Question about Sanyo SBM-20 Bread Maker
Broken door glass
Hi :
The glass of the breakmaker broke. A cup left on the countertop was innadvertently pushed by my son, and landed on top of the breadmaker, which was just about to be put away on its box, breaking the glass.
Do you know where I can get the part, and how to fix it?
Any help is greatly appreciated.
Americo Roman
romanacs@sympatico.ca
    Champion:
  • 204 Answers
I had great success in finding what I wanted for my breadmaker at http://breadmakerpartsemporium.ioffer.com/. They have manuals and parts for most breadmakers at very reasonable prices.
Posted on Jan 12, 2009
Viking Microwave door latch
Try pushing in on the door while pressing the door release latch;
Also, try pushing the door latch and reach under the front edge of the door and slightly pull as the latch is depressed.
Third option is use a suction cup, maybe from a GPS device on the glass portion of the door, pulling on it while you depress the door latch....let me know any problems or if I can help anymore.
Jul 27, 2014 | Viking VMOC205 Convection/Microwave Oven
Broken screen
That means the internal glass is broken. Get a new remote
Nov 30, 2013 | Philips Audio Players & Recorders
Neff B6774.0GB replace inner glass panel
open the door, loosen the two large screws (t20x or large flat head) near the top of the inner door, this will loosen the main outer door and you can slide it up and off. Look to the hinges and you will see retaining brackets held with two t20x screws, remove these and you then slide the rest of the door off enabling you to work on it on a flat surface. Lie it down with the broken glass as the lowest part. Remove two t20x screws from the two plastic holders near the top of middle frame, slide them out and remove the middle angled frame. Pay attention to which groove in the bottom of the door they are positioned for reassembly. You are now faced with a frame with absolutely mountains of t20x screws which will all have to be removed. when this is done, lift off the frame and you are left with the inner frame, broken glass and mesh panel. carefully take off the mesh screen and discard the broken glass ensuring that you do not inadvertently throw away the black thin seal (looks like a large rubber band). Use a toothbrush to ensure all glass is removed from the inner frame and that the inner edge of the frame is free from food debris etc (This is probably what caused the glass to shatter as the microwaves are attracted to food debris and would have cooked the glass causing a hotspot, this is usually evident if you look at the starting point of where the glass broke). Give the seal a clean also and reposition in the groove around the inner edge of the first frame. position the new glass panel, position the mesh screen and the middle frame. When putting all the screws back in, alternate them. left right top bottom until they are all back in (do not over tighten). Then reassembled the rest of the door by reversing the dismantling info. Let me know how you get on, please leave some feedback.
Nov 22, 2011 | Neff Ovens
The glasses and cups in the top rack have a sediment on them after the cycle is over. The dishes in the bottom rack are fine. Thanks
open the door and look inside the top of machine.
might be a rubber plug there. if plug is not water tight
or missing water will go thru and hit countertop. wet wooden countertop
equals sawdust like material thru to dishes
Oct 12, 2010 | GE Dishwashers
Can't find a part for a Broken door glass on KC010050B-1 countertop toaster oven.
Take the pieces to a local glass dealer & have him cut a replacement from tempered glass.
Jul 16, 2009 | Ovens
Left front drivers side power window went down but left glass up then glass fell down to bottom of door. I took door panel off and was able to push glass up but cannot get it on its tract or even see the...
Hello and thank you for using FixYa!
Most likely your window regulator cable broke. That is why the glass can not be controlled. You will need to remove it and inspect it to verify.
Thanks Jay!
Jul 11, 2009 | 2004 Nissan Titan
Broken glass top on my Maytag Schott Clean (upper
u have to replace the whole top and its about 400 to 500 dollars just for the part cheaper to buy new
Mar 20, 2009 | Maytag MER6772 Gemini Electric Kitchen...
REPLACIND DRIVER SIDE WINDOW REGULATOR
Pull out window crank and door handle, remove panel, remove plastic Nylon that's between metal and panel, crank the window down enough to see the arm and the part that connects with glass. Make sure the metal part inside the door that comes from an arm and attaches to glass is clean, from broken glass and the gap that attaches to window is clean,bend the new glass to make it fit inside the opening slide down the new glass from the top using opening guides, grave it from both sides standing in between and make land on top center of the part that graves the glass, put automotive glass silicone on center of that part,just at where graves the glass, let dry, put the plastic back the door panel the window crank with the "U" shaped lock washer and the door handle, I hope I was clear
Jan 21, 2009 | 2004 Chevrolet Silverado 2500HD
I have a 3 year old Kenmore range. There are openings at the top of the oven door. While cleaning, some soapy water went into one of these openings and left water dribble marks. How do I get inside the...
You'll have to remove and disassemble the door to clean the back side of the glass.
Open the door slightly. It should hold itself slightly ajar. Then lift the door straight up and off the hinges. Lay the door on a floor, table or flat countertop with a towel or rug protecting the door. The screws holding the door together will be on the bottom, top, and sides. Sometimes there are screws on the inside, holding the door handle and outer glass. Take care to notice how it's assembled, as getting it back together is sometimes tricky. By the way, it's best to lift the door by the sides, not by the handle!
Mar 10, 2008 | Kitchen Ranges
Top oven front glass broken want replacement
WHERE CAN WE BUY REPLACEMENT GLASS FOR AN OVEN
Dec 10, 2007 | Zanussi ZHQ575 Electric Double Oven
Sanyo SBM-20 Bread Maker Logo
32 people viewed this question
Top Sanyo Kitchen Appliances - Others Experts
David Payne
David Payne
Gerry Harvey
Gerry Harvey
Irene Tulloch
Are you a Sanyo Kitchen Appliances - Other Expert? Answer questions, earn points and help others
