Question about MSI K7T Turbo2 Motherboard
Turn on issues
I have a msi k7t turbo 2 mother board that won't turn on. Can you help me to solve this problem?
    Genius:
  • 1,605 Answers
Take all accessories off the motherboad (network card, memories, etc) connect just the monitor, keyboard, and mouse. it fires up. then insert one accessory at atime and see what is keep it off. then replace it.
Posted on Oct 13, 2008
WE CANNOT DOWNLOAD THE MANUAL FOR THIS MOTHERBOARD. CAN YOU HELP..PLEASE.
download the manuals from this link:
http://www.iusermanual.com/motherboard/msi-k7t-turbo-motherboard-manual.htm
Jan 10, 2011 | MSI K7T Turbo LE (6330-200) Motherboard
What motherboard will replace a msi k7t turbo2?
This is an obsolete part; as such, you will have a hard time finding it at any retailer, whether brick and mortar or online. However, all hope is not lost-try E-bay
http://computers.shop.ebay.com/i.html?_nkw=socket+a&_sacat=1244&_trksid=m270&_dmpt=Motherboards&_odkw=&_osacat=1244
You will have to look for a board that supports S-Dram memory, because that is what your MSI K7T Turbo2 uses.
My advice would be to skip this entirely; I would replace the whole board/CPU setup, and pick up some memory. You can get an Athlon II quad core and mobo for $165.98 USD (Asus /AMD). Pick up 2 GB of Kingston DDR3 RAM for $56
http://www.newegg.com/Product/Product.aspx?Item=N82E16820134790
and you essentially have a whole new system for $222
Just my opinion on this-I don't think that spending the amount of cash you would have to in order to replace an obsolete board is worth it.
You might try this, instead:
AMD Athlon II x2 Regor (2.8 Ghz, dual core) @ 56.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16819103688
ASRock M3A770DE AM3 AMD 770 ATX AMD mobo @ 59.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16820148305
Total $174.97 + shipping USD
Given you 3 ways to go and my advice-good luck!!
http://www.newegg.com/Product/Product.aspx?Item=N82E16813157176
Crucial 2 GB Ballistix 240 pin DDR3 1600 Memory for $57.99
Feb 03, 2010 | MSI K7T Turbo2 Motherboard
MSI K7T Turbo Limited Edition USB Host to host bridge
hi frnd..
Just get a usb hub it will help u.. USB HUB is a collection of USB wic coonects to a sys via a single usb port
take care
Oct 01, 2009 | Computers & Internet
Need front panel connector diagram for msi 6330 ver 2.1 mainboard ALREADY TRIED 6330 LITE AND IT IS DIFFERENT LAYOUT
Hi there.
This is the configuration for that motherboard >>>>>>
Good luck and thanks for using FixYa!!
Mar 22, 2009 | Gateway Computers & Internet
Pinning layout for Micro Star WS 6330 motherboard
Hi Hunter45,
Download the manual from MSI, click on the link below.
MSI K7T Pro MS-6330
You'll need winrar or winzip to uncompress the manual & you'll find there are 5, *.pdf files rather than just one for the hole manual.
http://global.msi.com.tw/index.php?func=searchresult&keywords=K7T+Pro&table=download
File name: 6330-1.PDF will show the MB layout. Page 1-4.
You ca see the 2 USB pins to the left of JMDM1.
JFP1 close up;
Open file 6330-2.pdf, page 2-22 for the pin layout for the MB USB's.
If you need more information, post here.
Good luck Hunter45!
Thank you for trying FixYa.
Mike
Jan 19, 2009 | MSI MS-6330 Motherboard
MSI K7T Turbo2 No Manual
Hi, click on this MSI link which will open to the motherboard
K7T Turbo 2 (MS-6330 v5.0). Links for, Bios download, user manual & FAQ is listed at the top of the page in the blue in colored bar. http://www.msicomputer.com/product/detail_spec/K7Tturbo2.htm
You can run up to 1800 but it must be the AMD Athlon XP (Palomino, Socket A) up to 1800+
Aug 05, 2008 | MSI K7T Turbo2 Motherboard
AGP 4x-8x compatability on msik7t turbo
El único manual que pude encontrar es en Inglés, sino que debe contener información de conexión (inc diagrama) que puede utilizar.
Si el vínculo con el manual en la parte superior de la página da problemas, puede encontrar los enlace de descarga para que, en la parte inferior de la página; http://www.ecs.com.tw/ECSWebSite/Downloads/ProductsDetail_Download.aspx?detailid=422&DetailName=New&DetailDesc=741GX-M%20%20&MenuID=0&LanID=8
May 29, 2008 | MSI K7T Turbo Motherboard
Powered on MSI K7T Master Ver:1 motherboard and it beeps very frequently
Hi, it sounds like your RAM chips are not installed properly or are faulty, if you have 2 seperate sticks of RAM, remove them and install one at a time to test which one is at fault. make sure you use DIMM 1 for each RAM stick.
Regards mistyman
Nov 26, 2007 | MSI K7T Master-S Motherboard
How to set my fsb at 166
what ur mother full model number or name?
Nov 18, 2007 | MSI K7T Turbo2 Motherboard
MSI K7T Turbo2 Motherboard Logo
117 people viewed this question
Top MSI Computers & Internet Experts
vsri9
Alun Cox
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
