Question about Smeg Dishwashers
My smeg dwi 710 dishwasher keeps flashing on the diplay panel and won't change to another wash selection. it wont close and wont start. the light is stuck on the heaviest wash selection and just keeps flashing on and off and on and off. i have tried turning it off, keeping buttons held down and nothing seems to work. there is nothing in the manual that says what the flashing means so i dont know how to fix it.
  • 641 Answers
SOURCE: smeg dishwasher wash cycle freezes ,
Thanks for the information.
Posted on Jul 24, 2007
gwshaw71
  • 83 Answers
SOURCE: maytag dishwasher MDBTT60AWW
if you can select different cycles such as rinse only and that light up and then if you change it to normal cycle and it light up,then that tells me you touch pad is working,Check your door switches if those are good and your touch pad is responding, i would replace cpu board.If you remove the kick plate there should be a tech sheet there you can put unit into diagnostic mode with a certain key dance if your touch pad is responding.
Posted on Nov 25, 2007
SOURCE: Kitchenaid Dishwasher Control Panel lights - some don't light up
control panel light all of a sudden do not come on and my unit wont start model kud101fl
Posted on Mar 25, 2008
onthejob5130
  • 640 Answers
SOURCE: whirlpool g2p dwi
either the latch thats on the door is bad,,or the catch on the tub is out of line,,,now if the dishwasher door drops hard and wont stay up ..you need new door spring and the weight makes it pop[ open..
Posted on Dec 24, 2008
SOURCE: Clean light on dishwasher won't stop flashing
yust reset press heated dry-normal-heated dry normal-and it will work 100% remember that code it is reset code for wirpool quiet partner and many other models
Posted on Feb 19, 2009
No power after blocked drain dishwasher
Reset it by turning power off to it or unplugging it for a minute. If it still wont work then you need to take the kick panel off and see if there is leak under the machine.
Feb 08, 2014 | Smeg Dishwashers
All lights up flashing lights but will not start
all lights flashing on programme washing machine wont start
Aug 29, 2013 | Smeg Dishwashers
I have a Bosch SHU9955US/14 (Integra) dishwasher. There is currently a 0 with and asterisk showing on the display and the unit will not run.
see this causes and fix it. God bless you
Thermal Fuse If the dishwasher won't start the thermal fuse might have blown. The thermal fuse helps to prevent damage to the dishwasher by turning off power so that it doesn't overheat. Once blown, the thermal fuse will have to be replaced for the dishwasher to work.
Door Switch The door switch, or switches, are sometimes called interlock switches. The door switch prevents the dishwasher from running while the door is open. If the dishwasher won't start, the switch or switches might be defective. To access the door switches, remove the control panel or inside door panel - depending on the model. They can be tested for continuity.
Main Control Board The main control board provides power to nearly every component of the dishwasher. If the dishwasher won't start the main control board might be defective. YOU should first check for more common parts. Many times control boards are replaced unnecessarily because the problem was not diagnosed properly.
Touchpad and Control Panel If the touchpad is defective, the control board might not get the signal for the selections made. If the dishwasher won't start and the display doesn't seem to change properly when the buttons are pressed, the touchpad might need to be replaced. On some models the touchpad and control panel are sold together and will need to be replaced at the same time.
Touchpad If the touchpad is defective, the control board might not get the signal for the selections made. If the dishwasher won't start and the display doesn't seem to change properly when the buttons are pressed, the touchpad might need to be replaced.
Timer The timer allows power to flow to the proper parts at the proper times. If the dishwasher won't start, the timer might be defective. Keep in mind that timers are often misdiagnosed as the cause of a problem. Check other components first before replacing the timer.
Sep 29, 2012 | Bosch Dishwashers
E1 message on smeg DWI 614
E1--Leakage error--Conditon: Excessive RPM of washing motor happened during wash cycle due to water leakage. Possible cause: Water leakage in hose connections,water is leaked by damages. The motor water seal leakage of sump assembly. The height of drain hose connection (sink drain hose) is not over 20". Impeller of the washing pump is worn away
Sep 28, 2012 | Dishwashers
Dx103wk will not start
You will need to be a bit more specific about what does "will not start mean"
Do you see the lights on the panel
are you able to set the wash program
are you able to press the start button.
Does it start and then stop or it never does anything except flash lights when you press the strart button.
If you have shut the door but pressing the start button causes no action then most likely the door switch is faulty or the door gasket is swollen and does not let the door close properly.
Please post a comment to take this fruther.
Sep 24, 2010 | Smeg STX2 Dishwashers
SMEG DWI410 TRIPS CIRCUIT LATE IN WASHING CYCLE
just possibly
take the kick panel off. On some smeg, there is a small suppressor capacitor on the lhs tucked in the wiring. this breaks down. snip it off - no need to replace
Jul 18, 2008 | Smeg 18 in. DWI410 Built-in Dishwasher
Dishwashers Logo
105 people viewed this question
Top Smeg Dishwashers Experts
Starnley Johnwells
Starnley Johnwells
Are you a Smeg Dishwasher Expert? Answer questions, earn points and help others
