Question about Mitsubishi VS-50605 50" Rear Projection Television
Mitsubishi 50605 Convergence Board - Replacement?
Hi, Dan-
Thanks for your response to my posting on Fixya.com; I was bummed when my TV picture crapped out on me, but hopefully we can get it back!
I am comfortable working inside the TV, so any guidance/direction you can give me is greatly appreciated!
-Phil
racepoint68@yahoo.com
  • racepoint Oct 14, 2008
    Thanks, Dan. If you could post the repair instructions there, I'd appreciate it!
  • 4,234 Answers
I have responded to this in the original posting. I'd rather keep things there to retain the entire context.
Thanks,
Dan
Posted on Oct 14, 2008
The color and picture is not alligned
You have defective convergence. I have a tip at http://www.fixya.com/support/r4220499-change_projection_tv_convergence_ics which explains the problem, how to fix it and where to get the parts. Let me know if you need more help.
Thanks for using FixYa and for the generous rating.
hardrocko
May 13, 2010 | Mitsubishi VS-50605 50" Rear Projection...
Red tinted picture
HI,
Try reseting the TV first by unpluging all the cords for 4hrs and then plug it back.
I will be posting more troubleshooting steps..
Apr 03, 2008 | Mitsubishi VS-50605 50" Rear Projection...
Hour glass cannot adjust red horizontal convergence
The most likely cause is shorted convergence chips and possibly a few pico fuses.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
You can see some more examples and find a fix herebb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Oct 09, 2009 | Mitsubishi VS-50605 50" Rear Projection...
I have taken the back off and cleaned everything and i am still having an out of alignment coloring on the outsides of my tv. the middle is perfect bet the outsides, mainly the left side(my right facing...
Post shows its Mitsubishi WS-55511 TV, if that's correct then check convergence section for dry solder joints and resold these joints. Specially check convergence out ICs pins.
Below is an exploded image of main board of TV and convergence area is marked to have an idea...
Let me know if problem remains to check further options.
Thanks.
Jul 13, 2009 | Mitsubishi WS-55511 55" Rear Projection...
Hitachi 43FDX Rear Projection TV
If the picture was good prior to the 3D images, I would fix it. The convergence ICs either have poor connections or are defective. The IC is an STK392-110. There may be 2 inside the set. If you have this repaired, expect a labor cost in the $200 range. Request that the ICs be replaced rather than the board changed. This will maintain all of the internal settings and require only part replacement not a complete re-convergence adjustment.
Keep us posted.
Dan
May 01, 2009 | Hitachi 43UWX10B 43" Rear Projection...
Mitsubishi 50 inch projection tv
you probably have a problem with the convergence board.
Nov 13, 2008 | Mitsubishi VS-50605 50" Rear Projection...
Mitsubishi 50 convergence problem
If you can confirm the model number, I will provide the parts required as well as additional instructions for the repauir.
Thanks,
Dan
Nov 03, 2008 | Mitsubishi VS-5043 50" Rear Projection...
Mitsubishi 50605
Got the info. Working on my second 16 hour day. I'll update this tonite. Sorry about the delay.
Dan
Oct 17, 2008 | Mitsubishi VS-50605 50" Rear Projection...
Replacing the whole board will fix it, but is a bit of overkill. If you can solder and feel comfortable working inside the set, you can fix this yourself. Let me know if you wish to attempt the repair and I'll proviode additional details and instructions.
Dan
Oct 13, 2008 | Mitsubishi VS-50605 50" Rear Projection...
Mitsubishi Convergence Problem
you need to replace the convergence board but it will cost you around $200 to fix the board and components associated with it .......
Have you tried adjusting the convergence settings ........
Mitsubishi VS-50605 50" Rear Projection Television Logo
102 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
