils and unit should be cleaned every year. running your unit on low is not a good idea.
Jul 08, 2014 | Samsung AW1203B Air Conditioner
Is it OK to set fan speed control to Low?
you can turn this too low but the heat exchanger will get hot and you will have less air coming out of the vents it should be set to makes spec . gas fed to burners has nothing to do with fan speed ,have you oiled the fan motor
May 08, 2012 | Heating & Cooling
I have a continental elec port. air. Not sure of model. Cools great but when compressor kicks on unit make a loud whistling noise. Cleaned filter no help.
although annoying, at this time i would not mess with it, the fan motor needs oiling (zoom spout oiler ) works the best .. you can find how in my other postings.. try running the unit on a lower fan speed... some cool is better than NONE
Jul 28, 2011 | Continental Electric Portable Air...
Do you know of a way to slow down the LOW speed fan setting on a Kelvinator KSE70HRA air conditioner? Low is very noisy and blows air like a HIGH setting.
Hi, no, im sorry if it is on low already, it can't be changed to go any lower. The only thing I can come up with is the fan motored is wired wrong, and they have the high or med lead connected to the low speed, as it should run slow. On a central air system, there is a board that is in the indoor unit that shows the fan speeds, and they can be changed.I didnt look up your unit, and if it is a central air and not a window unit, you can change the speeds at the board. The wires are colored, blue is normally low, red is Hi, and blk or yellow is med. If this is a window unit, there is nothing much you can do. If you know anything about electrical, and you have a 3 speed fan, pull the cover to get to the switch back, and see what leads the have terminated to the switch. They may have it miswired. I wish you the best of luck,
Shastalaker7
A/C, Contractor
Jun 12, 2011 | Heating & Cooling
The air unit is frezzing up and the air is never under 70 degress in the house! whats making it keep frezzing up?
Hi, when the unit freezes up, it is either low on freon, a plugged a/c filter, or the evaporator coil is dirty and will need to be cleaned. When the evap. coil freezes up, the blower motor can't blow air through the coil. Check the filter, and behind the filter to see if the coil is dirty, just remove the screws to excess the evap. coil on this unit. Make sure the blower motor is running up to speed also. You will know. If the coil is dirty, try and clean it the best you can and replace the filter. If it continues to ice, you will need to have the freon level checked> These are the # 1 causes of coils icing up. Please let me know how it turns out.
Sincerely,
Shastalaker7
A/C, Heating, & Refrigeration, Contractor
Aug 17, 2010 | Intertherm P3RA-048K Air Conditioner
New Ruud 16 seer central air and heat pump - very noisy
A few things to check
1) Is the unit mounted on metal brackets attatched to
the house, is so I would probably put rubber pads
between the unit and the brackets to absorb the
vibration.
2) Same is tru if sitting on a concrete or plastic pad.
3) Some units come with the compressor that has
an insulated jacket around it, this is also for noise
reduction.
4) The fact that you replaced an older unit with a newer one could also mean that you have a bigger blower.
5) Which leads to the unit not performing because
it may have not been set up properly.
6) Take the door off the unit, make sure power is turned off. Usually on the left hand side of the indoor
unit it will list the temperature rise that this unit
requires. I`m guessing between 25-45 deg.
7) This is the temp. difference you would measure
on the return air near the furnace. Then Take a
temp. measurement in the Supply duct near the
indoor unit.
8) If its not within the range the furnace requires,
he needs to come back and adjust the fan speed
Jan 09, 2010 | Ruud Matching Split Air Conditioner
Lg window-type ac
Most little window units are mainly for 300-500 Square foot rooms.
Should be putting around 80-105 degrees top out of those little units, Make sure that your thermostat is set for heat rather then the normal setting of cooling (Turn more towards Heat) also if you have a fan setting you may want to try lowering the fan to low speed vs high fan, which should give you more heat.
Make sure the Filter is clean as well as the coils behind the filter or it will shut down the heaters quicker due to lack of air, shutting down your T-stat and bi-metals quicker.
Nov 11, 2009 | Heating & Cooling
Loud whistle noise kelvinator split KSR25F-01
It may be the small vent fan motor on the inside if the control panel. When the noise begins remove the panel and you may be able to catch it in the act.
Dec 27, 2007 | Carrier 36KCARMS Air Conditioner
LG LS-L1210CL Mini Split Air Conditioner Logo
199 people viewed this question
Top LG Heating & Cooling Experts
Donni Steen
Tim Whalen
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
