Question about Hampton Bay 54 In. 5-Blade Fan, Chestnut, Autumn Mist
Noisy Low hum at low setting, louder as speed increases then a grinding and clicking noise starts, almost like a bearing noise or a flat spot on a shaft. Once and a while the grinding and clicking stops for a short while only to start up again.
    Scholar:
  • 157 Answers
Hello janeknows. The shaft of the fan motor may have a bearing gone bad. Follow these steps to locate problem. #1-turn power off by tripping the breaker, place your fingers on the shaft surrorting the blades & SLOWLY rotate the blades feeling for a catch or bump. A bump felt I suggest replacing the motor. No bump #2- remove the screws holding the cover supporting the control switches. Located among the wiring is a box with 2 or three wires. This is a capacitor. Note the info on the capacitor (1.4mf125v). Contact the fans Mgfr they may send you one for free if not visit your local hardware store and ask. Replace the unit using the wire caps in the unit or snip & strip the wire using new wire caps. Note witch wire went where. Turn power on and test operation.
Posted on Oct 13, 2008
  • Gene Pitts Oct 26, 2008
    Hello janeknows, Was it the big guy or the little guy?
Signs of awheel bearing going on a daf cf85 430 articulated lorry 2004 ?
Wheel initally with start making a washing machine noise or grinding sound when doing sharp turns the opposite of the wheel side as the outer race will generally go bad first. You may also notice the rim heating up due to friction. Grinding at low speed or a growling sound would dictate an inspection.
Mar 19, 2015 | DAF 44 Cars & Trucks
2003 ford sport trac front grinding noise from drivers side when sharp left turn
go to the magicmechanic website and send him this--hes the best there is and will rply
Jan 19, 2015 | 2003 Ford Explorer Sport Trac
Washer makes rumbling noise during spin cycle
You have to take the whole drum out and IT IS YOUR BEARING(s). Order all four of them
Oct 22, 2014 | Washing Machines
How to replace front bearings on 2001 mitsubishi montero sport?
Have them replaced
Go to You Tube Video & watch how
Do both sides
I would got to a local shop that has been there for
20 years,not a franchise
Jul 26, 2014 | 2001 Mitsubishi Montero Sport 4WD
Car makes a low pitch sound starting at 30mph & getting louder as speed increases. 1999 Buick Park Avenue Ultra w/ 3.8liter.
Check for uneven tire wear, make sure the wheels are properly balanced, check for proper tire inflation.
Low pitched noise that increases with speed is related to tires, wheel bearings, etc. Start with the easy and cheap remedies first... tire inflation, wear etc.
Nov 26, 2009 | 1999 Buick Century
I have a whirring or griding in my drivetrain. I can coast donw a hill and let the engine idle and I still get the noise. It doesn't sound any different going around corners and gets louder as the speed...
this sounds like(no pun intended) you have a wheel hub bearing assembly failing. they will start a whirring or humming noise and then a growling or grinding noise the worse they get. from your description it is a rotational noise and gets louder and maybe a higher pitch as the vehicle speed increases. have this checked out right away so no further damage is done. they are not cheap assemblies as most GM and Saturn vehicles have the ABS sensor built into them(if your Vue has ABS).
Nov 06, 2009 | 2004 Saturn VUE
2004 Chrysler Crossfire 25,000 mls auto, road hum noise
MOST of the hums after a while come from the diff as the back axle does the driving and almost all its life runs the same way except when going in reverse ,is the rear diff meshing and worn on both the crownwheel and the pinion and the humming gets slightly louder the faster you go and almost goes when almost stopped and this can also be the slight vibration you get so get the diff oil drained and refilled and check if there is any metal in the oil when drained if so thats your problem But it will last for years like that..Let me know how you get on RON
Oct 23, 2009 | 2004 Chrysler Crossfire
There is a humming sound coming from the front end of my 1999 oldmobile alero. Only happens when the car is moving. I dont hear itat idle or even when pushing the gas at idle. could it be my transmission...
Hello! If the humming noise is speed related(gets louder as vehicle speed increases)check front wheel bearings. If the noise goes away when turning one way or the other then it will most likely be in the front wheel bearing. If you turn the wheel(while moving)to the right and the noise goes away it is on the right side. If you turn the wheel to the left and the noise goes away its on the left side. Hope this information helps!
Sep 13, 2009 | 1999 Oldsmobile Alero
My 2003 wrx has increasing road noise - its getting hard to hear the radio - no grinding, no pops, grunting - just loud and louder humming above 40 mph - even when i put it in neutral. drives fine - could...
i want you to feel all 4 tires, feel for lots of flat spots. feel all the way around them. they might have flat spots on them. this will cause this noise. you neer to rotate your tires at 3,000 miles front to back. this will stop them from cupping out. thats what the tire store calls it. have your tires checked for balance when you rotate them. your tire with flat spots will make a good spare tire. switch the bad one to your spare to see if the noise gets changes
Jul 31, 2009 | Subaru Impreza Cars & Trucks
2000 audi a4- humming noise coming from rear of car
It could be a unevenly worn tire or a bad wheel bearing.
Mar 27, 2009 | 2001 Audi A4
Hampton Bay 54 In. 5-Blade Fan, Chestnut, Autumn Mist Logo
439 people viewed this question
Top Hampton Bay Dryers Experts
Steve
Craig Butler
Craig Butler
Are you a Hampton Bay Dryer Expert? Answer questions, earn points and help others
